    6 Axis linear Delta
    598
    • tklnundefined
      tkln @dc42
      @dc42 thanks for the fast reply
      1. Is there a reason why the file cannot be found?
        I used vscode with the clone file from github
      #include math/deviaion.h
      -> My next step is: define the positions of the six actuators relative to the base.
      These are the corners of my tower
      That would be the tower positions.
      	towerX[DELTA_A_AXIS] = -(radius * cosf((25,5 + angleCorrections[DELTA_A_AXIS]) * DegreesToRadians));
      	towerY[DELTA_A_AXIS] = -(radius * sinf((25,5 + angleCorrections[DELTA_A_AXIS]) * DegreesToRadians));
      	towerX[DELTA_B_AXIS] = -(radius * cosf((34,5 + angleCorrections[DELTA_B_AXIS]) * DegreesToRadians));
      	towerY[DELTA_B_AXIS] = -(radius * sinf((34,5 + angleCorrections[DELTA_B_AXIS]) * DegreesToRadians));
      	towerX[DELTA_C_AXIS] = -(radius * cosf((34,5 - angleCorrections[DELTA_C_AXIS]) * DegreesToRadians));
      	towerY[DELTA_C_AXIS] = +(radius * sinf((34,5 - angleCorrections[DELTA_C_AXIS]) * DegreesToRadians));
      	towerX[DELTA_D_AXIS] = -(radius * cosf((25,5 - angleCorrections[DELTA_D_AXIS]) * DegreesToRadians));
      	towerY[DELTA_D_AXIS] = +(radius * sinf((25,5 - angleCorrections[DELTA_D_AXIS]) * DegreesToRadians));
      	towerX[DELTA_E_AXIS] = +(radius * cosf((4,5 - angleCorrections[DELTA_E_AXIS]) * DegreesToRadians));
      	towerY[DELTA_E_AXIS] = +(radius * sinf((4,5 - angleCorrections[DELTA_E_AXIS]) * DegreesToRadians));
      	towerX[DELTA_F_AXIS] = -(radius * cosf((4,5 + angleCorrections[DELTA_F_AXIS]) * DegreesToRadians));
      	towerY[DELTA_F_AXIS] = +(radius * sinf((4,5 + angleCorrections[DELTA_F_AXIS]) * DegreesToRadians));
      Questions about the tower positions
      2. Or do I have to dial +-85.5° for Tower E and F?
      3. When is the angleCorrections[DELTA_A_AXIS] positive and when is it negative?
      4. From the LinearDeltaKinematics.cpp, the tower position is like in the picture, isn't it?
      	towerX[DELTA_A_AXIS] = -(radius * cosf((30 + angleCorrections[DELTA_A_AXIS]) * DegreesToRadians));
      	towerY[DELTA_A_AXIS] = -(radius * sinf((30 + angleCorrections[DELTA_A_AXIS]) * DegreesToRadians));
      	towerX[DELTA_B_AXIS] = +(radius * cosf((30 - angleCorrections[DELTA_B_AXIS]) * DegreesToRadians));
      	towerY[DELTA_B_AXIS] = -(radius * sinf((30 - angleCorrections[DELTA_B_AXIS]) * DegreesToRadians));
      	towerX[DELTA_C_AXIS] = -(radius * sinf(angleCorrections[DELTA_C_AXIS] * DegreesToRadians));
      	towerY[DELTA_C_AXIS] = +(radius * cosf(angleCorrections[DELTA_C_AXIS] * DegreesToRadians));
      1. What values ​​do these variables represent?
      float Xbc, Xca, Xab, Ybc, Yca, Yab;
      I don't quite understand what coordinates are calculated with it.
      	Xbc = towerX[DELTA_C_AXIS] - towerX[DELTA_B_AXIS];
      	Xca = towerX[DELTA_A_AXIS] - towerX[DELTA_C_AXIS];
      	Xab = towerX[DELTA_B_AXIS] - towerX[DELTA_A_AXIS];
      	Ybc = towerY[DELTA_C_AXIS] - towerY[DELTA_B_AXIS];
      	Yca = towerY[DELTA_A_AXIS] - towerY[DELTA_C_AXIS];
      	Yab = towerY[DELTA_B_AXIS] - towerY[DELTA_A_AXIS];
      I am grateful for every comment, criticism, help and idea.
        dc42 administrators @tkln
        @tkln
        1. File Math/Deviation.h is in the RRFLibraries project, which is in the include path when compiling RRF under Eclipse.
        2,3. I don't know, I haven't studied that kinematics. You have the additional complication that the effector can rotate; so the usual equations for linear delta kinematics don't apply. Your kinematics is akin to a Stewart platform, except that instead of changing the lengths of the rods you are changing the anchor positions.
        1. Yes.
        2. Xbc = towerX[DELTA_C_AXIS] - towerX[DELTA_B_AXIS] sets Xbc to the difference in the X coordinates of the C tower and the B tower.
        • tklnundefined
          tkln
          So the kinematics calculation is completed and tested with Matlab, so far everything works. Now I want to implement the refraction in the firmware. For this I would like to cut out everything unnecessary from the LinearDeltaKinematics.cpp. So that I can enter x,y,z and the three rotation angles u,w,v and the machine moves. Is it correct that I can delete everything in LinearDeltaKinematics.cpp from line 245 or does everything have to remain in place for it to work?
            @tkln you could write stub functions to replace the ones after line 245 in LinearDeltaKinematics.cpp.
            tklnundefined 1 Reply Last reply Reply Quote 1
            • tklnundefined
              tkln @dc42
              So is it correct that from line 245 everything else can be commented out? Or is any of this required for the Reprap firmware to work if I just want to test motion without any calibration?
              • tklnundefined
                tkln
                I have several questions about the LinearDeltaKinematics.h file.
                1. Is it enough to change these things in this file UsualNumTowers and "Axis names used internally" + "Derived values" for my kinematic calculation?
                static constexpr size_t UsualNumTowers = 3;
                -> static constexpr size_t UsualNumTowers = 6;```
                	// Axis names used internally
                	static constexpr size_t DELTA_A_AXIS = 0;
                	static constexpr size_t DELTA_B_AXIS = 1;
                	static constexpr size_t DELTA_C_AXIS = 2;
                	static constexpr size_t DELTA_D_AXIS = 3;
                	static constexpr size_t DELTA_E_AXIS = 4;
                	static constexpr size_t DELTA_F_AXIS = 5;
                1. Can i use SUPPORT_LINEAR_DELTA for my Six Axis Delta or do I have to change something there?
                • tklnundefined
                  tkln
                  Is it correct that machinePos[X_AXIS], machinePos[Y_AXIS], machinePos[Z_AXIS] calculates the Z coordinate of the linear slides?
                  // Calculate the Cartesian coordinates from the motor coordinates
                  void LinearDeltaKinematics::ForwardTransform(float Ha, float Hb, float Hc, float machinePos[XYZ_AXES]) const noexcept
                  	// Calculate RSUT such that x = (Uz + S)/Q, y = -(Rz + T)/Q
                  	const float R = ((Xbc * Ha) + (Xca * Hb) + (Xab * Hc)) * 2;
                  	const float U = ((Ybc * Ha) + (Yca * Hb) + (Yab * Hc)) * 2;
                  	// Note, Ka + Kb + Kc = 0 so we could calculate just two of them
                  	const float Ka = coreKa + (fsquare(Hc) - fsquare(Hb)),
                  				Kb = coreKb + (fsquare(Ha) - fsquare(Hc)),
                  				Kc = coreKc + (fsquare(Hb) - fsquare(Ha));
                  	const float S = Ka * towerY[DELTA_A_AXIS] + Kb * towerY[DELTA_B_AXIS] + Kc * towerY[DELTA_C_AXIS];
                  	const float T = Ka * towerX[DELTA_A_AXIS] + Kb * towerX[DELTA_B_AXIS] + Kc * towerX[DELTA_C_AXIS];
                  	const float A = fsquare(U) + fsquare(R) + Q2;
                  	const float minusHalfB =  Q2 * Ha
                  							+ Q * (U * towerX[DELTA_A_AXIS] - R * towerY[DELTA_A_AXIS])
                  							- (R * T + U * S);
                  	const float C = fsquare(towerX[DELTA_A_AXIS] * Q - S) + fsquare(towerY[DELTA_A_AXIS] * Q + T) + (fsquare(Ha) - D2[DELTA_A_AXIS]) * Q2;
                  	const float z = (minusHalfB - fastSqrtf(fsquare(minusHalfB) - A * C)) / A;
                  	machinePos[X_AXIS] = (U * z + S) / Q;
                  	machinePos[Y_AXIS] = -(R * z + T) / Q;
                  	machinePos[Z_AXIS] = z - ((machinePos[X_AXIS] * xTilt) + (machinePos[Y_AXIS] * yTilt));
                    @tkln, I suggest you create a new kinematics file and use the new type number that I allocated for you. Unless your kinematics uses the same inverse kinematics as for a linear delta, you will need to enable segmentation. This is done by supplying default segmentation parameters when calling the base class constructor. See the RotaryDeltaKinematics files for example.
                    tklnundefined 2 Replies Last reply Reply Quote 1
                    • tklnundefined
                      tkln @dc42
                      I understand that would be the best option for clean and orderly documentation.
                      I would like to test my kinematics first and for that I would like to have only the most necessary things in the kinematics file and keep everything as short as possible. For that I would like to not add something like autocalibration etc. in the first place.
                      • tklnundefined
                        tkln @dc42
                        Ah the tip with the Rotary Delta helped me, thanks. Now I can compare a bit.
                        • tklnundefined
                          tkln
                          Okay, last question for today, it's getting late in Germany 😄
                          Sorry for all the questions but I'm so excited to finally see the machines in action.
                          If I just want to test the 6-axis kinematics first, is it possible to create 6 axes with "Creating additional axes" and feed them with motor positions? I would then convert a Gcode with my 6-axis kinematics and then give the values to the Duet.
                          Is there a command that I do not control the ABCDEF axes using Cartesian coordinates (X10 Y10 Z5) but directly using steps (A5 B10 C10 D10 E100 F10)?
                          Is there anything against it?
                          o_lampeundefined tklnundefined 2 Replies Last reply Reply Quote 0
                          • o_lampeundefined
                            o_lampe @tkln
                            @tkln said in 6 Axis linear Delta:
                            I guess by defining them as rotatry axes and setting a propper steps/degree value, you can mimic steps . (eg. with 16 microsteps it would be 'M92 A16')
                            • tklnundefined
                              tkln @tkln
                              @tkln
                              Solution: https://forum.duet3d.com/post/315912
