ERR_CONNECTION_TIMED_OUT
I am using duet3 6hc board.
I connected the micro 5-pin (USB) and lan cable to my laptop (window10)When transmitting M552
'Ethernet is enabled, configured IP address: 192.168.1.20, actual IP address: 192.168.1.20
comes outHowever, even if I type 192.168.1.20/ in the crome address bar,
on a white screen
Only "ERR_CONNECTION_TIMED_OUT" error occurs.
If anyone knows a solution, please help!!M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-9P63L-DJ3T8-6J1F8-3SJ6N-TB7BA Used output buffers: 1 of 40 (1 max) === RTOS === Static ram: 151000 Dynamic ram: 95716 of which 0 recycled Never used RAM 103956, free system stack 192 words Tasks: NETWORK(ready,27.4%,463) ETHERNET(notifyWait,0.0%,252) HEAT(notifyWait,0.0%,359) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,342) TMC(notifyWait,0.0%,104) MAIN(running,72.6%,1126) IDLE(ready,0.0%,30), total 100.0% Owned mutexes: USB(MAIN) === Platform === Last reset 00:20:01 ago, cause: power up Last software reset time unknown, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 103956, slot 1 Software reset code 0x0163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0xb6d9335c SP 0x20420048 Task NETW Freestk 576 ok Stack: 000104a8 00000000 0000786d a5a5a5bf 00000000 00424dbb 004258b2 81000000 2041f3d4 ffffff01 0000000e 00000054 20420e58 0000006d 00000000 02fba6e6 10000000 004297ab a5a5a5a5 0042980b a5a5a5a5 00484171 a5a5a5a5 a5a5a5a5 20437688 00000000 00000000 Error status: 0x00 Step timer max interval 144 MCU temperature: min 29.6, current 38.1, max 38.3 Supply voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0, over voltage events: 0, power good: no 12V rail voltage: min 0.1, current 0.1, max 0.2, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, mspos 0, reads 0, writes 0 timeouts 0 Driver 1: ok, SG min 0, mspos 0, reads 0, writes 0 timeouts 0 Driver 2: ok, SG min 0, mspos 0, reads 0, writes 0 timeouts 0 Driver 3: ok, SG min 0, mspos 0, reads 0, writes 0 timeouts 0 Driver 4: ok, SG min 0, mspos 0, reads 0, writes 0 timeouts 0 Driver 5: ok, SG min 0, mspos 0, reads 0, writes 0 timeouts 0 Date/time: 1970-01-01 00:00:00 Slowest loop: 4.08ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 3.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 10816, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 6010/0/0 Tx timeouts 0,0,6009,0,0,4805 last cancelled message type 4514 dest 127 === Network === Slowest loop: 0.17ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: active Error counts: 0 0 0 0 0 Socket states: 2 2 2 2 2 0 0 0 ok -
- Ethernet is shown as an unidentified network and
when checking for errors
"Ethernet's ip configuration is incorrect"
is indicated.
@Dennis_kim did you set an IP address on your computer as well? If you have a cable directly between the board and your computer then you will need to have a fixed IP address, in the same subnet, on your ethernet adaptor on the PC
How do I set the subnet prefix length?
I tried setting it to 24 and it still doesn't work.
subnet would need to be added as 255.255.255.0
@Phaedrux
already set
ip
subnet mask
gate way -
Are you able to ping the Duet IP address from your PC?
Also see this guide on setting up a direct ethernet connection.
https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
