    Spindle ON/OFF and speed control issues Duet 3
    CNC
    1.7k
    • Nightowlundefined
      Nightowl @peteupshall
      @peteupshall
      Good answer!
      It doesn't have the probe window, but I haven't progressed that far, yet! Just one step at a time, for me 😊
      There is a spindle speed control on the Dashboard screen, though.
      To be honest, I tried the WB interface but couldn't get my head around it, and there should be improvements for CNC users with the 3.5 update from Duet, so I'm hanging my hat on that - for now.
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      • Nightowlundefined
        @peteupshall
        Not spindle control, no. I did provide a link on your other post, which should have been of use to you, though?
        peteupshallundefined 1 Reply Last reply Reply Quote 0
        • peteupshallundefined
          peteupshall @Nightowl
          @Nightowl Yes I tried all the suggestions but I just cant get it to work as expected.
          Thanks for all your help though.
            jay_s_uk @peteupshall
            @peteupshall you'll need a second output then from another heater output to the FWD connection on the VFD and then add it to the M950 e.g.
            M950 R0 C"OUT_9+out8"
              peteupshall @jay_s_uk
              @jay_s_uk Do I need to use some sort of relay?
              What voltage and settings would i need to provide to FWD from Duet?
                @peteupshall no, just a wire between the negative of the output to the fwd connector
                  @jay_s_uk Have tried Gnd on pin out 6 to FOR
                  Changed M950 R0 C"out9+out6" L0:24000 Q1000
                  Also tried to put directly into config.g but still no spindle start or stop.
                  Checking again with RUN button on VFD reactivated and I have speed control and sort of a stop control M5 but it just reduces to 500rpm not a complete stop.
                  Any further ideas?
                    @peteupshall just checked my wiring and I also have a wire between the + of the heater output and DCM on the top row.
                    some more info can be found here https://wiki.printnc.info/en/electronics/vfd/config#h-0-5v
                      @jay_s_uk So So close now. I now have spindle on and off and speed control via web control and gcode .
                      The only thing still not working is M5- Stop. When M5 is activated the spindle drops to about 500rpm, although VFD still shows 12000rpm, and stays there.
                      Is there a minimum RPM setting somewhere?
                      Thanks for your support so far you have been awesome!
                        peteupshall @peteupshall
                        Also just noticed that as I have to press STOP on the VFD to stop spindle I then can't restart using Web Control or Gcode.
                        Also when set at 12000rpm on web control it shows just over 13500rpm on VFD. Is this just a case of fine tuning the 0-10v converter?
                          @peteupshall yes, it just a case of adjusting the screw on the PWM converter.
                          You need to set the minimum RPM in M950. I think the spindle I have has a minimum RPM of 6000
                            @jay_s_uk Minimum rpm is currently set to 0, should it be something else then?
                              @peteupshall yes. more than likely there will be a minimum RPM that your spindle can work at, set it to that
                              peteupshallundefined Nightowlundefined 2 Replies Last reply Reply Quote 0
                                @jay_s_uk Minimum RPM on specs is 0 but have tried it at 600 but still the same.
                                If I adjust the 12000rpm it knocks the 24000rpm which is spot on, would it be an innacuracy with the 0-10v converter?
                                • Nightowlundefined
                                  Nightowl @jay_s_uk
                                  @jay_s_uk
                                  That might depend on the milling motor or spindle.
                                  I (now) know the Sorotec and Mafell have a minimum speed of 4,000RPM, but the AMB/Kress does go down to 0.
                                  I'm not sure about water/air-cooled spindles, though.
                                    jay_s_uk @Nightowl
                                    @Nightowl mines a water cooled one. no idea what spindle is being used here
                                    peteupshallundefined 1 Reply Last reply Reply Quote 1
                                      @jay_s_uk Hi 1.5kw aircooled spindle
                                        @peteupshall itll probably have the same minimum RPM as mine then, so 6000
                                          @jay_s_uk Still no joy. Set it to 6000 and M5 still wont make it stop. Tearing my hair out now as I cant get my head arround whats going on. Could it be a VFD setting?
                                            Sorted it and dancing around the workshop .
                                            Looked at all the frequency settings on VFD and noticed that PD011 was set to 200.00. Set it to factory 0 and it all works.
                                            Thanks so much for all your help. This forum is invaluable.
                                            • dc42undefined dc42 marked this topic as a question
                                            • dc42undefined dc42 has marked this topic as solved
