    Euclid facility
    91
    4.7k
      A Former User @jumpedwithbothfeet
      @jumpedwithbothfeet I will change and seeπŸ‘
        A Former User @A Former User
        I changed but when I run g32 or g29 it doesn't work
        jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
        • jumpedwithbothfeetundefined
          jumpedwithbothfeet @A Former User
          @sgk ok back to the beginning, when you home all axis, the printer does this? the euclid probe is detected and you can move all axes of the printer independently?
          6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
            @sgk this thread is getting long and I have lost track of what the current problem is. Can you state it again?
            To clarify how we intend a deployable probe such as the Euclid to be used:
            • Put the GCode movement commands needed to deploy or pick up the probe in file sys/deployprobe.g on the SD card, and nowhere else
            • Put the GCode movement commands needed to retract or stow the probe in file sys/retractprobe.g on the SD card, and nowhere else
            • Then if you run M401 it should pick up the probe. If you run M401 again then it will not repeat the pickup moves, but it will increment an internal counter
            • If you run M402 it will stow the probe, unless the internal counter indicates that M401 was run more than once without an intervening M402; in which case it just decrements the counter
            • When you have that working, if you command the nozzle to a XY position over the bed and execute G30, it should pick up the probe, return to the original position, probe the bed, and stow the probe
            • Running G29 S0 should pick up the probe, run mesh probing (assuming you have used M557 to define the grid), and stow the probe
            • The only time you need to use M401 and M402 explicitly is in a bed.g file that contains multiple G30 commands. If you don't use M401 then it will pick up and stow the probe for every probe point. If you use M401 before the first G30 command then it will pick up the probe once at the start and stow it once at the end.
            • Never invoke deployprobe.g or retractprobe.g directly. That would pick up or stow the probe without adjusting the internal counter, which RRF uses to keep track of whether the probe is deployed or stowed.
            HTH David
              A Former User @dc42
              @dc42 to put it simply since I installed the euclid probe when I run the g32 or g29 command nothing happens, that is to say the probe does not palpate the bed.
              I followed the euclid probe instructions. Deploy and retract config.g homeall home z. I'll make another video to see better.
                @jumpedwithbothfeet When I go home all she goes to get the probe and pats the center of the bed.
                Yes I can move all my axes.
                  jay_s_uk @A Former User
                  @sgk lets start a fresh shall we? please post the contents of the following files.
                  • config.g
                  • homez.g
                  • homeall.g
                  • deployprobe.g
                  • retractprobe.g
                  • bed.g
                    A Former User @jay_s_uk
                    retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
                    πŸ‘
                    want the files in raw or it goes in ZIP
                      A Former User
                      My bed 350x350x350 and prob euclid X0 y8. 5 IMG_20220916_191317_edit_18382711277923.jpg
                        M558 K0 P5 C"^io2.in" H8 F300 60 T9000 A3 S0.01
                        G31 K0 P500 X-27.955 Y-18.716 Z1.033
                        If you include K0, you need to use K0 everywhere else the probe is called. You only have a single probe, so remove K0 from your config where you have it.
                        In your bed.g and home all you have a bunch of moves to pick the probe but then you also call the probe deploy. Your pickup moves should just be in the deploy macro.
                        G1 Y8.5 F6000 ; Pick Up Klicky
                        G1 X20 F2000 ;
                        G1 X0 F1000 ; Pick Up Klicky
                        G1 Y30 F1000 ;
                        G1 Y50 F6000 ; Pick Up Klicky
                        M401 ; deploy Z probe (omit if using bltouch)
                          A Former User @Phaedrux
                          @phaedrux ok thank you I have to change the probe control in the bed m558 and g31?
                            A Former User? Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              https://youtu.be/9wJ2RCimWXU
                              it gives me that
                                Phaedrux Moderator @A Former User
                                @sgk said in Euclid facility:
                                No. That's not what I meant at all. Your deploy and retract macros seem fine. You just need to call them with M401 and M402 in your bed.g and homeall.g files when you want to pick up or two away the probe. You don't need the manual G1 moves to pick it up there.
                                Did you remove the K0?
                                  @phaedrux k0 deleted
                                    I'm really sorry I'm completely lost at this point
                                      And return your deployprobe.g macro to how it was before?
                                      With K0 removed, does G28, G32, and G29 function now?
                                        @phaedrux
                                        I deleted my deploy and retract and I didn't save
                                          πŸ‘
                                          Good thing you uploaded them here.
                                            @phaedrux yes niceπŸ‘
