    SBC loses network connection, alot!
    872
      jay_s_uk @Jered
      @Jered have you considered running in standalone mode?
      Can you post an M122 output when you see a disconnection?
      Can you also post a photo of your wiring? Concentrating on the area where the ribbon cable is
      Jeredundefined 1 Reply Last reply Reply Quote 0
      • Jeredundefined
        Jered @jay_s_uk
        @jay_s_uk
        I would post an M122, just can't due to no connection at the moment. I would need a display to run in standalone mode, which I don't have. Perfer sbc since it is really convenient and one of the feature I got this for. The only way I have to see into what this thing is doing is through the sbc.
        The cable runs from the bottom left up to the top right.
        jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @Jered
          @Jered wow, that cable is stupid long.
          I think duet recommend around 150mm long.
          That cables just too long for an SPI connection
          • Jeredundefined
            Jered @jay_s_uk
            @jay_s_uk
            So, no reboot during printing? Or using a more robust computer with it. Something without cable limits?
              jay_s_uk @Jered
              @Jered if it's lost the connection enough that it can't recover then the prints failed.
              I suggest moving the raspberry pi closer to the 6HC and using the supplied cable.
              This isn't something you can fix by using a different SBC
                Phaedrux Moderator @Jered
                @Jered said in SBC loses network connection, alot!:
                You mean you're using an HDMI touch screen with the SBC?
                keeps losing connection
                What errors are you getting? Is it DWC that is losing connection?
                @jay_s_uk said in SBC loses network connection, alot!:
                Definitely try this and see if it helps your situation. You MIGHT be able to get away with longer length if you used a shielded twisted pair cable instead of a flat ribbon, but even so, SPI isn't meant for long runs.
                Jeredundefined wayneosdiasundefined 2 Replies Last reply Reply Quote 0
                • Jeredundefined
                  Jered @Phaedrux
                  @Phaedrux
                  The machine is still printing even though connection has been lost for awhile now.
                  I will look into sheilded cables and what not before moving the sbc. As you can see from the pic, moving it will not be easy as space is limited.
                  Are there any plans to allow the Duet controller to use regular PCs?
                    No.
                    I still don't know exactly what you mean by losing network connection.
                    Network connection sounds different than an SPI connection issue. What exactly are you seeing?
                    • Jeredundefined
                      Jered @Phaedrux
                      @Phaedrux
                      Attached is photo taken of the monitor that is connected directly to the sbc.
                      I haven't really had any problems until just recently. So this is baffling to me.
                      Print is still going, but I need to cancel it. Since the sbc is not responding, I will have to just power down.
                        Where is that error displayed though? On a computer browser connected to DWC or on an HDMI touch screen to the SBC?
                        Are you still able to ping the IP address of the SBC?
                        Can you reach the SBC over SSH?
                        • Jeredundefined
                          Jered @Phaedrux
                          @Phaedrux
                          The error is displayed on the monitor connected to the hdmi port of the sbc.
                          Here is a zoomed out pic.
                          I can operate the sbc just fine. I can minimize the duet interface and operate the sbc normally, it's just that the sbc is no longer talking to the Duest controller. DWC is seems to be not connected somehow.
                          Not sure I need to ping anything. Also, not sure how to ping.
                            Ok, can you close the DWC interface and relaunch it?
                            Can you grab a log from the SBC?
                            https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#increasing-log-level
                            • Jeredundefined
                              Jered @Phaedrux
                              @Phaedrux
                              I'll try. How to I retrieve the log?
                                To obtain more data for potential debugging it is possible to adjust the log level of the DCS service. This can be done by changing LogLevel in /opt/dsf/conf/config.json from info to debug.
                                Once this change has been made, restart the DCS service to apply it (sudo systemctl restart duetcontrolserver). After that you can follow potential debug messages in a terminal by running journalctl -u duetcontrolserver -f.
                                • Jeredundefined
                                  Jered @Phaedrux
                                  @Phaedrux
                                  I can give that a try. I am not familiar with that, but there's no time like the present.
                                  I did close the browser on the sbc and re-open it. It works now. Remoted in from my other computer and I can see it there as well. So by closing the browser on the sbc and re-opening it, I now have full control from anywhere again.
                                  I will try the debugging thing when I get a chance.
                                  MintyTreborundefined 1 Reply Last reply Reply Quote 0
                                  • wayneosdiasundefined
                                    wayneosdias @Phaedrux
                                    @Phaedrux "You MIGHT be able to get away with longer length if you used a shielded twisted pair cable instead of a flat ribbon, but even so, SPI isn't meant for long runs."
                                    I dont think shielding will help. The issue is increased capacitance and resistance with long wire runs and screws up the spi signal timing. The quickest check would be what others have suggested. Simply move the SBC closer to the 6HC using the original cable. If that fixes your issue no amount of shielding is going solve your problem. You will need to relocate the SBC next to the 6HC.
                                      Phaedrux Moderator @wayneosdias
                                      @wayneosdias In this case it doesn't seem like an SPI issue because the print continued, so the connection between SBC and Duet was still active.
                                      Network connection error coming up in DWC is something else. Restarting DWC re-connected successfully.
                                      wayneosdiasundefined 1 Reply Last reply Reply Quote 0
                                        @Phaedrux interesting. I have no experience using sbc. So the sbc acts as sender?
                                          @wayneosdias Yes, but not in the sense of a traditional USB gcode sender would.
                                          • MintyTreborundefined
                                            MintyTrebor @Jered
                                            @Jered There is a lot to unpack in this thread, generating a number of questions which will help us to narrow this down.
                                            The Pi:
                                            What model Pi is it?
                                            How is it currently connected to your network Wifi or ethernet (It's difficult to tell from the picture)? Or is it acting as a hotspot?
                                            If you are using wifi on your normal network how good is the signal strength (should have a visual indication on the desktop)
                                            Are those thermal pads on the chips? Do you normally have heat-sinks on those pads/chips? Thermal Pads with nothing on them will probably just insulate the chips not dissipate heat, which may cause performance/stability issues (Again difficult to tell from picture)?
                                            Are you using the standard SBC build/OS on the pi?
                                            You do not mention how you are powering the Pi? Does the supply meet the Pi's recommended specs?
                                            Have you tried a new SDcard? They can and do fail in weird ways (I speak from experience)
                                            The Browser:
                                            What URL are you using in the browser on the Pi Desktop?
                                            Does the network error appear after a period of inactivity - where you have not interacted with the browser for a while?
                                            Run the browser with developer mode enabled, see if there is any more info in the developer console / networking tab when the error occurs
                                            Other:
                                            You mention "Remoting in from my other computer" do you mean VNC/SSH, or just accesses DWC from a different browser on your network? If Browser -> DWC what URL are you using?
                                            NodeDSF - Native Node-Red integration with Duet boards.
                                            BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                                            ReleaseMgr - Duet update info inside DWC.
                                            Repo
