    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    5.9k
    • Falcounetundefined
      Falcounet @CrazyCreator
      @CrazyCreator As said, open a thread and give a bit more informations about your setup (what kind of relay, etc ...)
      The 401 HTTP Error comes from this device so if it was working with the old execonmcode, I believe it is either because the config has changed, you were using another url or so.
      CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
      • CrazyCreatorundefined
        CrazyCreator @Falcounet
        @Falcounet
        thanks for the hints ... i try tomorrow any thinks and then make a new thread.
        Or maybe BtnCmd can help me
        http://www.crazycreatorcube.com
        • stuartofmtundefined stuartofmt referenced this topic
          @Falcounet
          It works now 🙂
          Solution for others reading here:
          The shelly 1 switch had a password-protected web interface. So it didn't work.
          Without a password I now get a warning in ioBroker, but it works for now 😉
            Falcounet
            ExecOnMcode V0.2 is released.
            No plugin improvements has been added on that version.
            Only change is the module imports to use dsf-python v3.4.5
            See https://forum.duet3d.com/topic/30761/dsf-python-3-4-5-released for more details
            CrazyCreatorundefined Garth_42undefined 2 Replies Last reply Reply Quote 1
              @Falcounet
              Just installed the v0.2 over the v0.1 ... worked without any problems.
              Which is impractical, my created commands are gone now 😉
              Falcounetundefined 1 Reply Last reply Reply Quote 0
                @CrazyCreator I think there is something wrong with the plugin reloading after upgrade.
                I just tried and the config file is still there in sd/sys/ExecOnMcode/ExecOnMcode.json after plugin upgrade.
                The plugin was in "desactivated" mode. A stop and a start on the plugin fixed it.
                CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                  @Falcounet strange but right
                    CrazyCreator
                    @Falcounet
                    I think you must make a little update in your plugin 😉
                    • Garth_42undefined
                      Garth_42 @Falcounet
                      I am having trouble installing the newest version on my Duet3. I am getting the following error:
                      dsf-python is installed on the RPI. Pip3 is recognized in the terminal when I enter "pip3".
                      Here is an output of M122:
                      M122
                      RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
                      Board ID: 08DJM-956BA-NA3TJ-6JTDA-3S06M-9U8GS
                      Used output buffers: 1 of 40 (13 max)
                      Static ram: 152760
                      Dynamic ram: 67548 of which 204 recycled
                      Never used RAM 130160, free system stack 200 words
                      Tasks: SBC(ready,0.5%,446) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.6%,91) MAIN(running,91.8%,923) IDLE(ready,0.0%,30), total 100.0%
                      Owned mutexes: HTTP(MAIN)
                      Last reset 01:16:51 ago, cause: software
                      Last software reset at 2022-05-29 08:42, reason: User, GCodes spinning, available RAM 132740, slot 1
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                      Error status: 0x00
                      Step timer max interval 134
                      MCU temperature: min 25.1, current 27.1, max 27.2
                      Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                      12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                      Events: 0 queued, 0 completed
                      Driver 0: standstill, SG min 0, mspos 8, reads 15144, writes 15 timeouts 0
                      Driver 1: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                      Driver 2: standstill, SG min 0, mspos 8, reads 15144, writes 16 timeouts 0
                      Driver 3: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                      Driver 4: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                      Driver 5: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                      Date/time: 2022-12-28 21:41:46
                      Slowest loop: 1.48ms; fastest: 0.04ms
                      === Storage ===
                      Free file entries: 10
                      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                      === MainDDARing ===
                      === AuxDDARing ===
                      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                      Segments left: 0
                      Movement lock held by null
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC* is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Aux2 is idle in state(s) 0
                      Code queue is empty
                      === CAN ===
                      Messages queued 41489, received 36956, lost 0, boc 0
                      Longest wait 1ms for reply type 6042, peak Tx sync delay 386, free buffers 50 (min 49), ts 23058/23057/0
                      Tx timeouts 0,0,0,0,0,0
                      === SBC interface ===
                      Transfer state: 5, failed transfers: 0, checksum errors: 0
                      RX/TX seq numbers: 23547/23547
                      SPI underruns 0, overruns 0
                      State: 5, disconnects: 5, timeouts: 5 total, 5 by SBC, IAP RAM available 0x2ad20
                      Buffer RX/TX: 0/0-0, open files: 0
                      === Duet Control Server ===
                      Duet Control Server v3.4.5
                      Code buffer space: 4096
                      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                      Full transfers per second: 38.22, max time between full transfers: 66.3ms, max pin wait times: 60.9ms/3.9ms
                      Codes per second: 0.00
                      Maximum length of RX/TX data transfers: 3195/64
                      Let me know if I can help with resolving this issue with any more information.
                        Falcounet @Garth_42
                        @Garth_42 Are you using the DuetPi image ?
                        What does sudo find / -name pip3 returns (in a terminal on the SBC) ?
                        Garth_42undefined 1 Reply Last reply Reply Quote 0
                        • Garth_42undefined
                          Garth_42 @Falcounet
                          @Falcounet thanks for getting back to me. I am using the DuetPi image.
                          Here is the result when I SSH into the RPI as the root account.
                            Falcounet @Garth_42
                            @Garth_42 Not sure why pip3 is installed at a different location as you are using the DuetPi image.
                            You have to change the pip path in the DSF config which is stored at /opt/dsf/conf/plugins.json
                            This command should do the trick :
                            sed -i -e 's|"InstallPythonPackageCommand": .*,|"InstallPythonPackageCommand": "/usr/local/bin/pip3",|g' /opt/dsf/conf/plugins.json
                            Then reboot the SBC and try to install the plugin again.
                            CrazyCreatorundefined Garth_42undefined 2 Replies Last reply Reply Quote 0
                              @Falcounet Any update available, for use the plugin in newest beta RRF 3.5.0-b1
                                @CrazyCreator No, it seems there is an issue with the plugin installation (related to the SBC permissions required by the plugin) so I'm waiting Christian to come back from holidays.
                                  @Falcounet Ahh ... Ok ... Then we wait together 😉
                                  • Garth_42undefined
                                    Garth_42 @Falcounet
                                    @Falcounet thanks for this. I am not sure either, as I haven't done anything at the command line on the RPI that would have modified my pip installation. It installed and is working now! Thank you very much.
                                      CrazyCreator
                                      @Falcounet
                                      I found your v_0.3 on GitHub ... But when i try to Install, i see no PopUp with Installroutine.
                                        @CrazyCreator That version is still for 3.4 and it installs fine here.
                                          @Falcounet
                                          I thought it was already for the latest 3.5... Because you just released it.
                                          Is there a beta version to test?
                                            @CrazyCreator The issue has been fixed in DWC 3.5b2 so I will release a beta version for 3.5 only when 3.5b2 will be released.
