    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    5.2k
    • CrazyCreatorundefined
      CrazyCreator @Falcounet
      @Falcounet
      in screen you see the pluginservice is running
      apparmor freshly installed
      http://www.crazycreatorcube.com
      • chrishammundefined
        chrishamm administrators @CrazyCreator
        @CrazyCreator I don't think this is an AppArmor issue, it's more likely that the permissions in your DWC directory are off for some reason. Try reinstalling duetwebcontrol and if that doesn't help, run sudo chown -R dsf.dsf /opt/dsf to fix the ownerships again. If that doesn't help, try to delete the file as root (sudo rm /opt/dsf/sd/www/js/...) and install the plugin once more.
        Duet software engineer
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
          CrazyCreator @chrishamm
          @chrishamm
          How can i reinstall or install DuetWebControl?
          I don't find any tutorial 😞
          /Update
          I upload this Zip-File: https://github.com/Duet3D/DuetWebControl/releases
          and hope this is what you mean, with reinstall DuetWebControl?
          i deleted all files with ExecOnMcode in name and try to reinstall the plugin
          ... But ... The same error 😞
            Why not start with a DuetPi image?
            CrazyCreatorundefined 1 Reply Last reply Reply Quote 1
              CrazyCreator @Phaedrux
              @Phaedrux actual duetpi image missing python3.9, but TAMV need this.
              Phaedruxundefined Falcounetundefined 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @CrazyCreator
                @CrazyCreator said in ExecOnMcode v0.1:
                missing python3.9
                https://itheo.tech/install-python-39-on-raspberry-pi
                  @Phaedrux
                  Maybe i try this, when @Falcounet & @chrishamm out of ideas 😄
                    @CrazyCreator Did you try the chown command I posted above? If that doesn't resolve it, try to run sudo rm /opt/dsf/**/ExecOnMcode* and then reinstall the plugin. It's odd you're getting that "access denied" error.
                    PS: The stock DuetPi image comes with the python 3 package, run sudo apt install python if you're missing it.
                    • Falcounetundefined
                      Falcounet @CrazyCreator
                      @CrazyCreator Can you give me a link to the system image you installed ?
                      I might give it a try on my pi.
                        @CrazyCreator TAMV is like 3 years old. I don't think python 3.9 was out at this time.
                        • stuartofmtundefined
                          stuartofmt
                          Jumping in here with a (possibly) relevant comment. If anyone intends to use Pi cameras: Consider using Debian Bullseye as the min base OS. There is a new library (from Pi) in Bullseye - so adopting this release will provide some future-proofing. It does not directly affect USB cameras but likely not a bad idea.
                            @chrishamm said in ExecOnMcode v0.1:
                            Yes ... try all your code-snippets ... now delete the directory and install the plugin again. but is the same error.
                            @Falcounet said in ExecOnMcode v0.1:
                            is the official image which come with the raspianimagebuilder
                            @stuartofmt said in ExecOnMcode v0.1:
                            TAMV has a new version
                            Now i test the DuetPi Image with update to bullseye
                            Falcounetundefined 1 Reply Last reply Reply Quote 0
                              @CrazyCreator So, I downloaded the image and following the steps I describe below, I could install the plugin without any issue.
                              1. Configure Wi-Fi and enable SSH in the advanced options of RaspberryPi Imager (Can be done by creating wpa_supplicant.conf and ssh files in boot partition)
                              2. Run sudo raspi-config and go to "Interface options", "SPI" to enable the SPI interface
                              3. Add Duet APT sources + GPG key : sudo wget -q https://pkg.duet3d.com/duet3d.gpg -O /etc/apt/trusted.gpg.d/duet3d.gpg && sudo wget -q https://pkg.duet3d.com/duet3d.list -O /etc/apt/sources.list.d/duet3d.list && sudo apt update
                              4. Install Duet packages + Apparmor: sudo apt install apparmor duetsoftwareframework duetpluginservice duetpimanagementplugin
                              5. Enable services : sudo systemctl enable duetcontrolserver duetwebserver duetpluginservice duetpluginservice-root
                              6. Reboot : sudo reboot
                              7. Install ExecOnMcode from DWC external plugins tab
                                @Falcounet
                                Which version did you load, 32bit or 64bit?
                                  @CrazyCreator 32bits comes to default so I took that one
                                    @Falcounet
                                    what you think, should i try 64bit? make it a difference for the plugin? i think not?
                                      @CrazyCreator I believe it will work the same but it is up to you. For the plugin itself, it won't make a difference.
                                        @Falcounet
                                        After your step 3 i have to make
                                        sudo apt upgrade?
                                          @CrazyCreator Actually I didn't added that but yes, upgrading system packages would be a good thing
                                            @Falcounet
                                            install is running now ... i have to wait
