    Trouble with M201 and M566 settings
    2.4k
    • Jeredundefined
      Jered
      So I put the M566 to 0 and M201 to 10 and didn't notice any change. At this setting the machine should have never reach full speed. Right? The part is small.
      • Jeredundefined
        Jered @Norder
        @norder
        Should I be using the M205 command instead of the M566?
        Just found this on the internet.
        Or is just one command is different units?
        Norderundefined 2 Replies Last reply Reply Quote 0
        • Norderundefined
          Norder @Jered
          @jered
          I'm just a normal Duet user and not an expert on anything... although... 🤔
          I mean, I don't know every M command and M205 is new to me.
          I wonder... why ?
          You can easily convert mm/min to mm/s by simply dividing the value by 60.
          Although I like mm/s better because it gives me a better idea of ​​the speed.
          If I'm printing at 30mm/s or at 50mm/s then I can roughly guess when I see it.
          So judging by the description for the M205 command, it does the same thing as M566 just in a seconds format.
          I'm just wondering... is there also a mm/s command for the maximum speed (M203) which is also calculated in mm/min?
          And since the M203 command usually comes directly after the M566 command in the config.g, I ask myself... isn't that a trip on your own because you have two different formats one below the other?
          So nothing should change for you whether you enter M566 Z480 or M205 Z8 in config.g, because according to the description for the command, the result is the same.
          In the end it's more of a "matter of taste"!?
          Google Translate
          -- Original Text --
          Ich bin ja auch nur ein normaler Duet Nutzer und kein Experte von irgendwas... obwohl... 🤔
          Ich will damit sagen, ich kenne nicht jeden M Befehl und M205 ist für mich neu.
          Ich frage mich... wozu ?
          Denn mm/min kann man doch sehr einfach in mm/s umrechnen, dazu einfach nur den Wert durch 60 teilen.
          Obwohl mm/s mir besser gefällt, weil ich mir so die Geschwindigkeit besser vorstellen kann.
          Wenn ich mit 30mm/s drucke oder mit 50mm/s, dann kann ich das in etwa schätzen wenn ich es sehe.
          Also nach der Beschreibung für den Befehl M205 zu urteilen, macht er das gleiche wie M566 nur in einem Sekunden Format.
          Ich frage mich gerade... gibt es auch einen mm/s Befehl für die maximale Geschwindigkeit (M203) der ja auch in mm/min gerechnet wird ?
          Und da der M203 Befehl meistens direkt nach dem M566 Befehl in der config.g kommt, frage ich mich... stellt man sich so nicht selber ein Bein, weil man zwei unterschiedliche Formate untereinander stehen hat ?
          Demnach sollte sich also bei Dir nichts ändern, ob Du jetzt M566 Z480 oder M205 Z8 in die config.g einträgst, denn nach der Beschreibung für den Befehl ist das Ergebnis das gleiche.
          Am Ende ist es wohl eher eine "Geschmackssache" !?
          DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
          Thingiverse
          • Norderundefined
            Norder @Jered
            @jered said in Trouble with M201 and M566 settings:
            You write you have the command "found on the internet".
            For GCodes, you should use the GCodes for RepRap firmware, not any you find on the web.
            The following page lists and describes all of the GCodes for the Duet.
            If you come across a GCode on the net, then check what it does in a Duet and whether the Duet understands or knows it at all.
            Thingiverse
            • Jeredundefined
              Jered
              I am still not satisfied with the M201 command. I changed it to 1 and still I can not see any difference in performance. It appears that this setting does nothing. That being said, I need this to work.
              I have literally tried at least 50 different values for this setting and can not see that it is having an effect.
              To account for this setting not doing what I think it should, I have had to greatly reduce my print speed to 50mm/s to get a good quality of print.
              I am very bummed that this very expensive 3d printer is getting its ass kick by my cheap Ender 5 in quality of print.......
              If I make these same changes on my cnc machine, the difference is VERY noticable. But not here.
              deckingmanundefined Norderundefined 2 Replies Last reply Reply Quote 0
                How are you sending the command?
                Does your sliced gcode file include M201 commands from the slicer?
                If you send M201 by itself, what does it report the current values as?
                  deckingman @Jered
                  @Jered said in Trouble with M201 and M566 settings:
                  That's likely because your CNC machine does not have an extruder. Therefore it's only X and Y moves that need to be synchronised. Whereas your printer needs to have extruder moves start and end in sync with the X and Y axes moves. Because you have capped the speed of the extruder by having very low accelerations and instantaneous speeds, then the X and Y axes will be slowed to keep in sync with the (slow) extruder. So you can change X and Y as much as you like but unless you also raise the thresholds for "E", then in order to maintain synchronisation, the X and Y acceleration and jerk will be capped by the low extruder settings.
                  I explained all this to you in my earlier post.
                  • Norderundefined
                    Norder @Jered
                    @Jered
                    I already wrote to you in another thread that you should set the jerk values for Z and all extruders to 1200mm/min.
                    Because 6mm/min for Z and 120mm/min each for the extruder is too slow.
                    Please post...
                    • Your current config.g
                    • A GCode of a printed part.
                    • A screenshot of your printer settings in your slicer
                    This might help to solve your problem faster.
                    Google Translate
                    -- Original Text --
                    Ich hatte Dir in einem anderen Thread auch schon geschrieben dass Du die Jerk Werte für Z und alle Extruder auf 1200mm/min stellen solltest.
                    Denn 6mm/min für Z und je 120mm/min für die Extruder ist zu langsam.
                    Bitte poste...
                    • Deine aktuelle config.g
                    • Ein GCode eines Druckteil.
                    • Ein Screenshot Deiner Drucker Einstellungen in Deinem Slicer
                    Dieses könnte helfen Dein Problem schneller zu lösen.
                    Thingiverse
                    • Jeredundefined
                      Jered
                      I wonder if there is a problem with the M201 setting using the 1XD boards. I am using these boards for x y and z.
                        droftarts administrators @Jered
                        @Jered how are actually testing? With a Gcode file? Try testing manually. Set M201 for X and Y axis. Send a long G1 move, just in X and/or Y. Change M201 and repeat. This should show the effect of changing acceleration.
                        As others have already said, if you have mesh levelling or run the extruder at the same time, motor settings for them may affect the acceleration and speed of the X and Y axes, so test without these.
                        If you are sending a Gcode file to test, send M201 on its own to show current setting before it starts, and during, then you will know if the Gcode file is overriding the values you set.
                        Jeredundefined 1 Reply Last reply Reply Quote 0
                        • Jeredundefined
                          Jered @droftarts
                          @droftarts
                          I will check this. It will take me a while as a print is currently running.
                            You can send M201 by itself at any time and it will report the current values.
                            • Jeredundefined
                              Jered
                              I have been testing this with the latest version of Super Slicer (SS) as it allows more control over accel throughout the print than Simplify (which has none), and the results are, it is working. However, I am not sure why the machine is operating out of the config limits with Simplify.
                              In SS the accel is controlled per feature, and is changing all the time, which is nice.
                              However, it is weird that the Ender and the Vcore perform completely different with the same settings.
                              Ender accel is set at 500 mm/m and jerk is set to 10 mm/s. I change these to match in the Duet config, and it doesn't seem to matter about the accel, the jerk setting does seem to do something.
                              So having SS adjust the settings where I want them works, but the limiting factors in the config, for accel, do not seem to matter.
                              So I am guessing that changing them while a print is running would also work. But if I rely on the config alone, then my print suffers.
                              It still bothers me that I have to go through the extra leg work of using a different slicer to get the Duet to work, but with Enders cheap board, it does what I want without dictating everything the machine is doing through the slicer.
                              Any thoughts?
                              What slicer does Duet recommend?
                              Phaedruxundefined deckingmanundefined 3 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @Jered
                                Any thoughts?
                                @Phaedrux said in Trouble with M201 and M566 settings:
                                  I would guess that somewhere along the line the value is getting changed from what you have in your config.g to whatever value is in the sliced gcode file. y previous post has questions that would help determine if that's the case.
                                  Do you also happen to have an M204 command that sets print move and travel acceleration? M201 is the upper limit, but M204 can set it lower. Send M204 by itself in the console and see what it reports.
                                  And if you're still running with low jerk values on Z and E, it could be the limiting factor.
                                    deckingman @Jered
                                    Any thoughts?
                                    My only thoughts have to do with horses, water, and drinking.
                                    • Jeredundefined
                                      Jered
                                      Super Slicer adds an M204 500 command towards the beginning of the print. Simplify does not.
                                      But I did find only 1 instant of this command throughout the Super Slicer version of gcode.
                                      I will add that command into an existing Simplify gcode to see if it now behaves the same on the Vcore.
                                      • Jeredundefined
                                        Jered
                                        So I added that command at the beginning (M204 500) of my Simplify gcode and the Vcore is now behaving like the Ender.
                                        Not sure why the gcode would need this added to it when it is in the config. Maybe it is because I am using 1XD boards for my axis and somehow it is not being reported to those boards through the config.
                                        I guess this is also a non-issues as long as I know how to get around it. I will add this code to my gcode from now on.
                                        Just thought I would include my config:
                                        config (1).g
                                          What does M201 and M204 report on a fresh reboot?
                                          What do they report when running a simplify3d gcode file that doesn't have the added M204?
                                            config (1).g
                                            M566 X300.0 Y300.0 Z6.00 E120
                                            Your jerk values are still incredibly low. 6mm/min is 0.1mm per sec.
                                            120mm/min isn't much faster at 2mm per sec.
                                            Those will be a major limiting factor on the XY speeds, especially if you use mesh compensation that requires moving the Z axis in relation to XY position.
                                            I suggest you change Z jerk to at least 60, and E jerk to 3000
