setup needed for 6 extruders 5 feed 1 for direct drive
@run-it to confirm you have multiple tools, each configured with their own motor. + an additional motor that you want to run whenever any of the tool are running?
is the additional motor setup as another extruder, or as a movement axis?
If its another extruder motor then an idea that comes to mind would be to map it as a second extruder, with the appropriate mixing ratio. and then use the tool change macros to un map, and remap the extruder motors each time the tool changes.
all the extruders running with the tool I change to only using 5 and I have 6th open for a direct drive I would like it to run in tandem with each chosen tool
That sounds good would you and the filament gods have the code to do this? and what can I do to help out
I was hoping that I could just put in my m563 D0:1 for T1 and D0:2 for T 2 and so on but did not work but did come up on wed interface next to extrude I tried setting up mix m567 p0 E1:1:0:0:0:0 for T0 m567 p1 E1:0:1:0:0:0 for T1 and so on. if I hit mix no joy if I highlight the two e buttons I get what I want but switching drops the highlighted buttons I know this is what your telling me right
@T3P3Tony I was hoping that I could just put in my m563 D0:1 for T1 and D0:2 for T 2 and so on but did not work but did come up on wed interface next to extrude I tried setting up mix m567 p0 E1:1:0:0:0:0 for T0 m567 p1 E1:0:1:0:0:0 for T1 and so on. if I hit mix no joy if I highlight the two e buttons I get what I want but switching drops the highlighted buttons I know this is what you're telling me right? so do I put the tool assignment code in the tool change? ie m563 D0:1 for T1. and I didn't know if I should text back here or on page reply
@run-it It would be less confusing if the drive which runs in tandem with the 5 extruders was designated as driver 5. Then your tool definitions for the 5 extruders (0 to 4) would look like this. T0 D0:5, T1 D1:5, T2 D2:5 etc. For drive 5 to to run in tandem, then you must define the mixing ratio for every tool as 1:1. You only need to set the mixing ratio for the drives that are assigned to tools, hence you only need 1:1 but you must use that for each and every tool.
@deckingman sounds great I will give this a shot. I will post the results. thank you for your time in helping me and others. catch ya later happy printing
@run-it Hello again I am very happy to say it's working thank you so much.
here's a pic of my changes for those who want to try this.
have a great day. -
@T3P3Tony out of curiosity what would the macro look like for the filaments retract and tool change ? because him thinking doing like Op but with only 2 tool , going to a Y filaments guide to a single extruder.
@Dad003 Hi I think you could try looking up m701 load filament and m702 unload the filament and see if that will meet your needs.
I am going to try to set up the load to a switch or filament sensor. ie encoder. but I see I may have a problem with that because I use the web interface to load files not the sd card. and I found this in the g code directory (For all firmware versions, note that filament monitoring in RRF is only active when printing from SD card.) so this is kinda a drag if it is a true statement for today's firmware. -
@run-it said in setup needed for 6 extruders 5 feed 1 for direct drive:
The web interface uploads the file to the local SD card, so you have no issue.
@Phaedrux Awesome thank you
