    activating z-babystepping before job runs
    Using Duet Controllers
    275
    • axiomundefined
      axiom
      For me, Z-Babystepping only becomes active when a job is running. Can I also activate this before a job runs?
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @axiom
        @axiom depends if Z is homed or not. Can't babystep an unhomed one
          droftarts administrators @axiom
          @axiom do you mean on PanelDue? That has been changed in the most recent PD release. Babystepping is available at all times in DWC, after homing.
          axiomundefined 2 Replies Last reply Reply Quote 0
          • axiomundefined
            axiom @droftarts
            @droftarts I guess I have to do an update... the documentation says that the update via Duet only works for version 7i, I have a 7: https://www.cr3d.de/produkt/paneldue-7-zoll/ Does that mean I can't update via the Duet interface?
            • axiomundefined
              axiom @droftarts
              @droftarts my PanelDue has no USP connection as described in the documentation, how can I update it?
                @axiom That looks like a Duet3D 7i. You can update it from DWC if your Duet is running RepRapFirmware version 3.2 or later, and you have a V3/5i/7i PanelDue running firmware 3.2.2 or later. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue
                Edit: Also, you'll want to use the latest PanelDue beta firmware, or wait (hopefully a couple of weeks) for the full 3.5 release. Get it from https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.5.0-rc6
                axiomundefined 1 Reply Last reply Reply Quote 0
                • axiomundefined
                  axiom @droftarts
                  @droftarts Version 1.24 is currently on my PanelDue 7. Duet Web Control 3.4.5 is running on the printer....is that still possible with the PanelDue or do I have to take an intermediate step?
                    Try following these steps
                    https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue#firmware-update-via-duet
                    with this file
                    https://github.com/Duet3D/PanelDueFirmware/releases/download/3.5.0-rc6/PanelDueFirmware-logo-3.5.0-rc6-7.0i.bin
                    • axiomundefined
                      axiom @Phaedrux
                      @Phaedrux Worked great! Thank you Phaedrux!!!!👍
                      • Phaedruxundefined Phaedrux has marked this topic as solved
