    DUET 2 Wifi, DIAG Led is constantly ON, no respond from terminal
    2.5k
    • darkcolmanundefined
      darkcolman @jay_s_uk
      @jay_s_uk I have also change the name of the sd card "0" after to receive the message from pronterface. Before the SD card named "WORKBEE"
        jay_s_uk @darkcolman
        @darkcolman you're on 3.4.1 so theres no need to send M997 S0 (as that updates the mainboard firmware, which is already up to date) you just need M997 S1.
        you also don't need to change the name of the SD card. 0:/ is the name internally used by RRF to identify the sd card slot in the board
        darkcolmanundefined 1 Reply Last reply Reply Quote 0
          @jay_s_uk on the picture, I've done as well the command M997 S1. the file is not found easer. And it's been placed in the good subflle at the beginning with the correct name
            @darkcolman what format is the SD card?
              @jay_s_uk FAT 32
                @darkcolman post an output of M122
                  @jay_s_uk
                  Capture d’écran 2022-07-22 à 16.06.00.png Capture d’écran 2022-07-22 à 16.05.55.png
                    darkcolman @darkcolman
                    @jay_s_uk weird, the SD card seems not detected ...
                    I can say that when it's fully inserted, I can hear a faint click and when I push again, it release the SD card.
                    and all pins seems okay to me
                      @darkcolman that was my guess that the sd card wasn't being detected. I would reformat the sd card using the sd card formatter and start again https://www.sdcard.org/downloads/formatter/
                      or try another sd card
                      if that doesn't work, try M39 and see what it reports
                        If the steps provided by Jay don't get it working there may be a problem with the SD card slot. Could you provide some close up photos of the slot and it's soldering?
                        darkcolmanundefined 1 Reply Last reply Reply Quote 1
                          darkcolman @Phaedrux
                          @phaedrux @jay_s_uk actually it works ! thanks a lot for that !
                          M997 S1 has been a success 🙂
                            @darkcolman how did you fix it?
                              @jay_s_uk I've followed your advice and I've formatted the SD Card from Formatter software and it worked perfectly.
                              But Now I've another issue....
                              I can't connect the duet to the wifi to set it up.
                              the link that I've followed :
                              https://docs.duet3d.com/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                              And this is what I've done
                              I can't or maybe I don't understand how to Configure network SSID and password.
                              What I've missed ?
                                @darkcolman don't use pronterface. It converts all text to uppercase. You can faff on adding a ' in front of each lowercase letter but it's better just to use putty or YAT
                                  For MacOS your best bet is probably SerialTools
                                  https://docs.duet3d.com/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-3-connect-to-duet
                                    @phaedrux Yes I have this app but don't know why, but never been a success when I've tried to connect the duet to the router 😭
                                    @jay_s_uk I found a PC and I've download YAT and it works !!!!!!
                                    I mean Almost !!!!! 😭😭😭
                                    the blue wifi led is now ON !
                                    the duet is connected but When I tried to be on the IP address, I can't access to the duet platform. I've got this message ERR_CONNECTION_REFUSED
                                    also I can't see the duet on the wifi network list
                                      @darkcolman ok, thats good that its connected. Is the IP address of the duet on the same range that you are connected to with your PC/laptop?
                                      How is the PC/Laptop you're using connected? Wireless or wired?
                                        @jay_s_uk router is in wireless but I've realized that I did a mistake in the IP router. so I've done it again. The module is connected to access point to the IP address: 192.168.0.10 and my IPv4 address of my router is 192.168.0.14.
                                        On the PC, nothing changed but on my Mac I've got this.
                                        here is my sd card
                                          @darkcolman the www folder should contain all the files that are in the duetwebcontrol folder, not another folder.
                                            @jay_s_uk I've done it and still the same problem.
                                            I've send a M122 command and the SD card is not detected...
