    Issues with pressure advance since RRF 3.4
    308
    37.9k
    • Argoundefined
      Argo @Phaedrux
      @phaedrux
      What would be different in your environment to mine? I mean what if a Duet test machine does show the problem. Is there a debugging firmware involved that does provide more data?
      • MartinNYHCundefined
        MartinNYHC
        Same bulging here.
        6HC + 1LC with RRF 3.4.3 and PA 0.035.
        • gloomyandyundefined
          gloomyandy @R4ffers
          @r4ffers If you think you have this problem please post details of your configuration (mainboard, toolboard or expansion board if any, pressure advance setting, Input shaper setting, print speed, acceleration, jerk), plus if you can a photo showing an example of the problem.
          R4ffersundefined 2 Replies Last reply Reply Quote 1
          • R4ffersundefined
            R4ffers @gloomyandy
            @gloomyandy Hi, here's some info.
            Voron v2.4
            Duet3 mini5+ with SBC
            Duet3 mini2+ expansion board
            Toolboard 1LC v1.2
            LGX lite extruder
            Firmware 3.4.3
            PA 0.095
            Tried with superslicer & prusaslicer
            Tried different speeds, accelerations & jerk settings giving same results.
            IMG_20221008_174046337.jpg IMG_20221008_174111573.jpg IMG_20221008_174131286.jpg IMG_20221008_174159305.jpg
            Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
            Argoundefined 1 Reply Last reply Reply Quote 2
            • R4ffersundefined
              R4ffers @gloomyandy
              @gloomyandy Here's my config file, Speed macro & prusaslicer gcode
              1664142820911-bulgecheck.gcode
              ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
              M550 P"duet3"
              ; PanelDue
              M575 P1 S1 B57600
              ; Toolhead leds
              M150 X3 Q3000000
              ;M150 B255 P255 S1 F1
              M150 W255 P255 S2 F0
              M111 S0                	; Debugging off
              G21                    	; Work in millimetres
              G90                     ; send absolute coordinates...
              M83                     ; ...but relative extruder moves
              M669 K1                 ; select CoreXY mode
              ; Limit axis
              M564 S1 H1             	; Forbid axis movements when not homed
              						; H1	Forbid movement of axes that have not been homed
              						; S1	Limit movement within axis boundaries
              ; Wait a moment for the CAN expansion boards to start
              G4 S2
              ; DRIVERS
              M569 P121.0 S0                                   ; E - physical drive 121.0 goes backwards
              M569 P0.5 S1 D2                                  ; A -> Y - physical drive 0.0 goes forwards
              M569 P0.6 S1 D2                                  ; B -> X - physical drive 0.1 goes forwards
              M569 P0.0 S1                                     ; Z0 - physical drive 0.3 goes forwards
              M569 P0.1 S0                                     ; Z1 - physical drive 0.4 goes backwards
              M569 P0.2 S1                                     ; Z2 - physical drive 0.5 goes forwards
              M569 P0.3 S0                                     ; Z3 - physical drive 0.6 goes backwards
              M584 X0.6 Y0.5 Z0.0:0.1:0.2:0.3 E121.0           ; set drive mapping
              M350 X32 Y32 Z32 E16 I1                          ; configure microstepping with interpolation
              M92 X160.00 Y160.00 Z800.00 E562.00              ; set steps per mm
              ; Accelerations and speed are set in separate macro
              M98 P"/macros/set_normal_speed.g"
              ; Stepper driver currents
              ; set motor currents (mA) and motor idle factor in per cent
              ; Drive currents
              M906 X1200 Y1200 Z1200 E600 I70                  ; XYZ and E current
              M84 S120                                         ; Idle timeout
              M574 X2 S1 P"^121.io0.in"                       ; configure active-high endstop for high end on X via pin ^121.io0.in
              M574 Y2 S1 P"^0.io1.in"                         ; configure active-high endstop for high end on Y via pin ^io1.in
              M574 Z0 p"nil"                                  ; No Z endstop
              ; Magnetic filament sensor
              ;M591 D0 P3 C"121.io1.in" S1
              ; Axis travel limits                            ; Mind this is travel NOT print area
              M208 X0:350 Y0:360 Z-0.5:300                    ; Set axis minima - negative X is to have 0,0 on bed corner
                                                              ; WARNING on Z not to hit the roof - this is set here
              ; Belt Locations
              M671 X-60:-60:410:410 Y-10:420:420:-10 S20      ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
              											    ; Position of the bed leadscrews.. 4 Coordinates
              											    ; Snn Maximum correction to apply to each leadscrew in mm (optional, default 1.0)
                                                              ; S20 - 20 mm spacing
              M557 X50:300 Y40:325 P6                         ; Define bed mesh grid (inductive probe, positions include the Y offset!)
              ; Bed heater
              M308 S0 A"Bed Heater" P"temp0" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out0" Q10 T0                           ; create bed heater output on out0 and map it to sensor 0
              M307 H0 B0 R0.637 C222.4 D0.95 S1.00 V24.0
              M140 H0                                          ; map heated bed to heater 0
              M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
              ; Hotend heater
              M308 S1 A"Nozzle" P"121.temp0" Y"pt1000"         ; configure sensor 1 as pt1000 on pin 121.temp0
              M950 H1 C"121.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
              M307 H1 B0 R2.518 C174.0 D6.14 S1.00 V23.8
              M143 H1 S270                                     ; set temperature limit for heater 1 to 270C
              ; SENSORS MISC
              ; Define MCU sensors which will be available in DWC Extra View
              M308 S3 A"MCU" Y"mcu-temp" 						; Officially NOT supported on Mini 3 5+ however seem to work
              M308 S4 A"Duet Drivers" Y"drivers" 		        ; This is not really working as it is just a threshold crossing
              ; CHAMBER SENSOR
              M308 S10 A"Chamber" P"0.temp2" Y"thermistor" T100000 B3950
              ; Z PROBES K0 (mag probe) and K1 (Microswitch Z0)
              ; MAG PROBE (GND, IO)
              ; This is the mag probe with microswitch in Afterburner
              M558 K0 P8 C"^121.io2.in" T18000 F600:180 H5 A10 S0.03
              G31 K0 P500 X-2.5 Y24.5 Z0.86 ;Z
              ; Z-SWITCH
              ; This is the microswitch which is pressed by the Noozle
              M558 K1 P8 C"^io5.in" T18000 F1200:180 H3 A10 S0.005 R0
              ; Omron micro switch
              G31 K1 P500 X0 Y0 Z0.47
              ; Part cooling fan
              M950 F0 C"121.out1"                              ; create fan 0 on pin 121.out2 and set its frequency
              M106 P0  H-1 C"Part cooling fan"                 ; set fan 0 value. Thermostatic control is turned off
              ; Hotend fan
              M950 F1 C"121.out2"                              ; create fan 1 on pin 121.out1 and set its frequency
              M106 P1 S1 H1 T45 C"Hotend fan"                  ; set fan 1 value. Thermostatic control is turned on
              M950 F2 C"0.out4"                                ; create fan 2 on pin out4 and set its frequency
              M106 P2 S1 H3:4 T30 C"Controller fan 1"          ; controlled by Sensor 3 - MCU
              ; Controller fan 2
              M950 F3 C"0.out3"                                ; create fan 3 on pin out3 and set its frequency
              M106 P3 S1 H0 T60 C"Controller bay fan 2"
              M563 P0 D0 H1 F0                                 ; define tool 0
              G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
              G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
              M955 P121.0 I05
              ; Input shaper
              M593 P"ei2"  F48
              ; Pressure advance
              M572 D0 S0.095
              ; Calibration skew correction
              M556 S100 X0.542
              ; defines global variables
              M98 P"/macros/define_global_vars.g"
              ; Load override parameters
              M501
              T0
              ; Sets normal speeds and acceleration for printing operation
              M566 X300 Y300 Z240 E200           ; Set Jerk
              M203 X36000 Y36000 Z9600 E7200     ; Set maximum speeds (mm/min)
              M201 X10000 Y10000 Z700 E10000     ; Set maximum accelerations (mm/s^2)
              M204 P10000 T10000                 ; Set printing acceleration and travel accelerations
              botundefined 1 Reply Last reply Reply Quote 2
              • Argoundefined
                Argo @R4ffers
                @r4ffers
                PA 0.095 is quite high for direct drive setup.
                Do you also get incomplete infill lines if you increase PA further to get less bulging corners?
                R4ffersundefined 2 Replies Last reply Reply Quote 0
                • botundefined
                  bot @R4ffers
                  @r4ffers One thing I would try if I were you would be to increase the E jerk a little, and drastically decrease the E acceleration. You never need that much E accel. It becomes completely pointless -- essentially no E acceleration is ever applied because there are not enough steps to interpolate speeds across.
                  Try E Jerk 500 and E Accel 2500.
                  *not actually a robot
                  R4ffersundefined 1 Reply Last reply Reply Quote 1
                  • R4ffersundefined
                    R4ffers @Argo
                    @argo I've been messing around with it for the last week. I had it set at 0.055 previously. I have noticed zero change to PA when updated in config.g However I was tinkering earlier and when I change PA live using paneldue whilst printing it does have an effect. I got the corners not perfect but not too bad, updated config.g with new PA value. Ran the print again and back to crap corners again. It's almost like PA value in config.g is being ignored.
                    botundefined Argoundefined 2 Replies Last reply Reply Quote 0
                    • botundefined
                      bot @R4ffers
                      @r4ffers Make sure your slicer start gcode doesn't disable PA. Check every .g file on your SD card, too.
                      • R4ffersundefined
                        R4ffers @bot
                        @bot thanks, I've just updated that. I'll try another print in a mo.
                        • R4ffersundefined
                          R4ffers @bot
                          @bot ok good shout
                          • R4ffersundefined
                            R4ffers @bot
                            @bot said in Issues with pressure advance since RRF 3.4:
                            Can't see anything tha'ts disabling PA.
                            if I issue M572 D0 whilst printing I get PA0.095
                            • R4ffersundefined
                              R4ffers @Argo
                              @argo said in Issues with pressure advance since RRF 3.4:
                              @r4ffers
                              Doesn't seem to be
                              • botundefined
                                bot @R4ffers
                                @r4ffers Did you try this print with different E jerk/accel?
                                R4ffersundefined 1 Reply Last reply Reply Quote 0
                                • R4ffersundefined
                                  R4ffers @bot
                                  @bot yep. Made no change to the corners.
                                  • Argoundefined
                                    Argo @R4ffers
                                    @r4ffers
                                    So if you enter your PA value manually during a print - how do your corners then look?
                                    • R4ffersundefined
                                      R4ffers @Argo
                                      @argo I'll try a print tonight, I'm on call this week.
                                      • R4ffersundefined
                                        R4ffers @Argo
                                        @argo Hi, so started the print off issued M572 D0 to report current PA of 0.095. M572 D0 S0 to clear PA then issued M572 D0 S0.085. Issued M572 D0 to report current PA of 0.085. Here is the result.
                                        IMG_20221010_213816210.jpg IMG_20221010_213846075.jpg IMG_20221010_213855669.jpg
                                        Corners look miles better. I did notice the infill not quite reaching the internal perimeter in places.
                                        Also note the walls on the square top layer, PA is working when manually input during print and as expected with such a high value for direct extruder.
                                        Hope this helps.
                                        Argoundefined 2 Replies Last reply Reply Quote 1
                                        • Argoundefined
                                          Argo @R4ffers
                                          @r4ffers
                                          I’ll do the same test when I’m back from my business trip on Friday.
                                          Though PA is reporting the correct value you set it to 0 and again to the value it was before and it works?
                                          • R4ffersundefined
                                            R4ffers @Argo
                                            @argo I set it to zero 1st just to make sure it reported the change. In my config I had it set at 0.095 but I manually set it to 0.085. I'm fairly sure I used to have it set at 0.055, if I get chance tonight I'll try it at that and see what happens. I've looked through everything and can't find anything that would disable PA .
                                            It'll be interesting to see if your PA works manually.
