    Mistake True bed levelling G32
    2.1k
      jay_s_uk @A Former User
      @sgk the euclid ones are here https://euclidprobe.github.io/06_rrf3.html
        A Former User @jay_s_uk
        @jay_s_uk ok thanks
        • jumpedwithbothfeetundefined
          jumpedwithbothfeet @A Former User
          @sgk Here are my macro's for my Klicky probe it`s mounted on a Voron trident, but they are quite simple but will need to be adjusted to your printer but hopefully they help ๐Ÿ™‚
          homeall.g
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 18:55:28 GMT+0100 (British Summer Time)
          G1 H2 Z3 F6000          ; lift Z relative to current position
          G1 H1 X400 Y400 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H1 X400 ; fast home x
          G1 H1 Y400 ; fast home y
          G1 X-5 Y-5 F600       ; go back a few mm
          G1 H1 X10 ; fine home x
          G1 H1 Y10 ; fine home y
          G90                     ; absolute positioning
          G1 Y310 F7000 ; Pick Up Klicky
          G1 X42 F7000 ; Pick Up Klicky
          G1 Y358 F7000 ; Pick Up Klicky
          G1 X180 Y180 F7000      ; go to first bed probe point and home Z
          G30                     ; home Z by probing the bed
          G1 Y310 F7000 ; Drop Klicky
          G1 X42 F7000 ; Drop Klicky
          G1 Y358 F7000 ; Drop Klicky
          G1 X89 F7000 ; Drop Klicky
          G1 Z3 F100             ; lift Z relative to current position
          homez.g
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 06 2020 18:55:29 GMT+0100 (British Summer Time)
          G1 H2 Z5 F600    ; lift Z relative to current position
          G1 X180 Y180 F7000 ; go to first probe point
          G1 Z5 F100       ; lift Z relative to current position
          bed.g
          ; bed.g
          ;G29  ; probe the bed and enable compensation
          ;G28 ; home
          M401 ; deploy Z probe (omit if using bltouch)
          G30 P0 X30 Y0 Z-99999 ; probe near a leadscrew, Front left leadscrew
          G30 P1 X30 Y300 Z-99999 ; probe near a leadscrew, Rear left leadscrew
          G30 P2 X330 Y0 Z-99999 ; probe near a leadscrew, Rear Right leadscrew
          G30 P3 X330 Y300 Z-99999 S4 ; probe near a leadscrew and calibrate 4 motors
          M402 ; retract probe (omit if using bltouch)
          6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
            A Former User @jumpedwithbothfeet
            @jumpedwithbothfeet
            great thank you guys. it's possible that you make me a picture of your model to have an idea?
            jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
              @sgk https://www.vorondesign.com/voron_trident my trident is no long standard it has 4 lead screws on the z axis even the klicky probe is not standard however the macro`s should give you an idea when you compare them to yours.
                @jumpedwithbothfeet
                OK great I see every time you feel the bed she will look for the probe that's it?
                A Former User? jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                  A Former User @A Former User
                  @sgk
                  the guy i ordered the probe more than receive it and install๐Ÿ˜Š
                      @sgk the hot end assy moves to the klicky mount you can see on the rear left of the picture, it then picks up the klicky using the magnets, probes each part of the bed requested then goes back to the klicky mount and removes the probe, it is based on the Euclid probe and has worked flawlessly for me.
                        A Former User
                        I have to make a support in 3d right?
                          @sgk if your using the Klicky probe then yes just print the files supplied and assemble, I cant comment on the Euclid probe as I donโ€™t know what is supplied.
                          https://github.com/jlas1/Klicky-Probe Link for Klicky files ๐Ÿ˜Š
                            @jumpedwithbothfeet ๐Ÿ‘ thanks
                            • Norderundefined Norder referenced this topic
