    Extruder Stepper not responding
    347
    • Norderundefined
      Norder @mlbuxbaum123
      @mlbuxbaum123
      However, it is only possible to extrude the filament at a hot end temperature of 160°C. The retraction of the filament only from 90°C.
      All that only when the tool is activated, i.e. click once on the name of the HotEnd in the DWC.
      Before that, the entire function is grayed out.
      Google Translate
      -- Original Text --
      Es wird aber erst bei einer HotEnd Temperatur von 160°C möglich das Filament zu extrudieren. Das zurückziehen des Filaments erst ab 90°C.
      Alles dass erst wenn das Werkzeug aktiviert ist, also einmal auf den Namen des HotEnd im DWC klicken.
      Vorher ist die gesamte Funktion ausgegraut.
      • mlbuxbaum123undefined
        mlbuxbaum123 @jay_s_uk
        @jay_s_uk
        dashboard says EXTRUDER DRiVE as DRIVE 0
        Config file for drives says
        M569 P0 S0 ; physical drive 0 (X AXIS) goes S0=backwards, S1=forwards
        M569 P1 S0 ; physical drive 1 (Y AXIS) goes S0=backwards, S1=forwards
        M569 P2 S0 ; physical drive 2 (Z AXIS) goes S0=backwards, S1=forwards
        M569 P3 S1 ; physical drive 3 goes S0=backwards, S1=forwards
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M84 S30 ; Set idle timeout
          mlbuxbaum123 @deckingman
          @deckingman said in Extruder Stepper not responding:
          @mlbuxbaum123 There are lots of possible reasons but with the very limited information provided, I can only make an informed guess. The most common reason is that by default, extrusion is prohibited until the hot end is heated. The next most common reason is that no tool is selected. The third most common reason is that the tool has not been configured to use the correct extruder drive. I could continue but you get the idea. For testing purposes, without any filament loaded, you could try sending M302 P1 via the console which will allow cold extrudes. https://docs.duet3d.com/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
          If that doesn't allow you to extrude, then you'll need to post your complete config.g file.
          (This all assumes that you've checked the wiring and tested the motor).
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.13 on Thu Sep 22 2022 07:04:13 GMT-0400 (Eastern Daylight Time)
          M550 P"My Printer" ; set printer name
          M669 K1 ; select CoreXY mode
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M208 X300 Y300 Z285 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
          M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
          M558 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          M307 H0 R0.168 K0.302:0.000 D2.11 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
          M307 H1 R2.148 K0.388:0.000 D6.07 E1.35 S1.00 B0 V12.0 ; disable bang-bang mode for heater and set PWM limit
          M563 P0 H1 F0 ; define tool 0
          • engikeneerundefined
            engikeneer @mlbuxbaum123
            @mlbuxbaum123 copy paste the text in a reply here.
            You can also use the code snippet tool on the forum to make it easier to read. It's the </> symbol by Bold and Italic. Makes the code look like this
            M552 S2 ; comment
            i3 clone with a bunch of mods
            • Norderundefined
              This post is deleted!
                jay_s_uk @mlbuxbaum123
                @mlbuxbaum123 config looks good. just add T0 to the end of your config on its own line
                mlbuxbaum123undefined 1 Reply Last reply Reply Quote 0
                  @jay_s_uk at the very end of the config file? Below the M911 S10 line?
                  jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                    @mlbuxbaum123 yep
                      deckingman @mlbuxbaum123
                      @mlbuxbaum123 Actually, your config.g does not look good.
                      This line "M563 P0 H1 F0 ; define tool 0" is missing a drive number. Try this
                      M563 P0 D0 H1 F0
                      mlbuxbaum123undefined 1 Reply Last reply Reply Quote 2
                        @deckingman YES !!!!!! that worked ! Just had to reverse direction of that motor in the config file as well !! THANK YOU !!
                        • Phaedruxundefined Phaedrux has marked this topic as solved
