    BTT Smart filament sensor setup
    Third-party add-ons
    1.3k
    • Terradiveundefined
      Terradive @jay_s_uk
      @jay_s_uk I did. It printed longer but still gave the too little movement.
        jay_s_uk @Terradive
        @Terradive what results are you getting back from it when it fails? M591 D0 (or D1) should tell you
        Terradiveundefined 2 Replies Last reply Reply Quote 0
          Terradive @jay_s_uk
          @jay_s_uk No data received. I set the r value down to R1:200. It still stopped in another test. I'm trying to rule out any gcode problems assigning drives. I think I have the wiring correct.
            Terradive @jay_s_uk
            @jay_s_uk It's printing using tool 1.
            jay_s_ukundefined Terradiveundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @Terradive
              @Terradive best to check your wiring then
                Terradive @Terradive
                This is my wiring. Do you see any problems? I've tried printing from both drives neither works. They're wired identically.
                elmoretundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • elmoretundefined
                  elmoret @Terradive
                  @Phaedrux This user has emailed me asking for a warranty replacement. Maybe use a X/Y/Z end stop to rule out a board defect on the E0/E1 ports?
                    Phaedrux Moderator @Terradive
                    @Terradive Can you check for continuity on that cable with a multimeter? It's acting like it's getting nothing from it.
                    As elmoret suggests, do you have a simple endstop you could connect and test as a simple filament presence sensor?
                    Terradiveundefined 1 Reply Last reply Reply Quote 0
                      Terradive @Phaedrux
                      @Phaedrux I moved the xstop cable over to the e0 slot and tapped the button a couple of times. The light flickered. I'm not real great with multimeters, I unplugged the cable at the sensor. With the printer off, I then put the positive connection to the v wire and the negative connection on the ground. The numbers changed slightly. I then turned on the machine and repeated the test and the numbers changed more.
                      elmoretundefined 1 Reply Last reply Reply Quote 0
                      • elmoretundefined
                        elmoret @Terradive
                        @Phaedrux @T3P3Tony
                          @Terradive said in BTT Smart filament sensor setup:
                          @jay_s_uk I have also installed a .9 stepper motor on my extruder. I tried doubling the l amounts to compensate but that did not owrk.
                          When you installed the 0.9 stepper did you also modify your E steps per mm?
                          So it sounds like the E0 endstop is responding correctly.
                          To test continuity of the cable going between the endstop port and the sensor you would set your multimeter to continuity mode and then touch a probe to an end of the wire at the same time. The meter will usually beep when there is a connection.
                          Here's an illustrated example of it. https://www.wikihow.com/Test-Continuity-with-a-Multimeter
                          Can you show a screenshot of the gcode console after sending M591 D0or M591 D1 depending which tool you're using after it has paused?
                          I don't think there is anything wrong with the Duet itself.
