    Duet mini 5+ freezes and shuts off heaters
    90
    4.4k
    • Michael Hathawayundefined
      Michael Hathaway @Michael Hathaway
      I can try replacing the power supply. I have no idea what else could be causing this issue.
      Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
      www.MatterHackers.com - https://discord.gg/Ked7GREqux
      Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
        The only spare power supply I had on hand is a Mean Well SE-600-24, 600W. I have it sitting outside the enclosure this time. It is overkill for this printer, I use these on my industrial printers. Ok for testing I hope.
          The printer went 5 layers and stopped. I have no idea why it is freezing.
          jay_s_ukundefined TLASundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Michael Hathaway
            @michael-hathaway Is the M122 output you posted from directly after the freeze?
              Michael Hathaway @jay_s_uk
              @jay_s_uk
              M122
              RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus Ethernet (standalone mode)
              Board ID: 6G14B-Z096U-D65J0-40KMD-2113Z-7JZ07
              Used output buffers: 1 of 40 (22 max)
              Static ram: 103684
              Dynamic ram: 105204 of which 0 recycled
              Never used RAM 32824, free system stack 204 words
              Tasks: NETWORK(ready,26.4%,238) ETHERNET(notifyWait,0.3%,568) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,105) MAIN(running,71.7%,422) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0%
              Owned mutexes:
              Last reset 00:03:26 ago, cause: reset button
              Last software reset at 2022-09-06 10:42, reason: User, GCodes spinning, available RAM 32536, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              MCU revision 3, ADC conversions started 206480, completed 206480, timed out 0, errs 0
              Step timer max interval 751
              MCU temperature: min 48.7, current 48.7, max 51.8
              Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 29, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: standstill, SG min 54, read errors 0, write errors 1, ifcnt 21, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 10837, writes 9, timeouts 0, DMA errors 0, CC errors 0
              Driver 5: not present
              Driver 6: not present
              Date/time: 2022-09-07 02:37:14
              Cache data hit count 353060786
              Slowest loop: 8.73ms; fastest: 0.13ms
              === Storage ===
              Free file entries: 9
              SD card longest read time 5.2ms, write time 44.1ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty
              === Filament sensors ===
              Extruder 0 sensor: ok
              === CAN ===
              Messages queued 1856, received 0, lost 0, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 1032/0/0
              Tx timeouts 0,0,1031,0,0,823 last cancelled message type 30 dest 127
              === Network ===
              Slowest loop: 12.40ms; fastest: 0.03ms
              HTTP sessions: 2 of 8
              - Ethernet -
              State: active
              Error counts: 0 0 0 0 0
              Socket states: 2 2 2 2 2 0 0 0
              Michael Hathawayundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                This one is directly after freeze
                  @michael-hathaway said in Duet mini 5+ freezes and shuts off heaters:
                  this is the reason for the "freezes". now its just understanding why this is happening.
                  Might be a good idea to post a high res picture of the reset button area
                    @jay_s_uk So the reset button on the board is being triggered?
                      @michael-hathaway yep
                            Is there anyway of resetting besides pressing that button?
                              @michael-hathaway i suppose the question is when and where did you purchase?
                              one for @Phaedrux or maybe @droftarts
                                not that i'm aware of
                                Michael Hathawayundefined 1 Reply Last reply Reply Quote 1
                                  My old board just started doing this recently after 1.5 years use. And my new board does the same exact thing. I purchased from Filastruder 1.5 years ago.
                                    droftarts administrators @Michael Hathaway
                                    @michael-hathaway I just did a quick test on my Mini 5+ to see what a power cycle, M999 (reset) and reset button press reports on restart in M122.
                                    M999:
                                    Last reset 00:00:12 ago, cause: software
                                    Last software reset at 2022-09-07 11:54, reason: User, GCodes spinning, available RAM 27680, slot 0
                                    Error status: 0x00
                                    Reset button:
                                    Last reset 00:00:13 ago, cause: reset button
                                    Error status: 0x00
                                    Power cycle:
                                    Last reset 00:00:22 ago, cause: power up
                                    Error status: 0x00
                                    I did the M999 first, and that is what the subsequent M122 'Last software reset...' is reporting. I notice that your M122 also reports the same time for 'Last software reset...' so I don't think the reset is coming from the firmware or gcode file.
                                    I think if the firmware is reporting a reset button press, it probably actually is a reset button press or short. Is the printed case you have the Duet in new? My guess is that, as the board heats up, it's flexing slightly and somehow shorting out on the case. Maybe add some nylon washers under your mounting screws (ideally the board should be mounted using nylon washers), to lift the board up a little?
                                    Michael Hathawayundefined 1 Reply Last reply Reply Quote 2
                                      Michael Hathaway @droftarts
                                      @droftarts Thank you, I will try that. I will also order a new board just in case I have fried this one.
                                        @michael-hathaway Looking at the Mini 5+ schematic (https://raw.githubusercontent.com/Duet3D/Duet3-Mini5plus/main/v1.01/Duet3_5%2B_Wifi_schematic_v1.01.pdf), there are also reset pins on the 12864_EXP2 connector, SWD connector (just behind the reset button, but as it is unpopulated with a header, this shouldn't be a problem) and there's also a test point (on the back of the board, by the SWD connector pins, I think). I don't think you have anything plugged into the 12864 connector, but again check that it is not shorting out to anything, top or bottom.
                                          I ordered a new Duet mini 5 plus board with overnight postage, should have it tomorrow. I also ordered nylon washers as recommended.
                                          This time when mounting in the petg enclosure, I will allow to board to float and not be fastened down so well.
                                          I have found new Samsung endurance sdcards, which are designed to be powered on continuously. I am hopeful this increases reliability.
                                          I appreciate everyone's help I have received and I will update with my progress as I proceed.
                                            Brand new Duet mini 5+ board, mounted loose on nylon washers.
                                            Reset tripped, frozen mid print.
                                            9/10/2022, 1:42:33 AM 	m122
                                            Board ID: 6MFQS-V096U-D65J0-40KMJ-JS03Z-R72JU
                                            Used output buffers: 1 of 40 (15 max)
                                            Static ram: 103684
                                            Tasks: NETWORK(ready,26.2%,246) ETHERNET(notifyWait,0.2%,568) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,114) MAIN(running,71.9%,422) IDLE(ready,0.2%,29) AIN(delaying,0.8%,264), total 100.0%
                                            Owned mutexes:
                                            Last reset 00:01:26 ago, cause: reset button
                                            Last software reset details not available
                                            Error status: 0x00
                                            MCU revision 3, ADC conversions started 87093, completed 87092, timed out 0, errs 0
                                            Step timer max interval 752
                                            MCU temperature: min 60.2, current 60.2, max 62.8
                                            Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 39, reads 4560, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 1: standstill, SG min 4, read errors 0, write errors 1, ifcnt 39, reads 4560, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 4559, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 4559, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 29, reads 4560, writes 9, timeouts 0, DMA errors 0, CC errors 0
                                            Date/time: 2022-09-10 01:42:33
                                            Cache data hit count 148434782
                                            Slowest loop: 8.24ms; fastest: 0.13ms
                                            === Storage ===
                                            SD card longest read time 1.0ms, write time 3.8ms, max retries 0
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            Code queue is empty
                                            === CAN ===
                                            Messages queued 783, received 0, lost 0, boc 0
                                            Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 436/0/0
                                            Tx timeouts 0,0,435,0,0,346 last cancelled message type 30 dest 127
                                            === Network ===
                                            Slowest loop: 4.93ms; fastest: 0.03ms
                                            - Ethernet -
                                            State: active
