    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    5.2k
    • Falcounetundefined
      Falcounet @CrazyCreator
      @CrazyCreator I think what you need is BtnCmd plugin but i'm not sure what you need exactly
      CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
      • CrazyCreatorundefined
        CrazyCreator @Falcounet
        @Falcounet
        I would like to send an http command to my network when the printer has finished printing.
        The command I wrote here turns off the smart socket and thus the printer.
        I think is anything with curl or so ...
        @BtnCmd: What is this and what can is do for me?
        http://www.crazycreatorcube.com
        Falcounetundefined 1 Reply Last reply Reply Quote 0
          @CrazyCreator You can try adding a M1203 command doing curl http://192.168.1.45/relay/0?turn=off and then adding M1203 to your end-gcode.
            @Falcounet said in ExecOnMcode v0.1:
              @CrazyCreator The error comes from the relay you are trying to drive. I would suggest you to open a thread for your issue as it is not directly related to this plugin. Thanks
              To add a bit more details, I think you have either to be identified or to allow an IP address from your network to send this command.
                @Falcounet
                maybe the switch need a password or so ... but in the old execonmcode script the same switch worked, without errors. i will see, maybe everyone have a idea what i can try.
                thanks
                  @CrazyCreator As said, open a thread and give a bit more informations about your setup (what kind of relay, etc ...)
                  The 401 HTTP Error comes from this device so if it was working with the old execonmcode, I believe it is either because the config has changed, you were using another url or so.
                  CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                    @Falcounet
                    thanks for the hints ... i try tomorrow any thinks and then make a new thread.
                    Or maybe BtnCmd can help me
                    • stuartofmtundefined stuartofmt referenced this topic
                      @Falcounet
                      It works now 🙂
                      Solution for others reading here:
                      The shelly 1 switch had a password-protected web interface. So it didn't work.
                      Without a password I now get a warning in ioBroker, but it works for now 😉
                        Falcounet
                        ExecOnMcode V0.2 is released.
                        No plugin improvements has been added on that version.
                        Only change is the module imports to use dsf-python v3.4.5
                        See https://forum.duet3d.com/topic/30761/dsf-python-3-4-5-released for more details
                        CrazyCreatorundefined Garth_42undefined 2 Replies Last reply Reply Quote 1
                          @Falcounet
                          Just installed the v0.2 over the v0.1 ... worked without any problems.
                          Which is impractical, my created commands are gone now 😉
                            @CrazyCreator I think there is something wrong with the plugin reloading after upgrade.
                            I just tried and the config file is still there in sd/sys/ExecOnMcode/ExecOnMcode.json after plugin upgrade.
                            The plugin was in "desactivated" mode. A stop and a start on the plugin fixed it.
                              @Falcounet strange but right
                                CrazyCreator
                                @Falcounet
                                I think you must make a little update in your plugin 😉
                                • Garth_42undefined
                                  Garth_42 @Falcounet
                                  I am having trouble installing the newest version on my Duet3. I am getting the following error:
                                  dsf-python is installed on the RPI. Pip3 is recognized in the terminal when I enter "pip3".
                                  Here is an output of M122:
                                  M122
                                  RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
                                  Board ID: 08DJM-956BA-NA3TJ-6JTDA-3S06M-9U8GS
                                  Used output buffers: 1 of 40 (13 max)
                                  Static ram: 152760
                                  Dynamic ram: 67548 of which 204 recycled
                                  Never used RAM 130160, free system stack 200 words
                                  Tasks: SBC(ready,0.5%,446) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.6%,91) MAIN(running,91.8%,923) IDLE(ready,0.0%,30), total 100.0%
                                  Owned mutexes: HTTP(MAIN)
                                  Last reset 01:16:51 ago, cause: software
                                  Last software reset at 2022-05-29 08:42, reason: User, GCodes spinning, available RAM 132740, slot 1
                                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                  Error status: 0x00
                                  Step timer max interval 134
                                  MCU temperature: min 25.1, current 27.1, max 27.2
                                  Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                  12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                                  Events: 0 queued, 0 completed
                                  Driver 0: standstill, SG min 0, mspos 8, reads 15144, writes 15 timeouts 0
                                  Driver 1: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                  Driver 2: standstill, SG min 0, mspos 8, reads 15144, writes 16 timeouts 0
                                  Driver 3: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                  Driver 4: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                  Driver 5: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                  Date/time: 2022-12-28 21:41:46
                                  Slowest loop: 1.48ms; fastest: 0.04ms
                                  === Storage ===
                                  Free file entries: 10
                                  DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                  Segments left: 0
                                  Movement lock held by null
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  SBC* is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Aux2 is idle in state(s) 0
                                  Code queue is empty
                                  === CAN ===
                                  Messages queued 41489, received 36956, lost 0, boc 0
                                  Longest wait 1ms for reply type 6042, peak Tx sync delay 386, free buffers 50 (min 49), ts 23058/23057/0
                                  Tx timeouts 0,0,0,0,0,0
                                  === SBC interface ===
                                  Transfer state: 5, failed transfers: 0, checksum errors: 0
                                  RX/TX seq numbers: 23547/23547
                                  SPI underruns 0, overruns 0
                                  State: 5, disconnects: 5, timeouts: 5 total, 5 by SBC, IAP RAM available 0x2ad20
                                  Buffer RX/TX: 0/0-0, open files: 0
                                  === Duet Control Server ===
                                  Duet Control Server v3.4.5
                                  Code buffer space: 4096
                                  Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                  Full transfers per second: 38.22, max time between full transfers: 66.3ms, max pin wait times: 60.9ms/3.9ms
                                  Codes per second: 0.00
                                  Maximum length of RX/TX data transfers: 3195/64
                                  Let me know if I can help with resolving this issue with any more information.
                                    Falcounet @Garth_42
                                    @Garth_42 Are you using the DuetPi image ?
                                    What does sudo find / -name pip3 returns (in a terminal on the SBC) ?
                                    Garth_42undefined 1 Reply Last reply Reply Quote 0
                                    • Garth_42undefined
                                      Garth_42 @Falcounet
                                      @Falcounet thanks for getting back to me. I am using the DuetPi image.
                                      Here is the result when I SSH into the RPI as the root account.
                                        Falcounet @Garth_42
                                        @Garth_42 Not sure why pip3 is installed at a different location as you are using the DuetPi image.
                                        You have to change the pip path in the DSF config which is stored at /opt/dsf/conf/plugins.json
                                        This command should do the trick :
                                        sed -i -e 's|"InstallPythonPackageCommand": .*,|"InstallPythonPackageCommand": "/usr/local/bin/pip3",|g' /opt/dsf/conf/plugins.json
                                        Then reboot the SBC and try to install the plugin again.
                                        CrazyCreatorundefined Garth_42undefined 2 Replies Last reply Reply Quote 0
                                          @Falcounet Any update available, for use the plugin in newest beta RRF 3.5.0-b1
                                            @CrazyCreator No, it seems there is an issue with the plugin installation (related to the SBC permissions required by the plugin) so I'm waiting Christian to come back from holidays.
