    Only probe where the part will be printed
    Gcode meta commands
    2.3k
    • danym21undefined
      danym21 @Proschi3D
      @Proschi78
      Hi, I use SuperSlicer, but I think in prusa Slicer it should also work.
      in my startcode I added this line:
      M557 X{first_layer_print_min[0]}:{first_layer_print_max[0]} Y{first_layer_print_min[1]}:{first_layer_print_max[1]}
      maybe this will help you too.
      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
      • Proschi3Dundefined
        Proschi3D @danym21
        @danym21 Error: in GCode file line 182 column 7: M221: expected number after 'S'
        Extruder pressure advance: 0.065, 0.000
        Error: in file macro line 8 column 8: M557: unknown value 'first_layer_print_min^'
        can you give me your whole start code ?
        and mesh.g ?
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
        danym21undefined 1 Reply Last reply Reply Quote 0
        • danym21undefined
          danym21 @Proschi3D
          @Proschi78
          start G-Code:
          G90 ; use absolute coordinates
          ;M83  ; extruder relative mode
          ;BED_MESH_CALIBRATE AREA_START={first_layer_print_min[0]},{first_layer_print_min[1]} AREA_END={first_layer_print_max[0]},{first_layer_print_max[1]}
          ;MINX:{first_layer_print_min[0]}
          ;MINY:{first_layer_print_min[1]}
          ;MAXX:{first_layer_print_max[0]}
          ;MAXY:{first_layer_print_max[1]}
          M82 ; absolute extrusion mode
          M104 S140 T0
          M140 S[first_layer_bed_temperature] ; set bed temp
          M190 S[first_layer_bed_temperature] ; wait for bed temp
          G32 ; home all
          G1 X-14 Y-10 F10000
          ; Reset speed and extrusion rates
          M200 D0 ; disable volumetric e
          M220 S100 ; reset speed
          M221 S100 D0 ; reset extrusion rate
          M109 S{first_layer_temperature[initial_extruder]+extruder_temperature_offset[initial_extruder]} ; wait for extruder temp
          G92 E0.0
          ;G1 X150.0 E20  F1000.0 ; intro line
          G1 E20  F1000.0 ; intro line
          G1 X0.0 Y0.0 Z0.1 F1000.0 ; go outside print area
          ;G1 X5 Y0
          G92 E0.0
          G1 X2 Y2 Z0.2 E0 F18000 ; new
          G1 X60 Y2 E9.0 F1800 ;intro Line
          ;G1 X200.0 E30 F500 ; second Part intro Line
          G92 E0.0
          G1 Z5 E-{retract_length[0]} F{retract_speed *60}
          G1 X{first_layer_print_min[0]} Y{first_layer_print_min[1]} Z{first_layer_height} F30000
          G1 E{retract_length[0]} F{retract_speed*60}
          G92 E0.0
          I do not use a mesh.g this does not exists on my system
          my bed.g:
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 09 2020 01:08:02 GMT+0100 (Mitteleuropäische Normalzeit)
          G4 P100
          G28 ; home
          G0 Z10 F4200
          G0 F60000
          G30 P0 X5 Y155 Z-99999						;Orbiter
          G30 P1 X302 Y155 Z-99999 S2					;Orbiter
          G91 										;Relative positioning
          G1 Z5 F1500 								;Raise Z 5mm
          G90 										;Absolute positioning
          G0 X45 Y-5 F60000
          G29 										;Probe the heatbed and generate heightmap
          G4 P100
          G0 X0 Y0 F60000 						;Go to Parking Position
          some settings in config.g that maybe relevant for:
          M671 X-52:377 Y155:155 S2.5 					   ; leadscrews at left (connected to Z) and right
          M557 X10:300 Y10:300 P6:6; S40                     ; define mesh grid ( the normal full size mesh config)
          Proschi3Dundefined 2 Replies Last reply Reply Quote 1
            Proschi3D @danym21
            jetzt gehts 🙂
            now it works 🙂
            • danym21undefined
              danym21 @Proschi3D
              @Proschi78
              Proschi3Dundefined 1 Reply Last reply Reply Quote 1
                Proschi3D @danym21
                @danym21 Do you also have start codes for other slicers?
                • danym21undefined
                  danym21 @Proschi3D
                  @Proschi78
                  no, sorry
                  but on S3d maybe have a look to this variables:
                  I do not know what is in, but you can test with a smal object and check then the gcode file
                  [build_size_x]
                  [build_size_y]
                  [build_size_z]
                  [next_position_x]
                  [next_position_y]
                  [next_position_z]
                  they are mentioned here:
                  https://community.ultimaker.com/topic/11328-simplify3d-hidden-undocumented-placeholders-for-post-processing-scripts/
                    Proschi3D @danym21
                    @danym21 thanks I'll test that tomorrow
                      Proschi3D @danym21
                      @danym21 said in Only probe where the part will be printed:
                      @Proschi78
                      start G-Code:
                      M104 S140 T0
                      G32 ; home all
                      G1 X-14 Y-10 F10000
                      G92 E0.0
                      ;G1 X5 Y0
                      G92 E0.0
                      G92 E0.0
                      G92 E0.0
                      my bed.g:
                      ; bed.g
                      G4 P100
                      G28 ; home
                      G0 Z10 F4200
                      G0 F60000
                      G0 X45 Y-5 F60000
                      G4 P100
                      what can I do with this start code so that it is probing in mesh like A5 in normal mesh?
                      Best off five ?
                      • danym21undefined
                        danym21 @Proschi3D
                        @Proschi78 said in Only probe where the part will be printed:
                        ke A5 in no
                        the A5 needs to be in the config.g where you configure the probe type
                        look for M558
                        https://docs.duet3d.com/User_manual/Reference/Gcodes#m558-set-z-probe-type
                          Proschi3D @danym21
                          @danym21
                          I know that and I also have it in the config.g
                          but if I start a print and it only creates the mesh where the printed part is, then it only runs once in z
                          M558 P1 C"io3.in" H5 A5 S0.009 F150 T6000                           ; set Z probe type to unmodulated and the dive height + speeds
                          G31 P500 X0 Y0 Z1.730; set Z probe trigger value, offset and trigger height
                          M557 X30:330 Y-3:210 P9
                          • danym21undefined
                            danym21 @Proschi3D
                            @Proschi78
                            mhm, this makes no sense for me, do you have a M558 on some other positions? like in the the bed.g or config-override.g?
                            I will test this when I have time for, I normaly use only one probe per point.
                            • mherundefined
                              mher
                              Just want to share the solution I made for this a couple of months ago (posted here)
                              as well.
                              It works with PrusaSlicer/SuperSlicer, Cura and Ideamaker. Instructions are included as well.
                              https://github.com/MaikoHermans/RRF-PAM
                                Proschi3D
                                Has anyone managed to do it with simplify v5?
                                IndeX4Dundefined 1 Reply Last reply Reply Quote 0
                                • jay_s_ukundefined jay_s_uk referenced this topic
                                • System referenced this topic
                                • Phaedruxundefined Phaedrux referenced this topic
                                • Phaedruxundefined Phaedrux pinned this topic
                                • Phaedruxundefined Phaedrux moved this topic from Tuning and tweaking
                                • IndeX4Dundefined
                                  IndeX4D @Proschi3D
                                  @Proschi78
                                  I would like to know the same 🙂
