SOLVED - Heater Temp not increasing after initial test.
i used T0 for the command after firmware update and it says "no heater tuned"
Hotend heater gets error of "temperature rising too slowly"
@anvil ah yes, I mean T0 not T1. Where do you see that error about no heater tuned?
When you send M303 do you see any rise out of the temperature at all? -
@jay_s_uk both on the web interface and my paneldue
but currently im dealing with a random "incompatible firmware version" that randomly popped up after working fine for a bed tune and trying to tune the nozzle...
grrrrrrr
@jay_s_uk
ok got everything connected again and the right firmware all going...but yes the heater rises verrrrryyyyyy slooooowly...
idle at same temp as be so i know the thermistors are correct... but ya it goes from 26.8 to like 27.4 before it says its not increasing fast enough -
@anvil sounds like you have a wiring issue. I'd start by using a multimeter to check the heater of the rapido
does the rapido need to be double fed or something? specs say its a 115w heater... not sure why its not heating. its all wired correctly. I cant find any documentation on a wiring diagram for it.
@anvil no, it doesn't need to be double fed. Are you using the right voltage version for your system?
Have you checked it with a multimeter? -
Can you send M122 and post the results?
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6JKFJ-3S86S-TBDQP
Used output buffers: 1 of 26 (12 max)
Static ram: 23860
Dynamic ram: 75112 of which 0 recycled
Never used RAM 13108, free system stack 184 words
Tasks: NETWORK(ready,10.2%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,82.2%,440) IDLE(ready,7.5%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:12 ago, cause: software
Last software reset at 2022-09-16 15:21, reason: User, GCodes spinning, available RAM 13108, slot 1
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 37.3, current 38.1, max 38.2
Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2022-09-16 15:21:13
Cache data hit count 458831398
Slowest loop: 5.52ms; fastest: 0.18ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 16.01ms; fastest: 0.00ms
HTTP sessions: 1 of 8
= WiFi =
Network state is active
WiFi firmware version 1.23
WiFi MAC address dc:4f:22:6e:6b:09
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22944
WiFi IP address 192.168.0.33
WiFi signal strength -51dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
Socket states: 0 0 0 0 0 0 0 0 -
Your wifi server version is out of date for 3.4.2. How did you update the firmware?
I suggest uploading the firmware zip file again to ensure everything is up to date.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.2/Duet2and3Firmware-3.4.2.zip
Next try tuning the heater again and take a screen shot of the temp graph and capture the complete error message if you get one.
M303 H0 S200
So i just noticed something on my paneldue when it starts up.... doesnt show up in the web console for some reason... but it says T0 hasnt been set up and that the bed seems to be overpowered.
I think my bed and nozzle are competing for the same tool definition in the config.. not sure how to fix it... i swapped the numbers and got the nozzle to start increasing temp normally but only by setting the bed temp and activating... can i fix this in my config or do i need to change something in my .json?
@phaedrux i think theres something up with the definition of my heaters... can you look it over and see if its odd with the bed and primary tool being the way they are?
This post is deleted! -
Is this what you still have for your heater definitions?
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C -
@phaedrux said in Heater Temperature not increasing after initial test.:
M303 H0 S200
Sorry, this should have been H1. H0 is the bed. H1 is the nozzle heater.
@phaedrux yes that’s what my config has
And lol ya I figured out it should have been h1.
But ya… no joy. But when I swapped the T0 and T1 when I activated the bed heater my nozzle started climbing at normal speed… but of course since it was looking for the bed to raise temp is errored out with the temp not increasing message. So I swapped it back and am trying to see what I did wrong in my configuration helper…
Do I need to do it again after upgrading from 2.x firmware to 3.x firmware… then to the latest version? Or did telling the configuration tool that I was coming from 2.x to 3.x automatically update everything needed after then just updating to the latest version?
Can you grab that?
I'm not sure what you mean with the rrf2 vs rrf3 questions.
Has your config changed from the one posted above?
No it’s the same. I was following the migrating from 2 to 3 guide and didn’t know if I did something wrong when the reprap configurator asks you what firmware your running… figure it’s the same now since the system files all have the color coded look like the new version I’m running on my modix.
And I’m not sure the temp graph will show much of anything… temp barely climbs 1c before it errors out saying it’s increasing too slow. But I’ll have to get a screenshot tomorrow. Left the shop for the evening.
@anvil said in Heater Temperature not increasing after initial test.:
Does the temp graph show a rise in temp if you just hold the hotend in your hand for a bit?
Does Rapido give you some values to use for this thermistor?
