    Extruder Stopped Working
    427
    • oranzirfundefined
      oranzirf
      I have been using my Duet 3 Mini5+ for some time now without issues. My extruder on Driver 3 stopped during a print. I checked and replaced the stepper and the wiring without any luck. I also switched the extruder to Driver 4 and no luck either. I did try a cold extrude M302 P1. the 0, 1,2 drivers still work fine. I am at a loss for next step. Here is my diagnostic file and my config.g underneath:
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus WiFi (SBC mode)
      Board ID: B7Y7N-8Q6KL-K65J0-409NS-NSW1Z-774VS
      Used output buffers: 1 of 40 (12 max)
      Static ram: 103652
      Dynamic ram: 101488 of which 44 recycled
      Never used RAM 36528, free system stack 173 words
      Tasks: SBC(ready,1.3%,469) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,341) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,97.1%,557) IDLE(ready,0.1%,30) AIN(delaying,0.8%,272), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:11:05 ago, cause: software
      Last software reset at 2023-03-15 10:23, reason: User, GCodes spinning, available RAM 36528, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 665671, completed 665669, timed out 0, errs 0
      Step timer max interval 1490
      MCU temperature: min 31.3, current 32.2, max 32.4
      Supply voltage: min 12.5, current 12.5, max 12.6, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 35008, writes 15, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 35007, writes 15, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 35007, writes 15, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 35013, writes 9, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 35010, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2023-03-15 10:34:42
      Cache data hit count 1466656429
      Slowest loop: 140.69ms; fastest: 0.09ms
      === Storage ===
      Free file entries: 10
      SD card 0 not detected, interface speed: 0.0MBytes/sec
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 5983, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 3329/0/0
      Tx timeouts 0,0,3328,0,0,2653 last cancelled message type 30 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 26113/26113
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x0f1bc
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server v3.4.5
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 39.27, max time between full transfers: 74.6ms, max pin wait times: 34.8ms/34.1ms
      Codes per second: 0.23
      Maximum length of RX/TX data transfers: 3276/1064
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Thu Feb 09 2023 14:55:43 GMT-0500 (Eastern Standard Time)
      M550 P"Duet 3" ; set printer name
      M665 R136.2 L215.82 B85 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M918 P1 E4 F2000000 ; configure direct-connect display
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z80.00 E413.86 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"!io4.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io4.in
      M574 Y2 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
      M574 Z2 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
      M558 P5 R0.4 C"io3.in+io3.out" H30 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      M557 R75 S20 ; define mesh grid
      M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
      M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
      M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
      M106 P0 S1 H1 T35 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
      M569 P2 D3
      M569 P1 D3
      M569 P0 D3
      jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet @oranzirf
        @oranzirf Have you tried running the drivers with just a bare motor? I'm assuming you`ve checked your hot end and heat break are clear and no heat creep has occurred, does the motor make any noise or vibration at all? also visually check you board for any damage around the drivers.
        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
        oranzirfundefined 1 Reply Last reply Reply Quote 0
        • oranzirfundefined
          oranzirf @jumpedwithbothfeet
          @jumpedwithbothfeet thanks, Yes I have tried a new motor and wires. No response at all. Nothing obvious on the board. Very strange.
          elmoretundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
          • elmoretundefined
            elmoret @oranzirf
            @Phaedrux / @T3P3Tony , this customer emailed requesting replacement. Wanted to bring your attention to the thread to expedite diagnosis.
              T3P3Tony administrators @oranzirf
              @oranzirf did you try moving the extruder to driver 4 temporary . You will need to update this line in your config,:
              M584 X0.0 Y0.1 Z0.2 E0.4 ; set drive mapping
              Strangely I don't see an error reported by driver 0.3 in the M122 report.
              • oranzirfundefined
                oranzirf @T3P3Tony
                @T3P3Tony Thanks, I did try moving to driver 4 with same result. That is why I tried a new stepper and wires. Seems like drivers 3 and 4 have issue but 0, 1 and two are fine. I just took the board out and do not see any obvious problems. Very strange, it has been working great. In fact, just bought another board for another printer.
                  Just for the sake of completeness, can you switch over to a driver that is otherwise working on another axis and use that for the extruder? If it works there then we know it's not an issue with wiring or configuration or hotend. Getting the hotend to temp and extruding is enough to test.
                  • oranzirfundefined
                    oranzirf @Phaedrux
                    @Phaedrux Thank you, I remapped to driver 2 and the extruded worked. While I was at it, I remapped the Z axis to the non working driver 3. The Z motor does not work. It looks like drivers 3 and 4 have problems.
                      Thanks for verifying. When and where did you purchase your Duet?
                      oranzirfundefined 2 Replies Last reply Reply Quote 0
                      • oranzirfundefined
                        oranzirf @Phaedrux
                        @Phaedrux Filastruder, Order #89866 , December 2022. Thank you for your help.
                        • oranzirfundefined
                          oranzirf @Phaedrux
                          @Phaedrux More detail on order.
                          Filastruder
                          ORDER #89866
                          Order summary
                          PanelDue 7iנ1
                          With 4 pin 1 meter cable $119.99
                          Duet 3 Mini 5+נ1 Wifi $144.99
                          If you have any questions, reply to this email or contact us at support@filastruder.com
                            Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
