    z probe not referenced
    Firmware installation
    809
      jay_s_uk @axiom
      @axiom said in z probe not referenced:
      G1 H1 Z705 F360 ; move Z up stopping at the endstop
      G90 ; absolute positioning
      G92 Z700 ; set Z position to axis maximum (you may want to adjust this)
      you're trying to home using an endstop.
      To home with a probe you need to move to the position you want to probe, usually the middle of the bed and then use G30
      E.g.
      G1 X150 Y150
      G30
      axiomundefined 1 Reply Last reply Reply Quote 0
      • axiomundefined
        axiom @jay_s_uk
        @jay_s_uk
        I commented out lines 6 and 10 and added lines 11 and 12.
        Now the message appears: "G28 Error: Probe already triggered at start of probinge move
        here the new code:
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool v3.3.12 on Wed Aug 24 2022 12:56:11 GMT+0200 (Mitteleuropäische Sommerzeit)
        G91 ; relative positioning
        ;G1 H2 Z5 F6000 ; lift Z relative to current position
        G1 H1 X-505 Y-505 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
        G1 H2 X5 Y5 F6000 ; go back a few mm
        G1 H1 X-505 Y-505 F360 ; move slowly to X and Y axis endstops once more (second pass)
        ;G1 H1 Z705 F360 ; move Z up stopping at the endstop
        G1 X150 Y150
        G30
        ;G91 ; relative positioning
        ;G90 ; absolute positioning
          jay_s_uk @axiom
          this line is a good idea to have
          this line should be removed.
          And what value does your probe show as having on the status screen?
          axiomundefined 2 Replies Last reply Reply Quote 0
          • axiomundefined
            axiom @jay_s_uk
            @jay_s_uk now comes the message:
            Error: Failed to enable endstops
            nwe code:
            ; homeall.g
            G1 X150 Y150
            G30
            ;G92 Z700 ; set Z position to axis maximum (you may want to adjust this)
            • axiomundefined
              axiom @jay_s_uk
                jay_s_uk @axiom
                @axiom that shows that your probe is triggered already. what type of probe is it?
                • axiomundefined
                  axiom @jay_s_uk
                  @jay_s_uk
                  a capacitive proximity sensor:
                  https://www.amazon.de/Heschen-kapazitiver-Näherungsschalter-Sensor-LJC18-A3-H-Z-Normalöfnung/dp/B071J6PXD1/ref=sr_1_5?__mk_de_DE=ÅMÅŽÕÑ&crid=1NG0J5PZMIZC4&keywords=kapazitiver+sensor&qid=1661366023&sprefix=kapizativer+sensor%2Caps%2C138&sr=8-5
                  i got the same for my little ender printer and it works since 2 years
                    jay_s_uk @axiom
                    @axiom you may need to invert the signal
                    e.g. M558 P1 C"!zprobe.in"
                    but you should test it before trying to home with it
                    • axiomundefined
                      axiom @jay_s_uk
                      @jay_s_uk
                      now the z-axis moves down instead of up when homing...but it responds to my hand and stops
                        jay_s_uk @axiom
                        @axiom you need to invert the direction of your Z axis then. It should be negative movement going up and positive going down
                        • axiomundefined
                          axiom @jay_s_uk
                          @jay_s_uk And how do I do that?
                            jay_s_uk @axiom
                            @axiom Change the S value in each M569 for the Z drivers. If its 0 change it to 1 and vice versa
                            • axiomundefined
                              axiom @jay_s_uk
                              @jay_s_uk how do i know which ones are for the z-axis...since i connected two, i don't want them to work in opposite directions...that might break the motors
                                jay_s_uk @axiom
                                @axiom you've mapped the driver numbers in M584
                                axiomundefined 1 Reply Last reply Reply Quote 1
                                • axiomundefined
                                  axiom @jay_s_uk
                                  @jay_s_uk you are super! it works... thanks for your patience!
                                  • Phaedruxundefined Phaedrux has marked this topic as solved
