    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    5.9k
    • CrazyCreatorundefined
      CrazyCreator @Falcounet
      @Falcounet
      Just installed the v0.2 over the v0.1 ... worked without any problems.
      Which is impractical, my created commands are gone now 😉
      http://www.crazycreatorcube.com
      Falcounetundefined 1 Reply Last reply Reply Quote 0
      • Falcounetundefined
        Falcounet @CrazyCreator
        @CrazyCreator I think there is something wrong with the plugin reloading after upgrade.
        I just tried and the config file is still there in sd/sys/ExecOnMcode/ExecOnMcode.json after plugin upgrade.
        The plugin was in "desactivated" mode. A stop and a start on the plugin fixed it.
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
          @Falcounet strange but right
            CrazyCreator
            @Falcounet
            I think you must make a little update in your plugin 😉
            • Garth_42undefined
              Garth_42 @Falcounet
              I am having trouble installing the newest version on my Duet3. I am getting the following error:
              dsf-python is installed on the RPI. Pip3 is recognized in the terminal when I enter "pip3".
              Here is an output of M122:
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
              Board ID: 08DJM-956BA-NA3TJ-6JTDA-3S06M-9U8GS
              Used output buffers: 1 of 40 (13 max)
              Static ram: 152760
              Dynamic ram: 67548 of which 204 recycled
              Never used RAM 130160, free system stack 200 words
              Tasks: SBC(ready,0.5%,446) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.6%,91) MAIN(running,91.8%,923) IDLE(ready,0.0%,30), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 01:16:51 ago, cause: software
              Last software reset at 2022-05-29 08:42, reason: User, GCodes spinning, available RAM 132740, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              Error status: 0x00
              Step timer max interval 134
              MCU temperature: min 25.1, current 27.1, max 27.2
              Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min 0, mspos 8, reads 15144, writes 15 timeouts 0
              Driver 1: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
              Driver 2: standstill, SG min 0, mspos 8, reads 15144, writes 16 timeouts 0
              Driver 3: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
              Driver 4: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
              Driver 5: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
              Date/time: 2022-12-28 21:41:46
              Slowest loop: 1.48ms; fastest: 0.04ms
              === Storage ===
              Free file entries: 10
              DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC* is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty
              === CAN ===
              Messages queued 41489, received 36956, lost 0, boc 0
              Longest wait 1ms for reply type 6042, peak Tx sync delay 386, free buffers 50 (min 49), ts 23058/23057/0
              Tx timeouts 0,0,0,0,0,0
              === SBC interface ===
              Transfer state: 5, failed transfers: 0, checksum errors: 0
              RX/TX seq numbers: 23547/23547
              SPI underruns 0, overruns 0
              State: 5, disconnects: 5, timeouts: 5 total, 5 by SBC, IAP RAM available 0x2ad20
              Buffer RX/TX: 0/0-0, open files: 0
              === Duet Control Server ===
              Duet Control Server v3.4.5
              Code buffer space: 4096
              Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
              Full transfers per second: 38.22, max time between full transfers: 66.3ms, max pin wait times: 60.9ms/3.9ms
              Codes per second: 0.00
              Maximum length of RX/TX data transfers: 3195/64
              Let me know if I can help with resolving this issue with any more information.
                Falcounet @Garth_42
                @Garth_42 Are you using the DuetPi image ?
                What does sudo find / -name pip3 returns (in a terminal on the SBC) ?
                Garth_42undefined 1 Reply Last reply Reply Quote 0
                • Garth_42undefined
                  Garth_42 @Falcounet
                  @Falcounet thanks for getting back to me. I am using the DuetPi image.
                  Here is the result when I SSH into the RPI as the root account.
                    Falcounet @Garth_42
                    @Garth_42 Not sure why pip3 is installed at a different location as you are using the DuetPi image.
                    You have to change the pip path in the DSF config which is stored at /opt/dsf/conf/plugins.json
                    This command should do the trick :
                    sed -i -e 's|"InstallPythonPackageCommand": .*,|"InstallPythonPackageCommand": "/usr/local/bin/pip3",|g' /opt/dsf/conf/plugins.json
                    Then reboot the SBC and try to install the plugin again.
                    CrazyCreatorundefined Garth_42undefined 2 Replies Last reply Reply Quote 0
                      @Falcounet Any update available, for use the plugin in newest beta RRF 3.5.0-b1
                        @CrazyCreator No, it seems there is an issue with the plugin installation (related to the SBC permissions required by the plugin) so I'm waiting Christian to come back from holidays.
                          @Falcounet Ahh ... Ok ... Then we wait together 😉
                          • Garth_42undefined
                            Garth_42 @Falcounet
                            @Falcounet thanks for this. I am not sure either, as I haven't done anything at the command line on the RPI that would have modified my pip installation. It installed and is working now! Thank you very much.
                              CrazyCreator
                              @Falcounet
                              I found your v_0.3 on GitHub ... But when i try to Install, i see no PopUp with Installroutine.
                                @CrazyCreator That version is still for 3.4 and it installs fine here.
                                  @Falcounet
                                  I thought it was already for the latest 3.5... Because you just released it.
                                  Is there a beta version to test?
                                    @CrazyCreator The issue has been fixed in DWC 3.5b2 so I will release a beta version for 3.5 only when 3.5b2 will be released.
                                      Falcounet
                                      ExecOnMcode v0.4 has been released.
                                      This version is still for 3.4 versions of DWC, starting from 3.4.5.
                                      Changes :
                                      • Append m-code parameters as command arguments (Thanks @brendon !)
                                      • Remove the flush option (Custom G-Code should always flush the code channel)
                                      • Use the DWC connector to make HTTP request
                                      • File architecture has been changed so the build_plugin script also bundles dsf and sd files
                                        @Falcounet
                                        A little side info:
                                        If try to install the new version from github (the 0.4) ... Only for test as well.
                                        I move the zip-file with drag&drop to the Button (Install Plugin) in DWC ... but nothing.
                                        I know is the wrong version, i wrote only for info.
                                          @CrazyCreator As said earlier, there is an issue related to the plugin permissions in 3.5b1 and it will be fixed in 3.5b2.
                                          There is no point trying to install the plugin targeting version 3.4.5 in version 3.5 of DWC.
                                            @Falcounet
                                            i know ... just for info 😉 All fine
