    Duet 3 Mini 5+ controlling Power Supply with SSR
    777
    • jaclopundefined
      jaclop @dc42
      @dc42 it's an G3MB-202P 1565E, 5VDC Input Relay. Here's a datasheet of the relay https://components101.com/sites/default/files/component_datasheet/G3MB-202P-Datasheet.pdf and can't find a schematic for the board itself but it is this one: http://wiki.sunfounder.cc/index.php?title=1_Channel_5V_Solid_State_Relay_Module
        dc42 administrators @jaclop
        @jaclop my AV program won't let me access that second link.
        Additionally, you appear to have a transistor connected between the three wires on the left and the board.
        What are the labels next t the three terminals on the left hand side of that boar in your photo? The wires are obscuring them.
        I don't understand why that board is needed at all, other than to make it easier to connect to the SSR. The Duet can drive an SSR directly. Usually the control inputs of the SSR are connected + to _5V and - to PS_ON.
        jaclopundefined 1 Reply Last reply Reply Quote 0
        • jaclopundefined
          jaclop @dc42
          This is the ciruit with the transistor I used previously with the transistor, diode and resistor that can be seen in the previous photo:
          https://www.susa.net/wordpress/2012/06/raspberry-pi-relay-using-gpio/
          Here are the labels of the board:
          I guess I can directly connect 5V to DC+, PSON to DC- and 3.3V to CH1?
          Then when I use M80 and M81, I expect it will turn the relay on and off.
          achrnundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • achrnundefined
            achrn @jaclop
            @jaclop As noted in the thread, the Duet board is designed to drive a SSR directly, and doesn't need the board, but with the board, I'd connect DC+ to 3.3V, DC- to GND, and the CH1 to io4.out. All three connections can be made on IO_4 header. This is making use of the fact that on a mini-5 IO_4 and ps_on are the same signal (but driven at different levels).
            If that doesn't work, DC+ to a 5V connection somewhere on the Duet board, DC- to a GND connection somewhere on the board and CH1 to the pson pin. I don't think you can get the 5V from the EXT 5V connector, because that's just for feeding 5V in, you'll need to get it from somewhere else (this is why this is my second choice).
            In either case you then need to test which polarity activates the SSR - ie whether you want M80 C"pson" or M80 C"!pson" (the board markings suggest probably pulling the output low will switch the SSR on, but it's more definitive to try both and see what happens).
              @jaclop I can see that the board has a transistor driver on it. Please post a photo of the underside of that board, which may enable me to confirm my guess about how it should be connected.
              • jaclopundefined
                jaclop @dc42
                Thanks for your help.
                  @jaclop thanks. I can see the traces clearly on the underside, but not on the top side. So I still can't work out the schematic. Can you provide a photo of the top side with good lighting?
                  I am a little concerned that there are high voltage connections close to low voltage connections on that board:
                  • jaclopundefined
                    jaclop @dc42
                    @dc42 top_2.jpg top_1.jpg bottom.jpg Thanks again for your patience and help.
                      @jaclop it looks to me that you can connect DC+ to +5V, DC- to GND, and CH1 to the PS_ON pin.
                      • jaclopundefined
                        jaclop @dc42
                        @dc42 Thanks. Is it also recommended to use a snubber like so between the two live wire contacts? In the past, I had to replace the SSR every 9 months or so which I'm guessing were failing due to voltage spikes.
                          @jaclop a snubber is usually only needed when the SSR drives an inductive load.
                          I suspect that the SSR may have failed because the surge current that the PSU draws when you start it up was too large. A larger SSR such as SSR25DA might be a better choice and can be driven directly from +5V (+ve control input) and PS_ON (-ve control input). Note, many Fotek SSR25DA listings on shopping sites are fakes.
                          • jaclopundefined
                            jaclop @dc42
                            @dc42 Thanks. I could not get the SSR module working and due to the likelihood of future failures I have installed the SSR25DA but this is also not working.
                            I have M81 C"!pson" in my config.g file. I tried initially with i04.out and now have the positive input of the SSR25DA connected to 5V_EXT of IO_4 and the negative input of the SSR connected to pson. I have tried sending these commands: M80 C"!pson", M80 C"pson", M81 C"!pson", M81 C"pson, but the relay is not turning on the 12V PSU. My Duet Mini 5+ is being powered via the Micro USB using a 5V 2.5A power supply.
                            Am I doing something wrong or is there something I can try to troubleshoot this issue?
                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                            • DIY-O-Sphereundefined
                              DIY-O-Sphere @jaclop
                              @jaclop
                              Which RRF version?
                              (UTC+1)
                              • jaclopundefined
                                jaclop @DIY-O-Sphere
                                @DIY-O-Sphere
                                From Machine-Specific General Tab:
                                Board: Duet 3 Mini 5+ (Mini5plus)
                                Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.3RC2 (2021-05-11)
                                Duet WiFi Server Version: 1.26
                                  @jaclop
                                  With RRF 3.3 you only need to add
                                  M80
                                  at the end of config.g
                                  (UTC+1)
                                  • jaclopundefined
                                    @DIY-O-Sphere I added M80 to the end of the config file and applied the new configuration by running it but it did not activate the relay.
                                      @jaclop
                                      https://forum.duet3d.com/topic/19161/smart-remote-power-control?
                                      Maybe the wiring diagram helps. Have a look on the input side of the relay.
                                      You need the +5V and the middle pin of PS-On
                                      (UTC+1)
                                      • jaclopundefined
                                        @DIY-O-Sphere Re-checked my wiring but I still can't get the relay to activate.
                                        This is the relay, the 5V_EXT connection and the PSON connection:
                                        Is activating the relay using a GPIO pin an option? If so, how would I do that?
                                        DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                                          @jaclop said in Duet 3 Mini 5+ controlling Power Supply with SSR:
                                          5V_EXT
                                          What is your setup of these two jumpers?
                                          (UTC+1)
                                            PS_ON should do the job....I guess you don't have the +5v voltage on the 5V_EXT pin
                                            (UTC+1)
