Solved Emergency Stop
@deckingman I have them commented ATM until I have them correct and complete. Based on what your saying I'll implement the following change:
M950 J1 C"e0stop"
M581 T2 P1 S1 R1
Thats the easy part. The macro is what baffles me. Do I manually build a trigger2.g file in the DWC and put in it what I want the button to do when triggered? -
@SonnyD1 Yes. You might find that trigger 2 already exists but is blank. If not create it. You can use the web interface or a text editor like notepad++ and upload it. I think the trigger files go in the .sys folder rather than the macros folder but I'm not 100% sure as I'm just using my phone right now.
Edit. Now that I'm in front of my PC, I can confirm that trigger files do indeed go in the .sys folder.
@deckingman I built a folder and put a simple M112 in it. Test failed. I've got some checking to do. I suspect it may be a wiring issue. I'll have to work it out and get back with ya.
@SonnyD1 said in Emergency Stop:
Suggest the first thing you do is change T2 to T0. That will work the same way that M112 does but without needing a trigger macro (that's why trigger 0 and trigger1 should not be used -T1 does a pause like M25). If that doesn't work, then you need to check your wiring etc. If it does work then you need to check the trigger2 file and /or its location.
@deckingman Yea its gotta be a wiring issue. I think I can sort it out. I'll get back with ya when I do.
@deckingman Ok I cant seem to figure out the wiring and I dont want to use the trial and error method my my new board. Do you know how to wire that particular endstop?
@SonnyD1 From a question in the the 'Question and Answer' section of the listing:
Question:
I assume the the green wire is the common? wireing needs to be in your description.
Answer:
Hi Green wire is common, Blue is NO, Yellow is NC.So you can wire it NO or NC. We advise NC (Normally Closed), see https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_endstops#microswitch
Duet 3: connect the switch between the IN and GND pins of your chosen IO_x connector.
Do you mean you created a folder called 'trigger2.g'? It needs to be a text file, like any gcode file. And it needs to be in the sys folder.
@droftarts Thats how I have it wired. I have the green wire to the ground and the yellow wire to the signal. Also, I created a folder named trigger2.g with an M112 in it. I started a home all and hit the endstop and nothing happened.
A folder, or a file? It should be a text file, not a folder.
@droftarts Yes it is a file. Currently named trigger0.g due to the "T" change you recommended. The file isn't even necessary with a T0.
@droftarts I found the problem. It wouldn't trigger because I had a R1 instead of a R0 in my M581 command. I've changed it and it executes the M112 properly now. Any modifications I do on it from here on out would be easy now that I know. I would say this issues is solved. Thank you very much!
@SonnyD1 R1 will only trigger while a file is being printed from the SD card. So it probably was working, you just weren't running a job! Also, yes, T0 and T1 ignore any trigger file, so any changes to trigger0.g won't do anything. You need to use T2 or higher to have it run what you want in a trigger#.g file.
@droftarts Thats what I may do later. For now I'm gonna leave it as is. Thanks again for your help!
