    Software bundle 3.5beta1 released
    Beta Firmware
    11
    19
    1.4k
      T3P3Tony administrators @CNCModeller
      @CNCModeller no testing done on Polar machines so if yours is working properly with 3.4.x and you are prepared to take the plunge then you feedback will be welcome!
        dc42 administrators @CNCModeller
        @CNCModeller no, we don't have any polar machines to test on. However we have made very few changes to the kinematics classes, and we have tested 3.5beta1 with other nonlinear kinematics such as Delta.
        • Nightowlundefined
          Nightowl
          Just out of curiosity @dc42, did you manage to implement any improvements for Power Loss/Resume for CNC machines, please?
          It was a while ago, but we discussed it here.
          Thank you.
          Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
          I'm still on my learning curve, so take everything I say with caution!
          RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
          • mikeabuilderundefined
            mikeabuilder
            Sweet! Have a great holiday, Duet folks. And thanks for your solid work on RRF. Much appreciated.
            • Exerqtorundefined
              Exerqtor @dc42
              Trying out some of the new stuff and i can't seem to get the fileexists function to work.
              Just to try it out i added this at the end of homey.g:
              if fileexists(homey.g)
                echo "fileexists works"
              When i run the macro i get this error:
              Error: in file macro line 65 column 15: meta command: unknown value 'homey.g'
                jay_s_uk @Exerqtor
                @Exerqtor maybe try the full file path? I.e. 0:/sys/homey.g
                Exerqtorundefined 1 Reply Last reply Reply Quote 0
                • Exerqtorundefined
                  Exerqtor @jay_s_uk
                  @jay_s_uk said in Software bundle 3.5beta1 released:
                  0:/sys/homey.g
                  That returns Error: in file macro line 65 column 16: meta command: expected ')' so I have no idea what I'm doing wrongšŸ˜…
                  If I try /sys/homey.g I get this error X Y steppers at 100% of max current! Error: in file macro line 65 column 15: meta command: expected an expression.
                  And with sys/homey.g I get Error: in file macro line 65 column 15: meta command: unknown value 'sys'
                  jay_s_ukundefined Sindariusundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @Exerqtor
                    @Exerqtor you may need to encase it in ` or "
                    Exerqtorundefined 1 Reply Last reply Reply Quote 2
                    • Sindariusundefined
                      Sindarius @Exerqtor
                      @Exerqtor you probably need to quote the file name so it is a string
                      ā€œ0:/sys/homey.gā€
                      Looks like @jay_s_uk beat me to it šŸ˜„
                      • Exerqtorundefined
                        Exerqtor @jay_s_uk
                        @Sindarius said in Software bundle 3.5beta1 released:
                        Yup, that sure worked!
                        Edit:
                        Don't need the full filepath either, since it's on 0:/sys/ it works with just the filename, and above that you only need /sys/foldername/ if it's located in 0:/ 🤘
                        MaxGyverundefined 1 Reply Last reply Reply Quote 1
                        • MaxGyverundefined
                          MaxGyver @Exerqtor
                          I have noticed two minor things after updating:
                          • G10 without L parameter will cause my macros to get stuck
                          • M569.1 without an E parameter defined will trigger a warning/error
                          Thanks to the Team for all your hard work!
                          • chernogorskyundefined
                            chernogorsky
                            Create a separate ticket. Movement issue + some minors
                              dc42 administrators @MaxGyver
                              @MaxGyver said in Software bundle 3.5beta1 released:
                              Please start a separate thread about this. In particular, show the G10 command(s) you are using.
                              Please see the upgrade notes.
                                dc42 administrators @dc42
                                A bug in the 3.5beta 1 main board files has come to light. The bug causes a reset or other odd behaviour if the G32 command is used to perform true bed levelling on a machine with multiple Z motors.
                                I have now identified the cause and fixed this issue. New main board binary files containing the fix are available at https://www.dropbox.com/sh/28zqy8t165nwa2f/AACZvmVSGhWMSpjKX43MsSWSa?dl=0. A few other changes have been made in these builds, see https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-350beta2-in-preparation for details.
                                Note, these main board binaries have received minimal testing; however the changes since version 3.5beta1 are small.
                                A Former User? 1 Reply Last reply Reply Quote 3
                                  A Former User @dc42
                                  This post is deleted!
                                    chernogorsky
                                    To anyone like me stacked with SBC and 3.5
                                    my way of resotoring stable version (after changing /etc/apt. ... to stable)
                                    sudo apt install duetcontrolserver/stable duetpimanagementplugin/stable duetpluginservice/stable duetsd/stable duetsoftwareframework/stable duettools/stable duetwebcontrol/stable duetwebserver/stable reprapfirmware/stable duetruntime/stable
                                    • dc42undefined dc42 referenced this topic
                                    • MaxGyverundefined MaxGyver referenced this topic
                                      dc42 administrators @Nightowl
                                      @Nightowl said in Software bundle 3.5beta1 released:
                                      Yes, commands to restore the spindle speed and direction are now included in resurrect.g.
                                      • T3P3Tonyundefined T3P3Tony referenced this topic
