    Duet 3 6HC v1.02 - Wifi Module
    696
      T3P3Tony administrators
      We added an ESP header to the Duet 3 6HC v1.02 and have designed an ESP32 wifi module to plug into that.
      The initial documentation is here:
      https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview#wifi-v102
      We have a small number of prototypes for testing for people who already have a 6HC v1.02 up and running on their machine and are running 3.5 firmware. If that sounds like you please drop me an email, info@duet3d.com with details of your printer, your forum name and where you are located.
      iDavidFengundefined 1 Reply Last reply Reply Quote 7
      • iDavidFengundefined
        iDavidFeng @T3P3Tony
        @T3P3Tony where to buy the module?
          T3P3Tony administrators @iDavidFeng
          @iDavidFeng for now we just have some prototypes. Please email sales@duet3d.com if you would like one.
          iDavidFengundefined 1 Reply Last reply Reply Quote 0
            @T3P3Tony is that open source hardware?haha
            • oliofundefined
              oliof @iDavidFeng
              @iDavidFeng all released hardware by Duet is well documented on their github and available under an open source license. Unreleased prototypes may not, but you can find the source to the firmware on github as well ... so I guess there is a good chance you may be able to derive how to build a module yourself.
                iDavidFeng @oliof
                @oliof but I can not find which pin is used on wifi module
                • NeoDueundefined
                  NeoDue
                  Just to know when I need to start looking for this part at the local resellers: Is there already a planned release date for this module?
                    T3P3Tony administrators @NeoDue
                    @NeoDue planned for 01 May
                    NeoDueundefined selva_tviundefined 2 Replies Last reply Reply Quote 0
                    • NeoDueundefined
                      NeoDue @T3P3Tony
                      @T3P3Tony Thanks a lot!
                      elmoretundefined 1 Reply Last reply Reply Quote 0
                      • elmoretundefined
                        elmoret @NeoDue
                        In stock: https://www.filastruder.com/products/duet-wifi-module-for-duet-3-6hc-v1-02-or-later
                        NeoDueundefined 1 Reply Last reply Reply Quote 1
                        • selva_tviundefined
                          selva_tvi @T3P3Tony
                          @T3P3Tony Hi, is it available with any UK or Asian resellers? We are from India and need to order two numbers.
                          I found it only in Filastruder. Or is it possible to order from you?
                          Thanks
                          T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                            T3P3Tony administrators @selva_tvi
                            @selva_tvi , I assume you have seen our list of resellers here:
                            https://www.duet3d.com/page/genuine-resellers
                            in stock in the UK:
                            https://e3d-online.com/products/duet-3-mainboard-6hc
                            EU (some examples, not complete list):
                            https://www.dhm-online.com/en/control-cards/4416-duet-3-mainboard-6hc-v102-motherboard-for-next-generation-3d-and-cnc-printers.html
                            https://nl.reprapworld.be/elektronica/electronische-3d-merken/duet3d/duet3d-controller-borden/duet-3-moederbord-6hc-v1-02/
                            https://www.dold-mechatronik.de/Duet-3-Mainboard-6HC_1
                            https://www.123-3d.nl/Duet3D-Duet-3-Mainboard-6HC-v1-02-origineel-i9559-t14808.html
                            https://www.3dmensionals.de/duet-3-main-board-6hc-v1-02-1235?category=527#attr=10114,10115
                              @selva_tvi apologies, it has just been pointed out to me you meant the wifi module.
                              please email sales@duet3d.com
                              selva_tviundefined 1 Reply Last reply Reply Quote 0
                                selva_tvi @T3P3Tony
                                @T3P3Tony yeah sure. Thank you 🙂
                                • NeoDueundefined
                                  NeoDue @elmoret
                                  @elmoret Thanks a lot, but thanks to Brexit I prefer to wait until the german resellers have it... less fuss with customs.
