BLTouch not communicating with my 3 mini
@53581
I tested my wires and they are good but I have not tried cleaning the board yet.
I have also test from different computer with no results. Thanks again.Also If the board is bad is there anybody that would repair it?
@Phaedrux
So I clean the board and above the lights on the board it pretty bad but it clean up very well and I could even tell anything was amiss when I was done. So what do I do from here just buy a new board or is there a way I can pinpoint it more? -
Is there something on the board that all I/O pins other than 5 and 6 have in common that could have fried?
If you had an oscilloscope you could check if the servo pin is sending out a signal.
Can you show some close up photos of the board?
I don't know what that chip is though.
Does my config look fine? -
Do you have a multimeter you can use to measure the resistance on R28?
@Phaedrux Yes I get 9.9 kΏ.
all right I did figure out this problem finally. the deploy probe file was messed up, I'm not sure how it slowly got worse and worse but is now working! I do have one more question however, I am geting this error and I do not know what's wrong does anyone here have answer?
thank you for your help! -
You'd have to share with us the macro
2_tests_completed
andconfig_default.g
The error message would make more sense in the context of those macros.
@53581 those are old board testing macros. You should not need to run them and can delete them.
Replace with a configuration from the config tool.
@T3P3Tony Ok, Thank you!
