    Software bundle 3.5beta1 released
    Beta Firmware
    11
    19
    1.4k
      jay_s_uk @Exerqtor
      @Exerqtor maybe try the full file path? I.e. 0:/sys/homey.g
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @jay_s_uk
        @jay_s_uk said in Software bundle 3.5beta1 released:
        0:/sys/homey.g
        That returns Error: in file macro line 65 column 16: meta command: expected ')' so I have no idea what I'm doing wrongšŸ˜…
        If I try /sys/homey.g I get this error X Y steppers at 100% of max current! Error: in file macro line 65 column 15: meta command: expected an expression.
        And with sys/homey.g I get Error: in file macro line 65 column 15: meta command: unknown value 'sys'
        jay_s_ukundefined Sindariusundefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @Exerqtor
          @Exerqtor you may need to encase it in ` or "
          Exerqtorundefined 1 Reply Last reply Reply Quote 2
          • Sindariusundefined
            Sindarius @Exerqtor
            @Exerqtor you probably need to quote the file name so it is a string
            ā€œ0:/sys/homey.gā€
            Looks like @jay_s_uk beat me to it šŸ˜„
            • Exerqtorundefined
              Exerqtor @jay_s_uk
              @Sindarius said in Software bundle 3.5beta1 released:
              Yup, that sure worked!
              Edit:
              Don't need the full filepath either, since it's on 0:/sys/ it works with just the filename, and above that you only need /sys/foldername/ if it's located in 0:/ 🤘
              MaxGyverundefined 1 Reply Last reply Reply Quote 1
              • MaxGyverundefined
                MaxGyver @Exerqtor
                I have noticed two minor things after updating:
                • G10 without L parameter will cause my macros to get stuck
                • M569.1 without an E parameter defined will trigger a warning/error
                Thanks to the Team for all your hard work!
                • chernogorskyundefined
                  chernogorsky
                  Create a separate ticket. Movement issue + some minors
                    dc42 administrators @MaxGyver
                    @MaxGyver said in Software bundle 3.5beta1 released:
                    Please start a separate thread about this. In particular, show the G10 command(s) you are using.
                    Please see the upgrade notes.
                      dc42 administrators @dc42
                      A bug in the 3.5beta 1 main board files has come to light. The bug causes a reset or other odd behaviour if the G32 command is used to perform true bed levelling on a machine with multiple Z motors.
                      I have now identified the cause and fixed this issue. New main board binary files containing the fix are available at https://www.dropbox.com/sh/28zqy8t165nwa2f/AACZvmVSGhWMSpjKX43MsSWSa?dl=0. A few other changes have been made in these builds, see https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-350beta2-in-preparation for details.
                      Note, these main board binaries have received minimal testing; however the changes since version 3.5beta1 are small.
                      A Former User? 1 Reply Last reply Reply Quote 3
                        A Former User @dc42
                        This post is deleted!
                          chernogorsky
                          To anyone like me stacked with SBC and 3.5
                          my way of resotoring stable version (after changing /etc/apt. ... to stable)
                          sudo apt install duetcontrolserver/stable duetpimanagementplugin/stable duetpluginservice/stable duetsd/stable duetsoftwareframework/stable duettools/stable duetwebcontrol/stable duetwebserver/stable reprapfirmware/stable duetruntime/stable
                          • dc42undefined dc42 referenced this topic
                          • MaxGyverundefined MaxGyver referenced this topic
                            dc42 administrators @Nightowl
                            @Nightowl said in Software bundle 3.5beta1 released:
                            Just out of curiosity @dc42, did you manage to implement any improvements for Power Loss/Resume for CNC machines, please?
                            It was a while ago, but we discussed it here.
                            Yes, commands to restore the spindle speed and direction are now included in resurrect.g.
                            • T3P3Tonyundefined T3P3Tony referenced this topic
