    DUET 2 Wifi, DIAG Led is constantly ON, no respond from terminal
    2.5k
    • darkcolmanundefined
      darkcolman @Phaedrux
      @phaedrux @jay_s_uk actually it works ! thanks a lot for that !
      M997 S1 has been a success 🙂
        jay_s_uk @darkcolman
        @darkcolman how did you fix it?
        darkcolmanundefined 1 Reply Last reply Reply Quote 0
          darkcolman @jay_s_uk
          @jay_s_uk I've followed your advice and I've formatted the SD Card from Formatter software and it worked perfectly.
          But Now I've another issue....
          I can't connect the duet to the wifi to set it up.
          the link that I've followed :
          https://docs.duet3d.com/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
          And this is what I've done
          I can't or maybe I don't understand how to Configure network SSID and password.
          What I've missed ?
            @darkcolman don't use pronterface. It converts all text to uppercase. You can faff on adding a ' in front of each lowercase letter but it's better just to use putty or YAT
              For MacOS your best bet is probably SerialTools
              https://docs.duet3d.com/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-3-connect-to-duet
              darkcolmanundefined 1 Reply Last reply Reply Quote 1
                @phaedrux Yes I have this app but don't know why, but never been a success when I've tried to connect the duet to the router 😭
                @jay_s_uk I found a PC and I've download YAT and it works !!!!!!
                I mean Almost !!!!! 😭😭😭
                the blue wifi led is now ON !
                the duet is connected but When I tried to be on the IP address, I can't access to the duet platform. I've got this message ERR_CONNECTION_REFUSED
                also I can't see the duet on the wifi network list
                  @darkcolman ok, thats good that its connected. Is the IP address of the duet on the same range that you are connected to with your PC/laptop?
                  How is the PC/Laptop you're using connected? Wireless or wired?
                    @jay_s_uk router is in wireless but I've realized that I did a mistake in the IP router. so I've done it again. The module is connected to access point to the IP address: 192.168.0.10 and my IPv4 address of my router is 192.168.0.14.
                    On the PC, nothing changed but on my Mac I've got this.
                    here is my sd card
                      @darkcolman the www folder should contain all the files that are in the duetwebcontrol folder, not another folder.
                        @jay_s_uk I've done it and still the same problem.
                        I've send a M122 command and the SD card is not detected...
                          @darkcolman I don't see anything wrong with that response.
                          Could you show the contents of the root of the SD card and the contents of the www folder
                            @jay_s_uk there is everything
                              @darkcolman that looks fine as well.
                              do you not have a config? are you just sending M552 S1 over serial?
                                @jay_s_uk yes I'm just sending M552 S1 on YAT.
                                what do you mean by the config ? config.g ?
                                  @darkcolman yes.
                                  Add a file called. config.g in the sys folder. Only include the following contents
                                  M552 S1
                                  darkcolmanundefined 2 Replies Last reply Reply Quote 0
                                    @jay_s_uk I've seen it before to have all those issues.
                                    I will sound probably stupid but it's not on GitHub. Where can I get the config.g ?
                                      @darkcolman just create a blank one and add the content above.
                                      notepad or equivalent will do it.
                                      when the board is powered, it should activate wifi. that way we know the sd card is being read
                                        @jay_s_uk sorry I understood now. I will !
                                          @jay_s_uk It working ! I can access now to the duet web controller ! a huge thanks for that !
                                          I have another question, The duet is pinned to my router.
                                          But the board will be back to the workshop and there is no wifi there. I remember, the guy from Ooznest set my duet to send it own wifi.
                                          I've plugged out the router and I can't connect the duet.
                                          How Could I achieve this ?
                                          jay_s_ukundefined infiniteloopundefined 2 Replies Last reply Reply Quote 1
                                            @darkcolman you can use access point mode https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#configuring-duet-in-wifi-access-point-mode
