    IR-Probe - Faulty triggers well before the actual trigger point
    ir-probe wrong triggers
    1.2k
    • dabohundefined
      daboh @Phaedrux
      @phaedrux
      Here is a close up.
      markzundefined 1 Reply Last reply Reply Quote 0
      • markzundefined
        markz @daboh
        @daboh What is your config.g setup for the probe? Here's mine:
        M558 P1 C"io4.in" R1 H2.5 F200 T5000 A10 S0.01 ; define Z probe and set dive height, probe speed and travel speed
        The triggering is dependent on the type of bed you're using because it is using infrared reflection to trigger. So, the bed needs to be smooth. When I had concerns about the bed surface I used small white paper stick-ons at the test points as they provide an easy flat ir surface.
        dabohundefined 1 Reply Last reply Reply Quote 0
        • dabohundefined
          daboh @markz
          @markz said in IR-Probe - Faulty triggers well before the actual trigger point:
          M558
          I am using klipper and set the probe like the last picture in my first post. I am using the probe in digital mode. The led is blinking two times on power up.
          I use a GRP FR4 plate, but have already tried it with a piece of paper. Is GFK FR4 not suitable?
          Is somebody else here using the ir probe with gfk bed plate?
          If the accuracy runs through, the range is very high in my opinion.
          I wonder if the IR probe is defective, since it also triggers well outside the actual measuring point.
          Norderundefined 1 Reply Last reply Reply Quote 0
            Do you have any stray bright light in the area that may be interacting?
            Has it ever worked correctly?
            • dabohundefined
              daboh
              This inconsistent behavior has been since the beginning. I especially do not understand that it sometimes triggers so early (8mm too early) that it can not home z. The next time you try, it may work again...
              There are no bright stray lights in the area that could interact with the light.
              Is there any experience with GRP (GFK FR4) plate?
                Phaedrux Moderator @daboh
                @daboh said in IR-Probe - Faulty triggers well before the actual trigger point:
                The plate should be irrelevant as you have tested with a plain piece of paper as well, correct?
                The only wild card here is that you're running klipper rather than RRF, so I'm not familiar with the configuration, but I don't think a configuration error would result in random probe performance.
                Are there any stray hairs or wisps of filament on the sensor?
                  A Former User
                  This post is deleted!
                  • dabohundefined
                    daboh @Phaedrux
                    @phaedrux
                    Yes I also tried it with a sheet of paper with the same result. The sensor is free of filament or other foreign matter.
                    I still suspect the sensor is defective otherwise the reviews on the net would not be justified.
                    • dabohundefined
                      daboh @A Former User
                      @herve_smith
                      Thanks for your info. That is of course interesting. Which print bed did you have the problem with?
                      Can you give me a link to the dockable probe?
                      Since I am using the probe also to home z it is unfortunately inevitable that the sensor triggers too early.
                        I have the IR-Probe (https://www.dold-mechatronik.de/IR-Probe)
                        When did you purchase it?
                        • Norderundefined
                          Norder @daboh
                          I use an FR4 plate and the IR probe.
                          It is a black FR4 plate without any imprints such as logos or writing.
                          It's the Blackprint from Printbay and I'm extremely satisfied with the measurement results and with the printing plate that I've been using for a number of years.
                          Unfortunately, I'm not familiar with Klippers either.
                          At what trigger value should the IR test trigger?
                          In RRF it is 500 which is specified with the P parameter in the G31 command.
                          Maybe this is where the problem lies!?
                          It may sound a bit crazy, but for testing purposes, applying a small amount of oil to a small area on the FR4 and measuring the IR probe there greatly increases the accuracy of the measurement.
                          Or you can put the metallic back of a coated spring steel plate on top and measure on it, then the repeatability is extremely high. It only deviates from me by 0.001mm, if at all.
                          In this way, measuring errors of the probe can be ruled out and the fluctuating repeatability of 0.05 (example value) can be assigned to the roughness of the printing surface.
                          Google Translate
                          -- Original Text --
                          Benutzt hier noch jemand die IR-Sonde mit GFK-Grundplatte?
                          Ich nutze eine FR4 Platte und den IR-Probe.
                          Es ist eine schwarze FR4 Platte ohne jegliche Aufdrucke wie Logos oder Schriften.
                          Es ist die Blackprint von Printbay und ich bin mit dem Messergebnissen so wie mit der Druckplatte, die ich schon einige Jahre nutze, bestens zufrieden.
                          Ich kenne mich mit Klipper leider auch nicht aus.
                          Ab welchem Auslösewert soll die IR-Probe auslösen ?
                          In RRF ist es 500 der mit dem Parameter P im Befehl G31 angegeben wird.
                          Eventuell liegt hier das Problem !?
                          Es mag sich etwas verrückt anhören, aber wenn man zu Testzwecken etwas Öl dünn auf einen kleinen Bereich auf der FR4 verteilt und dort die IR-Probe messen lässt, erhöht es enorm die Messgenauigkeit.
                          Oder man legt die metallische Rückseite einer beschichteten Federstahlplatte nach oben und misst dort drauf, dann ist die Wiederholgenauigkeit extrem hoch. Sie weicht bei mir nur 0,001mm ab, wenn überhaupt.
                          So kann man Messfehler der Sonde ausschließen und die schwankende Wiederholgenauigkeit von 0,05 (Beispielwert) der Rauheit der Druckoberfläche zuordnen.
                          DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
                          Thingiverse
                          Norderundefined 1 Reply Last reply Reply Quote 1
                          • Norderundefined
                            Norder @Norder
                            Do you have a light on the printer or on the print head?
                            If yes, then try to configure the printer in such a way that the lighting switches off shortly before each measurement.
                            The lighting "could" cause reflections that "could" interfere with a measurement.
                            Better safe than sorry. 😉
                            P.S.:
                            I just asked Uncle Google about IR probes and Klippers.
                            in some older posts people also complain about this problem.
                            I don't know if Klipper has this feature now but everyone was hoping for a fast followed by a slower probing drive as the IR probe with Klipper works better with a very slow probing.
                            Try changing the probing speed from 10.0 to 5 or less and then try again to see if the readings stay more consistent.
                            You should also post your problem on a Klipper forum.
                            Google Translate
                            -- Original Text --
                            Hast Du am Drucker oder am Druckkopf eine Beleuchtung ?
                            Wenn Ja, dann versuche den Drucker so zu konfigurieren dass sich die Beleuchtung kurz vor jeder Messung aus schaltet.
                            Es "könnten" durch die Beleuchtung Spiegelungen entstehen die eine Messung stören "könnten".
                            Sicher ist sicher. 😉
                            P.S.:
                            Ich habe mal kurz Onkel Google gefragt zum Thema IR-Probe und Klipper.
                            in einigen älteren Beiträgen klagen die Leute auch über dieses problem.
                            Ich weiß nicht ob Klipper diese Funktion jetzt hat, aber alle haben auf eine schnelle gefolgt von einer langsameren Sondierungsfahrt gehofft, da die IR-Probe mit Klipper besser mit einer sehr langsameren Sondierung funktioniert.
                            Versuche mal die Sondierungsgeschwindigkeit von 10.0 auf 5 oder weniger zu stellen und dann versuche es noch einmal ob die Messwerte konstanter bleiben.
                            Du solltest Dein Problem auch in einem Klipper-Forum stellen.
                            Thingiverse
                            dabohundefined 1 Reply Last reply Reply Quote 1
                            • dabohundefined
                              daboh @Phaedrux
                              @phaedrux said in IR-Probe - Faulty triggers well before the actual trigger point:
                              Last week. From here: https://www.dold-mechatronik.de/IR-Probe
                              • dabohundefined
                                daboh @Norder
                                @norder
                                Thanks for your help.
                                I have already turned off the light. Without success.
                                Also reduced the driving speed to 5. Without success.
                                I cannot set a trigger value. But since the sensor does not run in analog mode, that should not be necessary. It acts as a pure switch (led lights up twice when switched on).
                                I described my problem here, because I assume a hardware failure of the IR probe. My dealer is already informed and asked me to ask here in the forum for possible sources of error before sending it back, to make sure that the IR-Probe is defective.
                                Danke für deine Hilfe.
                                Ich habe bereits das Licht ausgeschaltet. Ohne Erfolg.
                                Auch die Fahrgeschwindigkeit auf 5 reduziert. Ohne Erfolg.
                                Einen Auslösewert kann ich nicht einstellen. Da der Sensor aber nicht im analogen Modus läuft, sollte das auch nicht nötig sein. Er fungiert als reiner Schalter (Led leuchtet zweimal beim Einschalten).
                                Ich habe mein Problem hier beschrieben, da ich von einem Hardwarefehler des IR-Probes ausgehe. Mein Händler ist bereits informiert und hat mich gebeten vor dem Rücksenden hier im Forum nach möglichen Fehlerquellen zu fragen, um sicherzustellen, dass der IR-Probe defekt ist.
                                • markzundefined
                                  markz @daboh
                                  @daboh I have an FR4 bed that I use sometimes and the IR Sensor has worked fine with it. I also have sunlight that streams in a side window and it hasn't caused any issues with the sensor.
                                  I assume you've checked your wiring quality and resistance to movement? The one problem I had at first was an intermittent connection.
                                    @daboh we will replace the sensor. Please send an email to warranty@duet3d.com and cc your supplier. Include a link to this thread in your email. You will receive a reply with a link to a form to fill in.
                                    • dabohundefined
                                      daboh @dc42
                                      Thank you very much for replacing my sensor.
                                      How will this be handled? Do i get a new one from my dealer and my dealer will get credit?
                                      Norderundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • Norderundefined
                                        Norder @daboh
                                        @daboh
                                        My printer is also a JGAurora, namely the A5X, which also had the MKS Gen L at the time.
                                        In the meantime, only the base frame has remained from the original, everything else has been rebuilt.
                                        The electronics box no longer exists because all the electronics have moved under the print bed. Everything has been converted to linear rails, completely custom designed print head and print bed etc.
                                        Nobody recognizes the previous printer anymore.
                                        The best move was switching from MKS Gen L (Marlin) to Duet Wifi (RRF).
                                        I can only recommend everyone to install a Duet Board that inspires reliability and the new possibilities.
                                        An MKS Gen L works, but a Duet is really fun and much more user-friendly.
                                        And by the way... the IR-Probe works as intended.
                                        No... I do not receive any money or other benefits from Duet3D. 😄
                                        Unfortunately 😞
                                        P.S.:
                                        However, from today's perspective I would rather go for a board from the Duet3 series, as they have stealth chop.
                                        My motors rustle a bit, which I unfortunately can't get rid of, since the MKS Gen L was actually quieter (it had 2208 drivers retrofitted at the time).
                                        Google Translate
                                        --- Original Text --
                                        Mein Drucker ist auch ein JGAurora und zwar der A5X der damals auch das MKS Gen L hatte.
                                        Mittlerweile ist nur noch der Grundrahmen vom Original geblieben, alles andere wurde umgebaut.
                                        Die Elektronik-Box gibt es nicht mehr da die komplette Elektronik unter das Druckbett gewandert ist. Alles wurde auf Linarschienen umgebaut, komplett eigens entworfener Druckkopf und Druckbett etc.
                                        Keiner erkennt mehr den vorherigen Drucker.
                                        Der beste Schritt war der wechsel von MKS Gen L (Marlin) auf Duet Wifi (RRF).
                                        Ich kann jedem nur empfehlen sich ein Duet Board zu installieren, die Zuverlässigkeit und die neuen Möglichkeiten begeistern.
                                        Ein MKS Gen L funktioniert, aber ein Duet macht erst so richtig Spaß und bringt eine viel bessere Bedienerfreundlichkeit.
                                        Und nebenbei... der IR-Probe läuft so wie er gedacht ist.
                                        Nein... ich bekomme kein Geld oder sonstige Zuwendungen von Duet3D. 😄
                                        Leider 😞
                                        P.S.:
                                        Allerdings würde ich aus heutiger Sicht eher zu einem Board aus der Duet3 Serie greifen, da diese Stealthchop haben.
                                        Meine Motoren rauschen etwas, was ich leider nicht weg bekomme, da war das MKS Gen L tatsächlich leiserer (hatte damals 2208 Treiber nachgerüstet).
                                        Thingiverse
                                          A Former User @daboh
                                            dc42 administrators @daboh
                                            That is correct.
                                            • oliofundefined oliof referenced this topic
