    Only probe where the part will be printed
    Gcode meta commands
    2.3k
    • Proschi3Dundefined
      Proschi3D @danym21
      @danym21 Error: in GCode file line 182 column 7: M221: expected number after 'S'
      Extruder pressure advance: 0.065, 0.000
      Error: in file macro line 8 column 8: M557: unknown value 'first_layer_print_min^'
      can you give me your whole start code ?
      and mesh.g ?
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      danym21undefined 1 Reply Last reply Reply Quote 0
      • danym21undefined
        danym21 @Proschi3D
        @Proschi78
        start G-Code:
        G90 ; use absolute coordinates
        ;M83  ; extruder relative mode
        ;BED_MESH_CALIBRATE AREA_START={first_layer_print_min[0]},{first_layer_print_min[1]} AREA_END={first_layer_print_max[0]},{first_layer_print_max[1]}
        ;MINX:{first_layer_print_min[0]}
        ;MINY:{first_layer_print_min[1]}
        ;MAXX:{first_layer_print_max[0]}
        ;MAXY:{first_layer_print_max[1]}
        M557 X{first_layer_print_min[0]}:{first_layer_print_max[0]} Y{first_layer_print_min[1]}:{first_layer_print_max[1]}
        M82 ; absolute extrusion mode
        M104 S140 T0
        M140 S[first_layer_bed_temperature] ; set bed temp
        M190 S[first_layer_bed_temperature] ; wait for bed temp
        G32 ; home all
        G1 X-14 Y-10 F10000
        ; Reset speed and extrusion rates
        M200 D0 ; disable volumetric e
        M220 S100 ; reset speed
        M221 S100 D0 ; reset extrusion rate
        M109 S{first_layer_temperature[initial_extruder]+extruder_temperature_offset[initial_extruder]} ; wait for extruder temp
        G92 E0.0
        ;G1 X150.0 E20  F1000.0 ; intro line
        G1 E20  F1000.0 ; intro line
        G1 X0.0 Y0.0 Z0.1 F1000.0 ; go outside print area
        ;G1 X5 Y0
        G92 E0.0
        G1 X2 Y2 Z0.2 E0 F18000 ; new
        G1 X60 Y2 E9.0 F1800 ;intro Line
        ;G1 X200.0 E30 F500 ; second Part intro Line
        G92 E0.0
        G1 Z5 E-{retract_length[0]} F{retract_speed *60}
        G1 X{first_layer_print_min[0]} Y{first_layer_print_min[1]} Z{first_layer_height} F30000
        G1 E{retract_length[0]} F{retract_speed*60}
        G92 E0.0
        I do not use a mesh.g this does not exists on my system
        my bed.g:
        ; bed.g
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 09 2020 01:08:02 GMT+0100 (Mitteleuropäische Normalzeit)
        G4 P100
        G28 ; home
        G0 Z10 F4200
        G0 F60000
        G30 P0 X5 Y155 Z-99999						;Orbiter
        G30 P1 X302 Y155 Z-99999 S2					;Orbiter
        G91 										;Relative positioning
        G1 Z5 F1500 								;Raise Z 5mm
        G90 										;Absolute positioning
        G0 X45 Y-5 F60000
        G29 										;Probe the heatbed and generate heightmap
        G4 P100
        G0 X0 Y0 F60000 						;Go to Parking Position
        some settings in config.g that maybe relevant for:
        M671 X-52:377 Y155:155 S2.5 					   ; leadscrews at left (connected to Z) and right
        M557 X10:300 Y10:300 P6:6; S40                     ; define mesh grid ( the normal full size mesh config)
        Proschi3Dundefined 2 Replies Last reply Reply Quote 1
          Proschi3D @danym21
          jetzt gehts 🙂
          now it works 🙂
          • danym21undefined
            danym21 @Proschi3D
            @Proschi78
            Proschi3Dundefined 1 Reply Last reply Reply Quote 1
              Proschi3D @danym21
              @danym21 Do you also have start codes for other slicers?
              • danym21undefined
                danym21 @Proschi3D
                @Proschi78
                no, sorry
                but on S3d maybe have a look to this variables:
                I do not know what is in, but you can test with a smal object and check then the gcode file
                [build_size_x]
                [build_size_y]
                [build_size_z]
                [next_position_x]
                [next_position_y]
                [next_position_z]
                they are mentioned here:
                https://community.ultimaker.com/topic/11328-simplify3d-hidden-undocumented-placeholders-for-post-processing-scripts/
                  Proschi3D @danym21
                  @danym21 thanks I'll test that tomorrow
                    Proschi3D @danym21
                    @danym21 said in Only probe where the part will be printed:
                    @Proschi78
                    start G-Code:
                    M104 S140 T0
                    G32 ; home all
                    G1 X-14 Y-10 F10000
                    G92 E0.0
                    ;G1 X5 Y0
                    G92 E0.0
                    G92 E0.0
                    G92 E0.0
                    my bed.g:
                    ; bed.g
                    G4 P100
                    G28 ; home
                    G0 Z10 F4200
                    G0 F60000
                    G0 X45 Y-5 F60000
                    G4 P100
                    what can I do with this start code so that it is probing in mesh like A5 in normal mesh?
                    Best off five ?
                    • danym21undefined
                      danym21 @Proschi3D
                      @Proschi78 said in Only probe where the part will be printed:
                      ke A5 in no
                      the A5 needs to be in the config.g where you configure the probe type
                      look for M558
                      https://docs.duet3d.com/User_manual/Reference/Gcodes#m558-set-z-probe-type
                      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                        Proschi3D @danym21
                        @danym21
                        I know that and I also have it in the config.g
                        but if I start a print and it only creates the mesh where the printed part is, then it only runs once in z
                        M558 P1 C"io3.in" H5 A5 S0.009 F150 T6000                           ; set Z probe type to unmodulated and the dive height + speeds
                        G31 P500 X0 Y0 Z1.730; set Z probe trigger value, offset and trigger height
                        M557 X30:330 Y-3:210 P9
                        • danym21undefined
                          danym21 @Proschi3D
                          @Proschi78
                          mhm, this makes no sense for me, do you have a M558 on some other positions? like in the the bed.g or config-override.g?
                          I will test this when I have time for, I normaly use only one probe per point.
                          • mherundefined
                            mher
                            Just want to share the solution I made for this a couple of months ago (posted here)
                            as well.
                            It works with PrusaSlicer/SuperSlicer, Cura and Ideamaker. Instructions are included as well.
                            https://github.com/MaikoHermans/RRF-PAM
                              Proschi3D
                              Has anyone managed to do it with simplify v5?
                              IndeX4Dundefined 1 Reply Last reply Reply Quote 0
                              • jay_s_ukundefined jay_s_uk referenced this topic
                              • System referenced this topic
                              • Phaedruxundefined Phaedrux referenced this topic
                              • Phaedruxundefined Phaedrux pinned this topic
                              • Phaedruxundefined Phaedrux moved this topic from Tuning and tweaking
                              • IndeX4Dundefined
                                IndeX4D @Proschi3D
                                @Proschi78
                                I would like to know the same 🙂
