    Duet 2 Wifi Dual Z issue after increasing esteps
    1.7k
    • slabstationsundefined
      slabstations @slabstations
      @jay_s_uk 24v. It even says it on the dashboard, that was one of the first things I checked.
        jay_s_uk @slabstations
        @slabstations how fast are you trying to move the motors?
        max speed you can really run them at before generating too much EMF is 28mm/s (F1680)
        slabstationsundefined Norderundefined 2 Replies Last reply Reply Quote 0
          slabstations @jay_s_uk
          @jay_s_uk Honestly I am not sure, whatever the default is when you control it through the web interface. I started with the creality ender 3 base config in the configurator. I have gotten an ender 3 pro up and running, so I just copied the config and change printer size to fit the lulzbot. Only thing I did different was add a bl touch to the lulzbot, which seems to be working properly, have only gotten as far as retracting and dropping it.
          slabstationsundefined 1 Reply Last reply Reply Quote 0
          • Norderundefined
            Norder @jay_s_uk
            According to the previous information... Motor model / Za + Zb / voltages and speeds from the config.g) this result should be more accurate.
            I didn't know the values for "Phase resistance" and "Phase inductance" and I didn't change the displayed value either.
            @slabstations :
            I asked you earlier whether you have two end stops and possibly want to use E1 and Za for the two Z motors !? 🙂
            Google Translate
            -- Original Text --
            Nach den bisherigen Infos... Motoren Modell / Za + Zb / Spannungen und Geschwindigkeiten aus der config.g) sollte dieses Ergebnis zutreffender sein.
            Werte für "Phase resistance" und "Phase inductance" wusste ich nicht und habe den angezeigten Wert auch nicht geändert.
            @slabstations :
            Ich hatte Dich vorhin gefragt ob Du zwei Endstops hast und eventuell E1 und Za für die beiden Z-Motoren nutzen willst !? 🙂
            DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
            Thingiverse
              @jay_s_uk I would like the dual z bed leveling. Do you think I should try setting that up and hope this problem goes away, or do you think it could be something I have setup wrong?
                slabstations @Norder
                @norder I only have one endstop switch mounted on highend of the left z axis. And setting up two z motors sounds good, I like the bed leveling feature!
                  @slabstations it definitely won't hurt as it makes sure everything is level. it may or may not help your issue though.
                  I would bump your current for Z up to 1200, separate them out as you say (don't forget the jumpers). and map E1 to Z using M584 e.g. M584 Z2:4
                  Then repost your config, homez and homeall
                    @jay_s_uk I followed the instructions from this https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors Hopefully everything is good, I don't want to test it until its been looked over just in case! I really appreciate your time and help!
                    homeall.g config.g bed.g homez.g
                      @jay_s_uk
                      config.g: ; Configuration file for Duet WiFi (firmware version 3)
                      ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Sep 24 2022 04:07:34 GMT-0400 (Eastern Daylight Time)
                      ;M575 P1 S1 B57600                              ; enable support for PanelDue
                      G90                                            ; send absolute coordinates...
                      M83                                            ; ...but relative extruder moves
                      M550 P"LulzBot Mini"                           ; set printer name
                      ;M918 P1 E4 F2000000                            ; configure direct-connect display
                      M551 P"1084"                                   ; set password
                      M552 S1                                        ; enable network
                      M586 P0 S1                                     ; enable HTTP
                      M586 P1 S0                                     ; disable FTP
                      M586 P2 S0                                     ; disable Telnet
                      M569 P0 S1                                     ; physical drive 0 goes forwards
                      M569 P1 S0                                     ; physical drive 1 goes backwards
                      M569 P2 S1                                     ; physical drive 2 goes forwards
                      M569 P3 S0                                     ; physical drive 3 goes backwards
                      M584 X0 Y1 Z2:4 E3                             ; set drive mapping
                      M671 x20:200 y0:0 s0.5                         ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                      M208 X05:205 Y0:200                            ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                      M92 X101.26 Y100.00 Z1600 E436.54              ; set steps per mm
                      M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
                      M203 X9000.00 Y9000.00 Z1200.00 E6000.00       ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z1200 E1000 I50                  ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                        ; Set idle timeout
                      M208 X0 Y0 Z0 S1                               ; set axis minima
                      M208 X170 Y180 Z148 S0                         ; set axis maxima
                      M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                      M574 Y1 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                      M574 Z2 S1 P"zstop"                            ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
                      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
                      M557 X15:170 Y15:180 S20                       ; define mesh grid
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                        ; map heated bed to heater 0
                      M143 H0 S110                                   ; set temperature limit for heater 0 to 110C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S275                                   ; set temperature limit for heater 1 to 275C
                      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 C"Extruder Fan" S1 H1 T160             ; set fan 0 name and value. Thermostatic control is turned on
                      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 C"Case Fan" S1 H0 T50                  ; set fan 1 name and value. Thermostatic control is turned on
                      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 C"Part Cooling" S1 H-1                 ; set fan 2 name and value. Thermostatic control is turned off
                      M563 P0 S"Extruder" D0 H1 F0                   ; define tool 0
                      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                      ; bed.g
                      G29  ; probe the bed and enable compensation
                      G28 ; home
                      G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
                      G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                      ; homeall.g
                      ; called to home all axes
                      G1 H2 Z5 F6000          ; lift Z relative to current position
                      G1 H1 X-175 Y-185 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000       ; go back a few mm
                      G1 H1 X-175 Y-185 F240  ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z153 F240         ; move Z up stopping at the endstop
                      G90                     ; absolute positioning
                      G92 Z148                ; set Z position to axis maximum (you may want to adjust this)
                      ;G91                    ; relative positioning
                      ;G1 Z5 F100             ; lift Z relative to current position
                      ;G90                    ; absolute positioning
                      ; homez.g
                      ; called to home the Z axis
                      G1 H1 Z153 F3000 ; move Z up until the endstop is triggered
                      Phaedruxundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @slabstations
                        ; bed.g
                        You'll want to remove the G29 from bed.g. At least move it to the end of the file after the leveling if you want it to create a mesh at the same time. Otherwise handle the mesh creation separately.
                        jay_s_ukjay_s_uk 4 Oct 2022, 03:57
                        @slabstations what voltage are you running at?
                           0
                        slabstationsslabstations 4 Oct 2022, 04:07
                           0
                        jay_s_ukjay_s_uk 4 Oct 2022, 04:10
                           0
                        slabstationsslabstations 4 Oct 2022, 04:47
                           0
                        NorderNorder 4 Oct 2022, 04:48
                        @slabstations :
                        Google Translate
                        -- Original Text --
                        @slabstations :
                        Thingiverse
                           0
                        slabstationsslabstations 4 Oct 2022, 04:49
                           0
                        slabstationsslabstations 4 Oct 2022, 04:52
                           0
                        jay_s_ukjay_s_uk 4 Oct 2022, 04:52
                           0
                        slabstationsslabstations 7 Oct 2022, 09:12
                           0
                        slabstationsslabstations  7 Oct 2022, 09:15
                        @jay_s_uk
                        ; bed.g
                        G28 ; home
                        ; homeall.g
                        At the end of homeall and homez you are using an endstop to home the Z axis. You'll want to use the probe instead. To do this, remove those 3 lines and replace them with something like
                        G90
                        G1 X150 Y150 F6000 ; move to bed center
                        G30 ; probe the Z axis
                        You can also add those lines to the end of bed.g so that any change in Z position from the tilt correction is captured.
                          deckingman @slabstations
                          @slabstations This is not relevant to your problem, but you have two sets of axis limit commands (M208) - one under your "drives" section, the other in "axis limits". The latter will override the former so you might want to remove the former and/or make sure that the latter matches the machine (the two set of values are different and only one can be true).
                            slabstations
                            @Phaedrux I was able to get both z motors running properly and able to run the g32 command successfully. Everything seems good to go, but when I heat the bed after PID the board makes loud chrips/hums and such. Here is a link to what it sounds like https://youtube.com/shorts/MbS4bipRc7Y?feature=share I tried adding Q10 to M950 H0 and same sounds just different pitch. It was printing, but has since stopped in the middle of the print.
                            M569 P3 S1 ; physical drive 3 goes backwards
                            M671 x0:170 y40:40 s0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                            M906 X800 Y800 Z800 E2000 I50 ; set motor currents (mA) and motor idle factor in per cent
                            G31 P500 X-22 Y-13 Z2.056 ; set Z probe trigger value, offset and trigger height
                            M557 X0:170 Y0:110 S20 ; define mesh grid
                            M950 H0 C"bedheat" T0 Q15 ; create bed heater output on bedheat and map it to sensor 0
                            M307 H0 R0.582 K0.516:0.000 D3.58 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                            Norderundefined 1 Reply Last reply Reply Quote 0
                            • Norderundefined
                              Norder @slabstations
                              @slabstations said in Duet 2 Wifi Dual Z issue after increasing esteps:
                              Is the parameter Q with the value 15 wanted? Default is Q250 for heaters.
                              This could cause the hissing noise when Q15 is not requested for the heater.
                              If Q250 is correct for the heater I would repeat the PID tuning.
                              Thingiverse
                                @norder I did not have the Q15 in there before and it did the same thing, I had read on a few post on the forum that it may fix it. I even set it to 250 and same noise
                                • Norderundefined
                                  @slabstations
                                  You always had the hissing, or when did it start?
                                  Thingiverse
                                  Norderundefined slabstationsundefined 2 Replies Last reply Reply Quote 0
                                  • Norderundefined
                                    Norder @Norder
                                    Do you mean the noise that can be heard when you show the print head?
                                    Thingiverse
                                      You could try Q1 or Q2 even. I don't think you'll be able to totally eliminate the sound though.
                                      Did you stop it or are you saying it stopped? Was there an error message? What exactly happened?
                                        @norder It starts to play a high pitch sound when the bed is being heated, besides that it seems normal. And the sound in the video that syncs up with the red light flashing on the board, not the steppers moving.
                                          slabstations @Phaedrux
                                          @phaedrux I tried that too and it was still annoyingly loud, do you think it could be the power supply? I could try hooking a meanwell one up to it.
                                            @Phaedrux The stock one on the LulzBot Mini is a 24v 150watt, meanwell is 24v 350watts.
