    CR-10 with DuetWifi - updated with Bondtech exruder (3djake)
    My Duet controlled machine
    11
    26
    14.5k
    • Knaudlerundefined
      Knaudler
      Hello
      update:
      no (original Case)
      last night my CR-10 gets upgrade to DuetWifi
      first the Duet needs FW upgrade…via SD an PC...
      (comes with old FW)
      then I'm creating the config via reprap online config
      https://configurator.reprapfirmware.org/
      for Molex Connectors you need a Tool for Crimping
      looking amazon (DE): IZOKEE Crimpzange
      works good for this cheap tool
      the Duet fits into the original case of CR-10
      without Display - mounting duet board with ca. 3cm distance from case, for air flow
      using the 2 Case original case fans parallel
      (using PWM Fan Port 3 - needs other PWM Frequency ~ 30Hz on 40% - so duet remains below 30 degrees)
      for Bed using original Mosfet from CR-10
      raise up Voltage on Powersource to 14.4V - works
      (more Power 🙂 )
      first Test:
      I'm using demo config files for prusa from sd,
      then overwritten with data from config tool (zip)
      I need to switch direktion for x, y Motor
      Endstops working
      in Bed conf there was a failure with Z define 2mm to low - correctet to 0
      (I'm still work without autolevelling on CR1-10)
      using 16 microstepps with interpolation for x,y,z
      using 32 microstepps with interpolation for E
      Test…with 100mm/sec - silence !
      really silence - great
      now i can hear the bad chinese ball bearings !
      there is one bad bearing on Y
      the fans are the only loud sound
      very smooth printing
      and testet...150% works...200% works
      I let the printer print at 300mm/sec ! - with PLA
      (needs 230 degrees and 150% extrusion - not nice, but works with original Hotend)
      but up to 200mm/sec would be ok for Vase Mode
      my CR-10 mods:
      • Bed isolation - silcawool (stoutwind) 300x300
        (sealed with a lot of Kapton)
      • more Voltage - 14.4V
      • Fan Mod thingiverse : www.thingiverse.com/thing:2274499
        (bridging without any problems)
      • Case fans, Hotend fan and Parts cooling fan on PWM Ports
        (Hotend Fan working over 45 degrees)
      • BuildTak direct on ALU-heatbed (glass plate is too heavy for high speed)
      • extra Car Fuses for Board (10A) and Bed (30A)
      • CR-10 case and frame grounded
      files, config will be submitted later….
      Greetings from Hamburg
      Ingo
      update 25.7.18
      • Knaudlerundefined
        Knaudler
        here my config
        config.g
        ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
        ; generated by RepRapFirmware Configuration Tool on Sat Oct 28 2017 00:02:03 GMT+0200 (Mitteleuropäische Sommerzeit)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        G90 ; Send absolute coordinates…
        M555 P2 ; Set firmware compatibility to look like Marlin
        M208 X300 Y300 Z400 S0 ; Set axis maxima
        M574 X1 Y1 Z1 S1 ; Define active high microswitches
        M558 P0 X0 Y0 Z0 H5 F120 T12000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
        G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
        M557 X20:280 Y20:280 S20 ; Define mesh grid
        M569 P0 S0 ; Drive 0 goes backwards
        M569 P1 S0 ; Drive 1 goes backwards
        M569 P3 S0 ; Drive 3 goes backwards
        M92 X80 Y80 Z400 E99 ; Set steps per mm
        M350 E32 I1 ; Configure microstepping with interpolation
        M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
        M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
        M203 X30000 Y30000 Z600 E3000 ; Set maximum speeds (mm/min)
        M201 X500 Y500 Z100 E5000 ; Set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M143 S265 ; Set maximum heater temperature to 265C
        M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
        M563 P0 D0 H1 ; Define tool 0
        M550 PDuetWifi.lan.local ; Set machine name
        M552 S1 ; Enable network
        M587 S"SSID" P"PASSWORT" ; Configure access point. You can delete this line once connected
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M106 P0 S1 I0 F500 H1 T50 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P1 S0 I0 F30 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off - have 2 Blowers parallel
        M106 P2 S0.5 I0 F30 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off - have 2 Case Fans parallel
        ; Custom settings
        M912 P0 S-13 ; calibrate MCU Temp
        M501 ; with PID Tune data
        T0 ; Select first tool
        config-override.g
        M307 H0 A79.4 C307.3 D0.7 S1.00 B0
        M307 H1 A481.0 C126.3 D7.7 S1.00 B0
        homeall.g
        ; homeall.g
        ; called to home all axes
        ; Relative positioning
        G91
        ; Lift Z
        G1 Z5 F12000
        ; Course home X and Y
        G1 X-305 Y-305 F3600 S1
        ; Move away from the endstops
        G1 X10 Y10 F12000
        ; Fine home X and Y
        G1 X-305 Y-305 F360 S1
        ; Move Z down until the switch triggers
        G1 Z-405 F1800 S1
        ; Absolute positioning
        G90
        ; Tell the firmware where we are
        G92 Z0
        ; Uncomment the following line to lift the nozzle after probing
        G1 Z5 F200
        • Knaudlerundefined
          Knaudler
          works great - you only hear the fans
          in Vasemode - Vase 120mm diameter (but with edges)
          5-6sec / Layer
          • perolalarsundefined
            perolalars
            @igi0815
            Hi Ingo
            Sound great that you have good experiance of converting the cr-10 to duet board because I am thinking of doing the same.
            I havent recieved the printer yet but any day now (if not the swedish customs will grab it :-() . And have a duet wifi floating around somewhere…
            But I wonder did you use a paneldue for display or did you use the original display? And if so how did you set it up? If not does it work with a paneldue (4.3") in the original case?
            With the wifi, does it work through the case?
            Do your printer have dual z-axis steppers?
            many questions but would be happy for any input from you since you made this already!
            Cheers
            Per
            • Camalot977undefined
              Camalot977
              Works great on my CR-10-4
              Using the original case ,and like you , i raised the board about 30 mm for airflow.
              I did swap the original case fans for a single Noctura 60 mm fan , and that keeps it just aound 30 degrees .c
              I use the 5" PanelDue . And i must say i really love this setup . Really quiet printer now
              Thanks for a great job on this g code
                perolalars
                @Camalot977 Would you care to share your sys folder for the CR-10? I have been trying to use the reprap configuration tool but since I have not yet got my cr-10 4 printer I cant tell whats what…
                • totalitarianundefined
                  totalitarian
                  Works brilliantly. I had to turn down jerk a little but other than that, great job!
                  • Agniusmundefined
                    Agniusm
                    Great. I have my cr10 stript and most parts replaced. Do you know how to set bed offsets? My endstop is 38mm outside of the bed on X and i cant figure out how to set it so it moves 38mm after homing.
                      totalitarian
                      G31 I believe
                        @Agniusm:
                        Assuming it is an X-min endstop switch, use parameter X-38 in your M208 S1 command.
                        • Agniusmundefined
                          Agniusm
                          Does that goes into config or homex? I had it set like that in config.g but my carriage slammed into physical x stop
                            That goes in config.g. It defines both the minimum X value after homing, and the X position when an X min endstop switch is triggered during a homing move. It has nothing to do with whether the carriage stops when it triggers the endstop switch.
                              I understand from elsewhere that there are 2 very loud fans in the CR10 control box. With the Duet WiFi installed, you probably don't need both of them, and you should be able to substitute a quieter fan.
                              • stavrosgmtlundefined
                                stavrosgmtl
                                @perolalars:
                                A interested party here too my man. Excited to see this thing in action. My motor config on a late s4 is being a hassle
                                • Knaudlerundefined
                                  Knaudler
                                  Hello
                                  I had an home move, so long time nothing new
                                  some days ago I upgraded my CR-10
                                  new hardware upgrade:
                                  • a new Case für DuetWifi - there are a lot in thingiverse
                                    pla is better for wifi then metal case
                                  • powersource from Maas electronic or Alinco (for amateur radio)
                                    12-15V with 35 Amps - really quite - very good quality and stable power - and a lot more secure then cheap china powersource
                                  • CR-10 frame grounded
                                  • 4mm² for Heatbed
                                  • 2.5mm² for Duet
                                    (very smooth silicon cable)
                                  • drag chain on Heatbed
                                  • 100A- SSR (100DD) from Banggood (only 0.008 ohm)
                                  • 10A car fuse for Duet
                                  • 20A car fuse for Heatbed
                                  • Noctura fan für Duet case
                                  • FW .21rc (for smoother pressure advance - 0.2 on my cr-10)
                                  with 14.5V Heatbed needs 20A (cold)
                                  (only 0.155v voltage drop on SSR)
                                  now I'm testing FW retraction….
                                  (think the gcode substitution script would be the best)
                                  planned:
                                  • micro swiss nozzle
                                  • levelling with BLTouch...
                                    but when the heating bed is perfectly aligned, there is no need for a levelling - the cr-10 the frame is stable enough
                                  • dual extrusion
                                  • arduino smoke detector for security
                                  using S3D - but Cura (3.2) has a lot features now, maybe switching to cura or prusa slicer edition
                                  (repetier now can use prusa slicer)
                                  there are a lot updates on most slicers (nothing on S3D)
                                  so Duet is very great uprade for CR-10
                                  Ingo
                                  translated from german with deepl
                                  edit:
                                  only 30amps
                                  MAAS SPS-350-II
                                  rickypilnikundefined 1 Reply Last reply Reply Quote 0
                                  • Knaudlerundefined
                                    Knaudler
                                    @perolalars:
                                    @igi0815
                                    Hi Ingo
                                    Cheers
                                    Per
                                    Hello
                                    no Display, only Android Tablet via wifi, or Laptop
                                    • genexeneundefined
                                      genexene
                                      Thanks for sharing this valuable info. Your goodness is appreciated.
                                      Can you advise on the CR-10S, we have dual-Z screws, how would we configure for that? I'm new to board upgrades. Thanks for your help!
                                      zacklabelundefined 1 Reply Last reply Reply Quote 0
                                      • zacklabelundefined
                                        zacklabel @genexene
                                        @genexene said in CR-10 with DuetWifi (original Case):
                                        Same, what do we put for the second Z? M569 P5 S1 ; Drive 4 goes forwards?
                                        • rickypilnikundefined
                                          rickypilnik @Knaudler
                                          @knaudler Hi I was just wondering if you had finished your upgrades and so had a full set of configuration files with a bl-touch installed. I have been having a lot of trouble getting it set up and was wondering if you could share your files.
                                          Many Thanks.
                                          Knaudlerundefined 1 Reply Last reply Reply Quote 0
                                          • Knaudlerundefined
                                            Knaudler @rickypilnik
                                            @rickypilnik
                                            hi
                                            no BL Touch yet
                                            in works good without - once the bed is leveled fine - manuel
                                            it works
                                            I print some reinforcing brackets
                                            and screwed cr-10 on board (18mm Multiplex or Siebdruck)
                                            not screwed its glued on rubber bumper
                                            and the board on rubber
                                            I have to look for an holder for Chimera hotend, there I will then mount the bl-touch...
                                            but last weeks it was to hot in HH (28 grad in Room) to make anything with heat 🙂
                                            and maybe an Bondtech extruder...
