    Advanced nozzle design
    3D Printing General Chat
    15
    48
    4.9k
    • plasticfactoryundefined
      plasticfactory @CCS86
      @ccs86 Yeah, I definitely see that -- good eye. I probably got too excited with the last post, but the other images, coupled with this, are promising. I will refrain from making conclusions until we get a proper inspection next week.
        plasticfactory
        Disclaimer: A sample size of 1 is not enough to draw distinct conclusions. Everything I am sharing are simply preliminary results and I will do many prints/inspections before making any clear statements of capability.
        Based on user CCS86's suggestion, we performed another straightness test with more data points:
        Slight reduction, but ~12% "straighter". Eventually we will do more thorough inspections on this. I was considering using our extrusion measurement systems to test it not on a print, but in line (like a normal plastic extruder).
        Next up are simple stringing tests, pictured here:
        ADV Left, V6 Right
        These prints were done on the same hardware, with same the same Gcode file. Both prints were done with no retraction. Prusament PLA, 200*, 15mm/s print, 180mm/s travel.
        Clearly, the ADV oozes considerably less, almost none at all. I do notice "fuzz" on the edges, and what appears to be occasional heat dissipation issues from the ADV nozzle. I suspect this is due to the end taper geometry not being correct for a V6 0.4 orifice nozzle (as mentioned by another user earlier in the thread). The next step is to EDM or surface grind this taper to the correct geometry to eliminate this as a variable. Nozzle taper comparison below:
        I very much welcome feedback!
        HebigTundefined Darth Scoobundefined 2 Replies Last reply Reply Quote 5
        • HebigTundefined
          HebigT @plasticfactory
          This post is deleted!
          • Darth Scoobundefined
            Darth Scoob @plasticfactory
            @plasticfactory the base of the stringing test with the ADV nozzle appears much smoother/flatter than the other one. Is it just the picture or can you see a difference as well? On a side note, earlier in the thread you said you have a toolchanger, how has that turned out? It seems like a very solid system to base a printer on.
            Edit: I has a other idea for a test you could run, idk if this is what you mean in an earlier post, but I will ask anyway. When you calibrate linear advance on Marlin it extrudes multiple lines with varying speed, teaching tech has an excellent video on how it works if you don't know what I mean (though I would guess you do, you seem quite experienced with 3d printing), but I wonder if the ADV nozzle would offer improved properties in this 'test'. I could see the flow properties allowing changes in speed that should be synced with the extruder (I think firmware does this but I'm not sure) to require less compensation in this test. Another example of this sort of test is the Bambu Labs X1 auto/self calibration function.
            Edit 2: I think the larger diameter of the nozzle tip would unnecesarily heat the plastic, requiring aditional cooling to compensate. All of the cheap nozzles I have also have larger tip diameters and seem to perform worse it that area.
            MrDuiundefined plasticfactoryundefined 2 Replies Last reply Reply Quote 1
            • MrDuiundefined
              MrDui @Darth Scoob
              Very interesting and pretty cool tools you got there!
              What about maximum flow comparison between both nozzles?
              HebigTundefined 1 Reply Last reply Reply Quote 1
              • HebigTundefined
                HebigT @MrDui
                @mrdui I'm curious about this too. I wonder if the longer orifice creates significantly more pressure loss due to friction compared to a standard V6.
                deckingmanundefined 1 Reply Last reply Reply Quote 1
                  deckingman @HebigT
                  @hebigt said in Advanced nozzle design:
                  I would say that's highly likely (although not necessary just due to friction). Based on my own exploits into multi-input hot ends, something like a Diamond which has about 2mm final orifice length needs an immense amount of pressure advance compensation but has very little tendency to ooze and requires only a little retraction length on top of the PA compensation. But my own design which uses "standard" M6 threaded nozzles and thus a much shorter final orifice length, requires hardly any pressure advance compensation but has a much higher tendency to ooze and requires much higher retraction length values. The nozzle diameter, filament and temperature in both cases being the same.
                    plasticfactory @Darth Scoob
                    @darth-scoob I made the same observation. I assume this is a sort of "ironing" effect due to the larger flat at the end of the nozzle. I definitely think the larger taper causes heat dissipation issues and plan to get the taper to the standard geometry as soon as possible. As for the toolchanger, I like it a lot. There are many things I would/have changed about it, but that's the beauty of open source 3d printing products.
                    @mrdui That will be one of the final tests I perform. High speed printing is lowest on the list of what I'm interested in here, but obviously want to know how it compares. Who knows, I may be surprised. Assuming I see reduced throughput, I've considered adding features like this:
                    https://procdn.blob.core.windows.net/pages/nozzles-caddie-wrench.pdf
                    I am unsure how patents would affect similar features on a 3d printing nozzle as I simply haven't gotten that far.
                    Overall, I assume there is more pressure loss in the ADV nozzle vs. V6. Whether it significant or can't be compensated via software, I am unsure at this time. I am also hopeful the improved geometry and reduction in sharp angles help to mitigate such an issue. Plastic really dislikes sharp angles.
                    Just for posterity, the primary areas I'm looking to improve are a) overall consistency in extrudate, b) improved surface finish, and c) reduced drool/stringing. On C, PLA is the material I am least interested in, but as it is the defacto 3d printing standard I decided to start with it. The nozzle is being developed with higher temp/viscosity and engineering grade polymers in mind. I'm very optimistic about doing Nylon test prints.
                    EDIT: One other thought, and correct me if I'm off base -- I assume standard nozzles have such a short orifice length due to machining limitations. After all, that's a very small tool and deflection would become an issue if making it much longer. I highly doubt the current "standard" orifice lengths are necessarily optimized.
                      deckingman @plasticfactory
                      @plasticfactory said in Advanced nozzle design:
                      ......................... EDIT: One other thought, and correct me if I'm off base -- I assume standard nozzles have such a short orifice length due to machining limitations. After all, that's a very small tool and deflection would become an issue if making it much longer. I highly doubt the current "standard" orifice lengths are necessarily optimized.
                      That's a thought that has also occurred to me. I would guess there ought to be an optimum orifice length to diameter ratio. Or if not, then at least some trade-offs to be made between long vs short, or pros and cons to put it another way. The only data point I have is the very unusual Diamond mixing hot end which, for an 0.4mm nozzle diameter, has a 3mm long section at 0.4mm for each individual input, then they combined into a further 2mm long section which is the nozzle proper. I know that this design needs an immense amount of PA compensation but oozes very little, especially when the volume of molten plastic in the melt chamber is taken into account.
                      Here is a picture of the beast
                      Diamond_Nozzle.pdf
                      plasticfactoryundefined 1 Reply Last reply Reply Quote 1
                        plasticfactory @deckingman
                        I'm not sure if anyone is still interested in updates on this, but a lot of testing has taken place, as well as numerous design revisions. All inspections were performed with a new Keyence LM. All brands used in testing were "high end" or otherwise among the most popular in the community (I'm not sure how I feel about including specific names compared to measurements taken). Key updates:
                        1. We have dialed in our machining process to hold a +/-0.001mm tolerance. The EDM machined nozzle is objectively higher precision than anything I can find on the market. The latest .80 nozzle measures at 0.801mm. The +/-0.001mm is consistent and achievable regardless of major ID nominal size (IE, a .40mm nozzle will come out to ~.401mm). Nothing I measured across all popular brands came close.
                        2. The machining process is very conducive to getting roundness right. The EDM machined nozzle is objectively rounder than everything I tested (across 6 nozzle brands). The EDM machined nozzles hold a roundness of 0.010mm, with the typical roundness across all tested brands being ~0.019mm.
                        3. The machining process results in a surface finish more consistent than anything else we dissected. This is typical for EDM machining vs. traditional cutting. Because we have some control over how matte or gloss the finish is, and the subjective nature of the effect this has on parts, I won't share much more until I have good pictures.
                        Overall, I'm very pleased with how things are turning out, though I was hoping for improvements in other areas, too. I think there is value in knowing you're .40 nozzle is as close to .40 as possible, for obvious slicing benefits and repeatability when swapping nozzles. The most precise nozzles I inspected were e3d's, averaging 0.394mm, with most brands measuring ~0.38mm, and the worst (and among the most expensive!) as low as 0.36mm. It definitely seems to me knowing your exact orifice size is just as valuable as knowing your exact filament diameter.
                        Where I go from here... Unsure. Are there any tests users would like to see performed? Specific prints? If this is allowed, I'd even love to get feedback on overall perception -- assuming things were priced similarly, what would make current options more appealing than this?
                        CCS86undefined Darth Scoobundefined 2 Replies Last reply Reply Quote 7
                        • CCS86undefined
                          CCS86 @plasticfactory
                          @plasticfactory
                          Thanks for the update!
                          Have you considered adding additional surface area, in the larger diameter section, to improve heat transfer to the filament?
                          The Bondtech CHT nozzles are improving max flow rate, with their 3 converging hole approach. With the EDM, I think you could do better and have essentially an internal spline shape.
                          plasticfactoryundefined 1 Reply Last reply Reply Quote 0
                            @CCS86 Actually, yes! I was inspired by this IMM product:
                            ... but was frustrated to see someone did exactly this with the Bozzle (https://www.fabreeko.com/products/bozzle-0-5mm-full-tungsten-carbide-nozzle-by-rentable-socks).
                            I am confident it could be done with even better geometry/finish (I have cross sectioned and tested the Bozzle along with the other popular nozzle brands), but higher flow has been toward the bottom of my list. I will definitely consider focusing on that next as it seems the community is very driven by faster/higher flow these days.
                            CCS86undefined 1 Reply Last reply Reply Quote 1
                            • CCS86undefined
                              So they did!
                              I can definitely see room for improvement in surface area of the Bozzle.
                                @plasticfactory I would be interested in seeing if there are any differences in the consistency of the extrudate size compared to a standard nozzle I would also be interested to see if the improvements made to the nozzle since the previous tests had any effect on the surface finish of parts, or line consistency.
