    Pre-release 3.5 beta 2 now available
    Beta Firmware
    14
    30
    2.4k
    • chrishammundefined
      chrishamm administrators
      On behalf of the Duet3D team I am happy to announce the next pre-release v3.5 beta 2.
      This release brings several new features and bug fixes since v3.5 beta 1 with the highlights being:
      • Ability to reassign individual array elements using the set command
      • New code editor in DWC including new G-code highlighting to support meta G-code expressions
      • Improved support of custom array variables
      • Several improvements for multiple motion systems
      • MQTT publisher support on Duet 3 series WiFi enabled boards (M586 P4 and M586.4)
      • Keepout zones (M599)
      • Backlash compensation (M425)
      Please do not forget to read the upgrade notes for
      • RepRapFirmware
      • DuetWebControl
      • DuetSoftwareFramework
      Starting from this release, DSF and DWC will use SemVer v2 for versioning.
      This means if you are using MintyTrebor's ReleaseMgr plugin to track impacts on your configuration, you need to upgrade it as well.
      In standalone mode, you can obtain the latest versions from here. Please check out to the docs if you want to try it out in SBC mode.
      If you encounter any issues, please open a new thread with [3.5.0-b2] in the title and describe it there.
      Duet software engineer
      oliofundefined 1 Reply Last reply Reply Quote 10
      • chrishammundefined chrishamm pinned this topic
      • oliofundefined
        oliof @chrishamm
        @dc42 any plans to integrate ADXL accelerometer support by @gloomyandy upstream? That would allow to make full use of RP2040 based boards on the market that usually have ADXL accelerometers on board for the klipper people.
        • mikeabuilderundefined
          mikeabuilder
          Has support for the new M291 message options been added to the PanelDu fw yet? If not, and ETA?
            T3P3Tony administrators @mikeabuilder
            @mikeabuilder said in Pre-release 3.5 beta 2 now available:
            No. I don't have an ETA yet.
              dc42 administrators @oliof
              @oliof said in Pre-release 3.5 beta 2 now available:
              Unfortunately the ADXL345 doesn't provide a fast means of reading data without introducing artefacts in the data. Andy has verified that these artefacts are present when using Klipper firmware too. So it is not something that we wish to support.
              oliofundefined 1 Reply Last reply Reply Quote 3
              • oliofundefined
                oliof @dc42
                @dc42 I understand but its still a bummer. @gloomyandy do you have any pretty pictures comparing ADXL with LIS where one could see those artefacts?
                • Diamondbackundefined
                  Diamondback
                  Does anyone else have issues with loops? It appears to me that this is not working at all:
                  while iterations < 4
                      echo iterations
                  RRF spawns lots of error messages likes this:
                  Error: Bad command: hile iterations < 4
                  0
                  0
                  0
                  0
                  0
                  0
                  0
                  0
                  (Note that this is from a a single macro execution of above code, nothing else)
                  And DWC keeps crashing and/or disconnecting after this, only cutting power solves the issue (until I try to execute it again)
                  OwenDundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                  • OwenDundefined
                    OwenD @Diamondback
                    @Diamondback
                    No issues with that macro on duet2 standalone
                      jay_s_uk @Diamondback
                      @Diamondback looks like it's dropping the w
                      SBC or standalone?
                      Diamondbackundefined 1 Reply Last reply Reply Quote 1
                        Diamondback @jay_s_uk
                        @jay_s_uk 6HC standalone
                          Diamondback
                          Ok, so in 3.5b1+ things work fine.
                          M98 P"0:/macros/TEST"
                          0
                          1
                          Since I have a bunch of different builds between b1 and b2, will now trying to figure out where thing broke.
                            Diamondback
                            Ok, @dc42 it looks like this happened at some point after you implemented the setting of individual array elements.
                            The initial test that you provided to me (3.5beta1+ (2023-01-26 14:16:10)) works correctly, however, another test version (with the same dropbox name for some reason) that you provided to me later as part of the Z/extruder issues (3.5beta1+ (2023-01-30 09:10:34)) has the issue already.
                            So I guess something between these two dates causes it.
                            dc42undefined 2 Replies Last reply Reply Quote 1
                              dc42 administrators @Diamondback
                              @Diamondback please attach that file to a post, I think there jmy be something odd about it.
                              Scratch that, I've managed to reproduce a similar issue. It's connected with using CRLF as the line ending.
                              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                @Diamondback please try the new RRF binary at https://www.dropbox.com/sh/tbxi2wz9olqe5cl/AAA1gvCp05XS7G1t0qxAV3yQa?dl=0.
                                Diamondbackundefined gman10192undefined 2 Replies Last reply Reply Quote 1
                                  Diamondback @dc42
                                  @dc42 This seems to work now, thanks a lot! 🙂
                                  • Ghaziundefined
                                    Ghazi
                                    I remember that @joergs5 was working on a robot kinematic K13. Is it available in the 3.5beta version?
                                    • DIY-O-Sphereundefined
                                      DIY-O-Sphere @dc42
                                      Is there any news on restoring the old error handling in the case of a heater fault ?
                                      (UTC+1)
                                      • JoergS5undefined
                                        JoergS5 @Ghazi
                                        @Ghazi I'm sorry, development will take longer, as I changed the internal algorithms. So it will not be included in 3.5.
                                        The original method was to iterate inverse kinematics solutions. But a few % of the solutions didn't iterate correctly, i.e. the solution will fail, ruining the print. The solution now is to calculate inverse kinematics for all possible solutions and will give an answer in every situation. But this change will take a while.
                                        • Marcossfundefined
                                          Marcossf
                                          We tested this 3.5 beta 2 in our 6XD + several 1LCs machine in SBC mode, and it gives constant SPI reseting.
                                          Going back to 3.4.5 stable version revert the normal behaviour of the printer.
                                          All firmware on the boards in the beta 2 are been updated, just in case it needs to be same version than mainboard.
                                          dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                                            dc42 administrators @DIY-O-Sphere
                                            @DIY-O-Sphere said in Pre-release 3.5 beta 2 now available:
                                            What aspect of the old error handling is it that you want, that can't be achieved using the event system?
