    Input Shaping + Pressure Advance Artifact
    2.1k
    • mikeabuilderundefined
      mikeabuilder
      Both Input Shaping and Pressure Advance affect the flow of the extrusion at corners, so they both need to be adjusted at the same time to get a good setting. The IS documentation suggests adjusting adjusting Pressure Advance after IS. In my case, I liked a PA setting of 0.1 without Input Shaping, and 0.08 after I selected IS parameters.
      One thing that I wish I did know was what the expected effect of adjusting each of the IS parameters. For example, when damping factor is increased, what is the expected change that should be observed in the ringing tower? Good stuff to add to the M593 page.
      evan38109undefined 1 Reply Last reply Reply Quote 0
      • bbergerundefined bberger referenced this topic
      • evan38109undefined
        evan38109 @mikeabuilder
        @mikeabuilder said in Input Shaping + Pressure Advance Artifact:
        Indeedy, you can see that happening in the second photo above. I first found good settings for input shaping, and then printed a PA calibration piece. That's a range of PA values with input shaping held constant. The same artifact shows up on the whole set of PA values from way too little (right) to way too much (left). But when PA is 0 (right edge), it's gone. For what it's worth, I've settled on a PA value of 0.09 with input shaping enabled, and 0.07 with it disabled.
        For reference, the input shaping configuration I'm currently using is M593 P"ei3" F42.0 S0.1 .
        I'll try and get some photos of a print holding PA constant but printing through a range of input shaping frequencies. The ridge is closer to the seam/turn with lower frequencies, and further away with higher frequencies. I've gone from 10Hz to over 100Hz, and it's always there. The damping parameter makes no difference to the artifact, nor does the PA value.
        The above were printed with the EI3 shaper. I'll try others soon. I've primarily focused on the EI2 and EI3 shapers since I have different resonant frequencies on the X and Y axes of my CoreXY printer. With 30-something Hz resonance on one axis and 50-something on the other, I can get pretty decent results with a shaping frequency in the low 40's using EI3.
          evan38109
          Try as I might, I can't get rid of these artifacts with any combination of IS and PA options.
          Here's how it shows up in real prints. Note the gaps where it looks like some segments of certain layers just didn't print.
          Here's a comparison with input shaping enabled + pressure advance enabled on the left (M593 P"ei2" F42.0 + M572 D0 S0.09); and only PA enabled on the right (M593 P"none" + M572 D0 S0.07). Same filament, gcode, printer, etc. Printed back to back, didn't even restart or re-home the printer. The one with IS disabled is fine.
          Is anyone out there using both input shaping and pressure advance at the same time with v3.4.0?
          Egon.Netundefined 1 Reply Last reply Reply Quote 1
          • oliofundefined oliof referenced this topic
          • Egon.Netundefined
            Egon.Net @evan38109
            @evan38109 I'm having the very same problem, you are not alone.
            • Egon.Netundefined
              Egon.Net @Egon.Net
              Any news about this issue?
                evan38109 @Egon.Net
                @egon-net I put this one down and figure I'll get back to it. I assume I'm doing something dumb somewhere.
                In the meantime, I've got an accelerometer and cabling in the mail. I've been tuning manually by printing calibration towers and such, but I figure I should try the more rigorous approach eventually. I've also been tuning other elements of my printer. If you look closely, even the "good" prints above have some artifacts and could be better.
                I'll probably revisit input shaping eventually, and I hope to be in the best possible place for it to succeed when I do.
                • evan38109undefined evan38109 referenced this topic
                • CCS86undefined
                  CCS86
                  I can't see what you could be doing wrong here.
                  Printing the same gcode with IS on and off is about as isolated as it can get, and it shows a very noticeable quality issue.
                  Did you ever look at this @dc42 ?
                  gnydickundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  • gnydickundefined
                    gnydick @CCS86
                    @CCS86 there is another very long thread about this. I didn't realize it's been at least 10 months since the problem started 😞
                      dc42 administrators @CCS86
                      @CCS86 yes we know that the current implementation of PA isn't ideal when IS is also used. We thought we could get away with not adjusting PA to account for IS, because Klipper doesn't either. But Klipper has got it wrong too.
                      I hope to address this before the RRF 3.5 release.
                      evan38109undefined CCS86undefined 2 Replies Last reply Reply Quote 4
                        evan38109 @dc42
                        Awesome! Thank you!
                        • CCS86undefined
                          CCS86 @dc42
                          @dc42 said in Input Shaping + Pressure Advance Artifact:
                          Glad to hear that!
                          Any chance that some sort of PA smoothing might be implemented as well?
                            @CCS86 the main reason that Klipper uses PA smoothing is that it doesn't control extruder jerk, and without applying PA smoothing it's likely that the extruder would miss steps.
