    Duet Mini 5 BTT MAX31865 Issue
    479
      jay_s_uk @wayneosdias
      @wayneosdias can you be a bit more explicit about what pins you've connected together?
      wayneosdiasundefined 1 Reply Last reply Reply Quote 0
      • wayneosdiasundefined
        wayneosdias @jay_s_uk
        @jay_s_uk Sure, referencing the MAX31865 pcb numbered a classic dip and the Duet 'TEMP DAUGHTER' header as a header the connections are;
        MAX / Duet
        1 NC / -
        2 SDI / 5 MOSI
        3 CLK / 4 SCK
        4 CS / 1 CS2 or 3CS1
        5 SDO / 6 MISO
        6 NC / -
        7 NC / -
        8 NC / -
        9 GND / 2 GND
        10 V_IN / 8 +3.3V
        11 FORCE- common to 12 RTDIN- / -
        13 RTDIN+ common to 14 FORCE+ / -
        15 GND / -
        16 NC / -
          @wayneosdias how do you have the dip switches set?
          where are you connecting the PT100 to?
          FYI, you'll also have to add R430 to the M308 line as it uses a different sense resistor than the one expected by the firmware by default
            @jay_s_uk
            The default switches as I recd it was
            Off, Off, Off, On
            which was odd as the sensor they supply with the board is a two-wire sensor.
            I changed it
            On, On, On, Off
            Doing so shorts RT+ to Force+ and RT- to Force-
            The sensor is wired directly to RT+ to one leg of the sensor and RT- to the other leg.
            Re the M308 R430, Thanks for the tip 😉
              dc42 administrators @wayneosdias
              @wayneosdias how long are the wires between the Duet daughterboard connector and the MAX31865 board?
                wayneosdias @dc42
                @dc42 For bench testing just using breadboard jumpers, ~5"
                wayneosdiasundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  wayneosdias @wayneosdias
                  @wayneosdias I also just checked that GND Pins 9 and 15 of the MAX pcb are common to each other. Im only using one for GND to the Mini.
                    @wayneosdias I can't see anything wrong with your description of how you have wired it; and 5" of wire should not be a problem.
                    What message if any do you get when you send the M308 command?
                      wayneosdias @dc42
                      So thats interesting, does this point to a config problem? havnt changed anything in the config which still is; (sans network settings)
                      ; Configuration file for Duet 3 Mini 5+
                      G90                                          ; send absolute coordinates...
                      M83                                          ; ...but relative extruder moves
                      M550 P"Ender 3 Pro"                          ; set printer name
                      ;M918 P1 E4 F2000000                          ; configure direct-connect display
                      ;M918 P2 E4 F2000000 ; configure direct-connect display
                      ;M150 X2 R255 U255 B255 S3 ; set all 3 LEDs to white
                      M575 P1 S2 B57600
                      M569 P0 S1 D3 V40							;X0
                      M569 P1 S1 D3 V40                           ;Y0
                      M569 P2 S0 D3 V40                           ;Z0
                      M569 P3 S0 D3 V40                           ;Z1
                      M569 P4 S1 D3 V40                           ;E0
                      M584 X0 Y1 Z2:3 E4                     		;set drive mapping
                      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z400.00 E424.90             ; set steps per mm
                      M566 X1200.00 Y1200.00 Z400.00 E300.00        ; set maximum instantaneous speed changes (mm/min)
                      M203 X9000.00 Y9000.00 Z200.00 E6000.00      ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z100.00 E5000.00        ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E1000 I50                ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                      ; Set idle timeout
                      M208 X0 Y0 Z0 S1                             ; set axis minima
                      M208 X235 Y235 Z215 S0                       ; set axis maxima
                      M574 X1 S1 P"io6.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in
                      M574 Y1 S1 P"io5.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in
                      ;M574 Z1 S1 P"io2.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
                      M950 S0 C"io3.out"                           ; create servo pin 0 for BLTouch
                      M558 P9 C"io3.in" H5 F120 T6000              ; set Z probe type to bltouch and the dive height + speeds
                      G31 P1000 X-32 Y-41 Z1                      ; set Z probe trigger value, offset and trigger height
                      M557 X30:190 Y30:190 S20                       ; define mesh grid
                      M308 S0 P"temp0" Y"thermistor" T100000 B4092 A"Bed"; configure sensor 0 as thermistor on pin temp0
                      M950 H0 C"out6" T0                           ; create bed heater output on out0 and map it to sensor 0
                      ;M307 H0 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
                      ;M307 H0 R1.012 K0.345:0.000 D4.32 E1.35 S1.00 B0
                      M307 H0 R1.071 K0.348:0.000 D3.57 E1.35 S1.00 B0
                      M140 H0                                      ; map heated bed to heater 0
                      M143 H0 S150     ; set temperature limit for heater 0 to 150C
                      ;Old for thermister
                      ;M308 S1 P"temp1" Y"thermistor" T10000 B4092 ; configure sensor 1 as thermistor on pin temp1
                      ;M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
                      ;New for PT100
                      M308 S1 P"spi.cs1" Y"rtd-max31865"
                      M950 H1 C"out1" T1 ; create heater 1 and map sensor 1
                      ;M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
                      ;M307 H1 R3.416 K0.428:0.000 D10.54 E1.35 S1.00 B0 V23.9
                      ;M307 H1 R3.288 K0.436:0.000 D11.30 E1.35 S1.00 B0 V23.9
                      ;M307 H1 R3.209 K0.313:0.000 D11.51 E1.35 S1.00 B0 V23.9
                      M307 H1 R2.907 K0.303:0.000 D12.84 E1.35 S1.00 B0 V23.9
                      M143 H1 S275                                 ; set temperature limit for heater 1 to 275C
                      M950 F0 C"out3" Q1000                         ; create fan 0 on pin out3 and set its frequency
                      M106 P0 C"PartCool" S0 H-1                   ; set fan 0 name and value. Thermostatic control is turned off
                      ;M950 F1 C"out4" Q1000                         ; create fan 1 on pin out4 and set its frequency
                      ;M106 P1 C"HotEnd" S1 H1 T45                  ; set fan 1 name and value. Thermostatic control is turned on
                      M950 F2 C"out5" Q500                         ; create fan 2 on pin out5 and set its frequency
                      M106 P2 C"CaseFan" S1 H1:0 T30                ; set fan 2 name and value. Thermostatic control is turned on M106 P2 C"CaseFan" S1 H1:0 T45
                      M950 F3 C"out6" Q500                         ; create fan 3 on pin out6 and set its frequency
                      M106 P3 C"LEDs" S1 H-1                       ; set fan 3 name and value. Thermostatic control is turned off
                      M563 P0 D0 H1 F0
                      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
                      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
                      T0         ; select first tool
                      gloomyandyundefined 1 Reply Last reply Reply Quote 0
                      • gloomyandyundefined
                        gloomyandy @wayneosdias
                        @wayneosdias Try running the M308 command for S1 in the console and see if you get any sort of error reported.
                          wayneosdias @gloomyandy
                          @gloomyandy
                          Same as above
                            wayneosdias
                            Is there a simple way to test spi on a Duet board? Before pulling out my scope I just put a cheap logic analyzer on CS1 CS2 CLK MOSI and MISO ref'd to ground and no activity. The CS1 CS2 MOSI are logic high as you would expect, and I see no activity either triggered or free running.
                            Is there anyway to force spi comms to verify HW working?
                              @wayneosdias I meant for you to sent the command:
                              or using spi.cs2 if that is how it is connected at present.
                                wayneosdias @dc42
                                Ok got comms sorted. I got this initially
                                Looks like the MISO line isnt pulled up locally on the the BTT board. I guess this makes sense as the board is meant to plug into 'step stick port' on a BTT driver board. In all the literature I read from BTT/Biqu makes no mention of pullups or active line jumpering. Any way pulled the MISO line up to 3V via 10k and now I get the following;
                                DWC is also reporting semi resonable values so now just some tuning and firmer wiring to get the ball rolling. I have a Duet PT100 dtr board coming from filastruda and I dont think ill have it for a week. I also ordered an Adafruit MAX31865 bob that should be here tomorrow so Ill follow up this thread on how that gos.
                                Huge thanks for this Forum and support, the best 🙂
                                • wayneosdiasundefined wayneosdias marked this topic as a question
                                • wayneosdiasundefined wayneosdias has marked this topic as solved
