    Duet mini 5+ freezes and shuts off heaters
    90
    4.4k
    • Michael Hathawayundefined
      Michael Hathaway
      Duet mini 5+ freezes a few layers in and shuts off heaters.
      Firmware 3.4.1
      E3D V6, 50W heater, pt1000
      Pulse XE bed
      350W Mean Well
      No error recorded in console. Nothing recorded on event log. Printer just freezes mid print in position and changes temp to zero on both heaters.
      Temperature of print:
      330C hotend
      106C bed
      I have replaced the mini 5+ board, replaced sdcard. Replaced Slice e 50w cartridge and thermostat.
      If the power supply fails, will there be an event log?
      Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
      www.MatterHackers.com - https://discord.gg/Ked7GREqux
      Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
        Michael Hathaway @Michael Hathaway
        m122
        RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus Ethernet (standalone mode)
        Board ID: 6G14B-Z096U-D65J0-40KMD-2113Z-7JZ07
        Used output buffers: 1 of 40 (24 max)
        Static ram: 103684
        Dynamic ram: 105204 of which 0 recycled
        Never used RAM 32824, free system stack 200 words
        Tasks: NETWORK(ready,26.7%,246) ETHERNET(notifyWait,0.3%,563) HEAT(notifyWait,0.0%,340) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,105) MAIN(running,71.4%,422) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
        Owned mutexes:
        Last reset 00:19:41 ago, cause: reset button
        Last software reset at 2022-09-06 10:42, reason: User, GCodes spinning, available RAM 32536, slot 1
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        MCU revision 3, ADC conversions started 1181396, completed 1181396, timed out 0, errs 0
        Step timer max interval 1488
        MCU temperature: min 40.2, current 40.0, max 51.4
        Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 27, reads 62146, writes 9, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 29, reads 62146, writes 9, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 62146, writes 9, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 62, read errors 0, write errors 1, ifcnt 23, reads 62145, writes 9, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 62146, writes 9, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: not present
        Driver 6: not present
        Date/time: 2022-09-06 20:47:55
        Cache data hit count 2023545538
        Slowest loop: 141.79ms; fastest: 0.13ms
        === Storage ===
        Free file entries: 9
        SD card longest read time 15.8ms, write time 41.8ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty
        === Filament sensors ===
        Extruder 0 sensor: ok
        === CAN ===
        Messages queued 10630, received 0, lost 0, boc 0
        Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 5906/0/0
        Tx timeouts 0,0,5905,0,0,4723 last cancelled message type 4514 dest 127
        === Network ===
        Slowest loop: 4.35ms; fastest: 0.03ms
        HTTP sessions: 2 of 8
        - Ethernet -
        State: active
        Error counts: 0 0 0 0 0
        Socket states: 2 2 2 2 2 0 0 0
           Config.g
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 23 2021 16:36:21 GMT-0700 (Pacific Daylight Time)
          G90                                                ; send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          M550 P"Pulse E-423S"                               ; set printer name
          M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
          M586 P0 S1                                         ; enable HTTP
          M586 P1 S0                                         ; disable FTP
          M586 P2 S0                                         ; disable Telnet
          M569 P0.0 S0                                       ; X-axis drive 0.0 goes backwards
          M569 P0.1 S1                                       ; Y-axis drive 0.1 goes forwards
          M569 P0.2 S1                                       ; Z-axis drive 0.2 goes backwards
          M569 P0.3 S0                                       ; Extruder drive 0.3 goes forwards
          M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E409.00                  ; set steps per mm
          M566 X600.00 Y600.00 Z30.00 E270.00                ; set maximum instantaneous speed changes *(mm/min)(8x60=480) 'jerk speed'
          M203 X12000.00 Y12000.00 Z12000.00 E7200.00        ; set maximum speeds *(mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E5000.00           ; set accelerations (mm/s^2)
          M906 X1000 Y1200 Z1000 E1000 I40                   ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                            ; Set idle timeout
          M208 X0 Y0 Z0 S1                                   ; set axis minima
          M208 X250 Y225 Z227 S0                             ; set axis maxima
          M574 X1 S1 P"io5.in"                               ; configure active-high endstop for low end on X via pin io5.in
          M574 Y1 S1 P"io6.in"                               ; configure active-high endstop for low end on Y via pin io6.in
          M574 Z1 S1 P"io2.in"                               ; configure active-high endstop for low end on Z via pin io2.in
          M950 S0 C"io3.out"                                 ; create servo pin 0 for BLTouch
          M558 P9 C"io3.in" H5 F1000 T8000                  ; set Z probe type to bltouch and the dive height + speeds F1000 T600
          G31 P500 X23 Y10 Z 0.88                         ; *** set Z probe trigger value, offset and trigger height (increase to lower nozzle) glass, g10=0.85
          M557 X23:240 Y25:205 S20                           ; define mesh grid M557 X25:225 Y25:205 S20 S40
          M308 S0 P"temp0" Y"thermistor" T100000 B4066       ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
          ; M307 H0 R0.25 C860.4 D14.2 S1.00 V24.0 B0         ; disable bang-bang mode for the bed heater and set PWM limit
          M307 H0 R0.210 K0.413:0.000 D7.79 E1.35 S1.00 B0
          M140 H0                                            ; map heated bed to heater 0
          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
          ; M308 S1 P"temp1" Y"thermistor" T100000 B4275 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1 E3D low temp sensor
          ; M308 S1 P"temp1" Y"thermistor" T500000 B3800     ; configure sensor 1 as thermistor on pin temp1 Slice Engineering 450C
          M308 S1 P"temp1" Y"pt1000"                       ; configure sensor for pt1000 high temp sensor Slice Engineering or Filastruder
          M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
          ; M307 H1 R2.648 C163.1:161.1 D6.32 S1.00          ; OLD disable bang-bang mode for heater  and set PWM limit
          M307 H1 R2.168 K0.365:0.000 D7.57 E1.35 S1.00 B0 V23.9 ; new T0 tuning result
          M143 H1 S500                                       ; set temperature limit for heater 1 to 500C
          ; M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
          ; M106 P0 C"PartCool" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
          M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
          M106 P1 C"HotEnd" S1 H1:0 T35                      ; set fan 1 name and value. Thermostatic control is turned on
          M950 F2 C"out5" Q500                               ; create fan 2 on pin out5 and set its frequency
          M106 P2 C"CaseFan" S1 H1:0 T35                     ; set fan 2 name and value. Thermostatic control is turned on
          M563 P0 S"Hotend" D0 H1 F0                         ; define tool 0
          G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
          ; Filament Runout Switch
          M591 D0 P1 C"io_4.in" S1                           ; P0 P1 NO/NC
          ; Pressure Advance                                 ; D = extruder drive number, S =amount of pressure advance
          ; M572 D0 S0.5
          ; Custom settings
          M280 P0 S160					                   ; Clear any alarms
          M402							                   ; Retract pin just in case
          M929 P"eventlog.txt" S3                            ; start logging to file eventlog.txt
          T0                                                 ; select first tool
          G29 S1                                             ; Load Height Map
            I can try replacing the power supply. I have no idea what else could be causing this issue.
              The only spare power supply I had on hand is a Mean Well SE-600-24, 600W. I have it sitting outside the enclosure this time. It is overkill for this printer, I use these on my industrial printers. Ok for testing I hope.
                The printer went 5 layers and stopped. I have no idea why it is freezing.
                jay_s_ukundefined TLASundefined 2 Replies Last reply Reply Quote 0
                  jay_s_uk @Michael Hathaway
                  @michael-hathaway Is the M122 output you posted from directly after the freeze?
                    Michael Hathaway @jay_s_uk
                    @jay_s_uk
                    M122
                    Used output buffers: 1 of 40 (22 max)
                    Static ram: 103684
                    Never used RAM 32824, free system stack 204 words
                    Tasks: NETWORK(ready,26.4%,238) ETHERNET(notifyWait,0.3%,568) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,105) MAIN(running,71.7%,422) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0%
                    Owned mutexes:
                    Last reset 00:03:26 ago, cause: reset button
                    Error status: 0x00
                    MCU revision 3, ADC conversions started 206480, completed 206480, timed out 0, errs 0
                    Step timer max interval 751
                    MCU temperature: min 48.7, current 48.7, max 51.8
                    Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 29, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 3: standstill, SG min 54, read errors 0, write errors 1, ifcnt 21, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
                    Date/time: 2022-09-07 02:37:14
                    Cache data hit count 353060786
                    Slowest loop: 8.73ms; fastest: 0.13ms
                    === Storage ===
                    SD card longest read time 5.2ms, write time 44.1ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    Code queue is empty
                    === CAN ===
                    Messages queued 1856, received 0, lost 0, boc 0
                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 1032/0/0
                    Tx timeouts 0,0,1031,0,0,823 last cancelled message type 30 dest 127
                    === Network ===
                    Slowest loop: 12.40ms; fastest: 0.03ms
                    - Ethernet -
                    State: active
                    Michael Hathawayundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                      This one is directly after freeze
                        @michael-hathaway said in Duet mini 5+ freezes and shuts off heaters:
                        this is the reason for the "freezes". now its just understanding why this is happening.
                        Might be a good idea to post a high res picture of the reset button area
                          @jay_s_uk So the reset button on the board is being triggered?
                            @michael-hathaway yep
                                  Is there anyway of resetting besides pressing that button?
                                    @michael-hathaway i suppose the question is when and where did you purchase?
                                    one for @Phaedrux or maybe @droftarts
                                      not that i'm aware of
                                      Michael Hathawayundefined 1 Reply Last reply Reply Quote 1
                                        My old board just started doing this recently after 1.5 years use. And my new board does the same exact thing. I purchased from Filastruder 1.5 years ago.
                                          droftarts administrators @Michael Hathaway
                                          @michael-hathaway I just did a quick test on my Mini 5+ to see what a power cycle, M999 (reset) and reset button press reports on restart in M122.
                                          M999:
                                          Last reset 00:00:12 ago, cause: software
                                          Last software reset at 2022-09-07 11:54, reason: User, GCodes spinning, available RAM 27680, slot 0
                                          Error status: 0x00
                                          Reset button:
                                          Last reset 00:00:13 ago, cause: reset button
                                          Error status: 0x00
                                          Power cycle:
                                          Last reset 00:00:22 ago, cause: power up
                                          Error status: 0x00
                                          I did the M999 first, and that is what the subsequent M122 'Last software reset...' is reporting. I notice that your M122 also reports the same time for 'Last software reset...' so I don't think the reset is coming from the firmware or gcode file.
                                          I think if the firmware is reporting a reset button press, it probably actually is a reset button press or short. Is the printed case you have the Duet in new? My guess is that, as the board heats up, it's flexing slightly and somehow shorting out on the case. Maybe add some nylon washers under your mounting screws (ideally the board should be mounted using nylon washers), to lift the board up a little?
                                          Michael Hathawayundefined 1 Reply Last reply Reply Quote 2
                                            Michael Hathaway @droftarts
                                            @droftarts Thank you, I will try that. I will also order a new board just in case I have fried this one.
