    BL TOUCH NOT WORKING.
    IR Height Sensor
    1.2k
    • oldironjunkieundefined
      oldironjunkie
      I have a modified carteian printer witha duet wifi with a duex 5 board running the latest firmware. I am trying to hook up a bl touch to the printer. I currently have it installe and am able to do a self tect on the bl touch at power up and that is it. My hope is to do a mesh bed leveling on ithe printer. I have searched all the boards as to the proper hook up and config file instructions. Of the number of board looked at I have as many different hook ups and sets of instructions and none of them have worked. I am at wits end. I cannot deploy the sensor as I cannot retract the sensor. I have it hooked up to the PWM1 connector on the DUEX 5 and the power comes from the z-stop connector utilizing the 3.3V and ground pins (I think those are correct). I am looking for some sort of guidance or a direction I need to go to. This is my partial config.g file most of which was generated by the reprap configuration editor. This is as far as I have gone.
      ;Axis Limits
      M208 X5 Y5 Z0 S1 ; set axis minima
      M208 X330 Y300 Z400 S0 ; set axis maxima
      ;Endstops
      M574 X1 S1 P"!xstop" ; configure active-(high) LOW endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-(high) LOW endstop for low end on Y via pin ystop
      ;M574 Z1 S1 P"!zstop" ; configure active-(high) LOW endstop for low end on Z via pin zstop
      ;Z-Probe
      M558 P9 C"zprobe.in" H3 F100 T9000 R0.5 ; BLTouch probing settings
      M950 S0 C"duex.pwm1" ; sets the BLTouch probe ;
      G31 P500 X0 Y40 Z0 ;offset settings
      M557 X15:300 Y15:235 S50 ; define mesh grid
        droftarts administrators @oldironjunkie
        @oldironjunkie Please post a picture of your wiring on the Duet/Duex, and on the back of the BLTouch. Also post your firmware version by sending M115 and posting the response. It may also make it easier if you post your full config.g, and the deployprobe.g and retractprobe.g files.
        The only instructions we recommend you read are the official ones; see https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#bltouch
        Under 'Wiring your BLTouch', click on the "Duet 2 WiFi/Ethernet with Duex 2, Duex 5 or EBoB" tab to show the Duex wiring and configuration.
        If the BLTouch is doing the self-test, then it is getting some voltage. It would be better just to wire it to the PWM1 header on the Duex, rather than the Z endstop connector, so it gets 5V; I'm not sure it works correctly on 3.3V (the Antclabs documentation says 5V on the red wire, assuming your BLTouch is genuine).
        Also, if you have a Duex v0.9 or v0.9a board, check that you have a jumper on the "5V AUX JUMPER SELECT PINS" between the 5V AUX and 5V INT pins. Without this, the PWM connector doesn't get 5V.
        The PWM connector supplies 5V and also has a connector for GND, so you can wire:
        • the red (5V)
        • brown and black (GND, wire one or both to the same pin, they are a shared ground on the BLTouch)
        • orange PWM wire
        Make sure you are not using the E2_heater output, as it shares the PWM pin with the PWM1 output on the Duex (E2_heater is shared with PWM1, E3_heater is shared with PWM2, etc). You need to use a free heater channel.
        That leaves the white signal wire, which should go to zprobe.in. You should also use a pullup on the probe.in signal, ie: M558 P9 C"^zprobe.in" H3 F100 T9000 R0.5. Generally, DWC should show the Z probe value as 0, and will change to 1000 (usually only for a fraction of a second, so often it doesn't register in DWC) when the probe is triggered. If you see 1000, check your wiring, as you are probably feeding 3.3V (or more) into the probe pin.
        oldironjunkieundefined 2 Replies Last reply Reply Quote 0
          oldironjunkie @droftarts
          CONNECTED TO THE PWM1 HEADER:
          GREEN WIRE CONNECTS TO THE BROWN WIRE ON THE BL TOUCH
          BLUE WIRE CINNECTS TO THE ORANGE WIRE ON THE BL TOUCH
          YELLOW WIRE CONNECTS TO THE YELLOW WIRE ON THE BL TOUCH
          CONNECTED TO Z BROBE HEADER:
          BLACK WIRE CONNECTS TOT THE BLACK WIRE ON THE BL TOUCH
          RED WIRE CONNECTS TO THE WHITE WIRE ON THE BL TOUCH
          THIRD POSITION IS BLANK
          GENUINE BL TOUCH SMART VER.2.0
          FIRMWARE VERSION
          CONFIG .G FILE
          droftartsundefined 2 Replies Last reply Reply Quote 0
            @oldironjunkie You can copy the text of your config.g (or any other file) and paste it into your reply here. Extra points if you put it between code tabs. Posting a picture of your config.g makes it much harder to quote parts that need to change.
            oldironjunkieundefined 1 Reply Last reply Reply Quote 0
              @droftarts I forgot to mention that the only things changed in the config file is that the extruder drive was remapped to #4 driver ( #3 driver is not working/shorted out with my new extruder which I replaced)
              The Z probe has been commented out.
              The tool heat was commented out and replaced by a PID setting for the tool.
                @oldironjunkie You have connected the BLTouch to the Z endstop, not the Z-probe header. See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#wiring-diagram
                  @droftarts
                  ; generated by RepRapFirmware Configuration Tool v3.3.3 on Wed Sep 29 2021 16:53:30 GMT-0500 (Central Daylight Time)
                  ;General preferences
                  M575 P1 S1 B57600                                               ; enable support for PanelDue
                  G90                                                             ; send absolute coordinates...
                  M83                                                             ; ...but relative extruder moves
                  M550 P"OLDIRON PRINTER"                                         ; set printer name
                  ;Network
                  M552 S1                                                         ; enable network
                  M586 P0 S1                                                      ; enable HTTP
                  M586 P1 S0                                                      ; disable FTP
                  M586 P2 S0                                                      ; disable Telnet
                  ;Drives
                  M569 P0 S0                                                       ; physical drive 0 goes backwards
                  M569 P1 S1                                                       ; physical drive 1 goes forwards
                  M569 P2 S0                                                       ; physical drive 2 goes backwards
                  M569 P3 S0                                                       ; physical drive 3 goes backwards
                  M569 P4 S1													     ; physical drive 4 goes forwards
                  ;M569 P3 S0                                                      ; physical drive 3 goes backwards
                  M584 X0 Y1 Z2 E4:4:4:4                                           ; set drive mapping
                  M350 X16 Y16 Z16 E8:8:8:8 I1                                 ; configure microstepping with interpolation
                  M92 X76.5 Y80.16 Z400.00 E942.00:454.00:454.00:454.00            ; set steps per mm
                  M566 X1100.00 Y1100.00 Z900.00 E1600.00:1600.00:1600.00:1600.00  ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z1500.00 E5000.00:3000.00:3000.00:3000.00 ;set maximum speeds (mm/min)
                  M201 X1000.00 Y1000.00 Z350.00 E600.00:600.00:600.00:600.00      ; set accelerations (mm/s^2)
                  M906 X1000 Y1000 Z1000 E800:800:800:800 I50                      ; set motor currents (mA) and motor idle factor in per cent
                  M84 S300                                                         ; Set idle timeout
                  ;Axis Limits
                  ;Endstops
                  ;Z-Probe
                  M950 S0 C"duex.pwm1"										    ; sets the BLTouch probeM558 P9 C"zprobe.in" H3 F100 T9000 R0.5	                        ;
                  ;Heaters
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138                  ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                                           ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00                                                ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                         ; map heated bed to heater 0
                  M143 H0 S120                                                    ; set temperature limit for heater 0 to 120C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4138                   ; configure sensor 1 as thermistor on pin e0temp
                  M950 H2 C"e0heat" T1                                            ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H2 R2.584 C226.4 D8.23 S.4 V24.3							;tool heat
                  ;M307 H1 B1 S.70                                                ; enable bang-bang mode for heater  and set PWM limit
                  M143 H2 S350                                                    ; set temperature limit for heater 1 to 350C
                  ;Fans
                  M950 F0 C"fan0"                                                 ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 s0.5 H-1 Q500                                           ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                                            ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S0.5 H-1 T45                                            ; set fan 1 value. Thermostatic control is turned on
                  ;Tools
                  M563 P1 D1 H2 F0                           			 			; define tool 1
                  ;M572 D0 S0.1													;ADDED PRESSURE ADVANCE SETTING
                  G10 P1 R0 S0
                  M501                                                            ; load saved parameters from non-volatile memory
                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; set voltage thresholds and actions to run on power loss
                  T1                                                              ; select first tool
                  G10 P0 X0 Y0 Z0                                           		; set tool 0 axis offsets
                    @droftarts Wi change as necessary later today. Have some appointments I need to make ths afternoon.
                      @oldironjunkie See where the white and black wires go here?
                        @droftarts I have accomplished all the items. Rehooked up the power and ground to the Z-probe header. Rechecked all the wiring. Self test still peforms flawlessly. The static tect to check the probe failed. The probe will not deploy with either the M401 or the M280 P0 S10 commands. I rechecked the voltages all ok. Question I have is this. Do I need to do anything with the Z stop header. I currently have a z stop intsalled and hooked up (needed to print something asap).
                        ;Network
                        ;Drives
                        M92 X79.68 Y79.44 Z400.00 E8440:454.00:454.00:454.00             ; set steps per mm
                        M566 X900.00 Y900.00 Z900.00 E1600.00:1600.00:1600.00:1600.00    ; set maximum instantaneous speed changes (mm/min)
                        M203 X4000.00 Y4000.00 Z1500.00 E4000.00:4000.00:4000.00:4000.00 ;set maximum speeds (mm/min)
                        ;Axis Limits
                        ;Endstops
                        ;Z-Probe
                        M950 S0 C"duex.pwm1"                                            ; Duet 2 WiFi/Ethernet + DueX2/5
                        M558 P9 C"^zprobe.in" H5 F120 T6000 							; Duet 2 WiFi/Ethernet, DueX2/5
                        G31 X40 Y0 Z2.5 P25												;probe offsets, trigger height and trigger value
                        M557 X15:300 Y15:235 S30                                        ;define mesh grid
                        ;Heaters
                        M307 H2 R2.584 C226.4 D8.23 S.5 V24.3							;tool heat
                        ;Fans
                        M106 P0 S.75 H-1 Q500                                           ; set fan 0 value. Thermostatic control is turned off
                        M106 P1 S.75 H-1 Q500                                           ; set fan 1 value. Thermostatic control is turned on
                        ;Tools
                        M572 D0 S0.06									                ;ADDED PRESSURE ADVANCE SETTING
                        G10 P1 R0 S0
                        ; deployprobe.g
                        M280 P0 S10 				;code for deploying the Z probe
                        ; retractprobe.g
                        M280 P0 S90     			;code for retracting the Z probe
                        Thye last 2 commands are in the system directory (is that where they belong)
                        Any other ideas?
                          @droftarts Sorry I sent the wrong config.g file hee is the correct one.
                          ;Network
                          ;Drives
                          ;Axis Limits
                          ;Endstops
                          ;Z-Probe
                          M558 P9 C"^zprobe.in" H3 F100 T9000 R0.5						; Duet 2 WiFi/Ethernet, DueX2/5
                          ;Heaters
                          ;Fans
                          ;Tools
                          G10 P1 R0 S0
                            @oldironjunkie did you do this?
                              @droftarts there is a jumper between pins marked "5V INT" and "5V AUX" . the header is between the endstop E2-E6 headers and the thermistor E2-E6 headers
                                @droftarts I also checked the voltage manuall with a meter and I have 4.96V dc
                                  @oldironjunkie Can you post pictures of how it is wired now?
                                  Can you send M98 P"config.g" and post the response from the console?
                                  Edit: check the continuity of each of the wires, to make sure all of them are making a connection.
                                    A Former User
                                    This post is deleted!
                                      oldironjunkie
                                      @droftarts Thanks for the response. I id find a bad connection in the tiny 5 pin factory connection on the BL touch. I fixed it by replacing the harnes with a known good one. Rechecked all and it is ok. The probe now expends and retracts with the M401 and M402 commands as it should. I did the calibration set up and I can home all axis. @ questions.How do I get to home the X and Y at the endstops in th upper right corner (where it is now) but I cannot get the z to home to the pin unless I run a G30 from the console. Also at the same time I would like to probe the z in the center of the bed (A150 and Y150) as this is where most of my prints start. Below are my homeall.g file and homez.g files. I only added the commands I need. Not sure what I need to add or comment out. Also once I get it al working correctly where do I enter the offset from the Bl touch to the nozzle. It is a consistent .59. Sorry about the questions but I am completely at a loss at this time.
                                      ; homeall.g
                                      ; called to home all axes
                                      G1 H2 Z5 F6000          ; lift Z relative to current position
                                      G1 H1 X-302 Y-302 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X5 Y5 F6000       ; go back a few mm
                                      G1 H1 X-302 Y-302 F180  ; move slowly to X and Y axis endstops once more (second pass)
                                      G30 S-1
                                      ; homez.g
                                      ; called to home the Z axis
                                      M98 P"homeall.g"                             ; Call the home X & Y macro to home those axes first
                                      M98 P"deployprobe.g"                          ; Called to extend the BL-Touch probe pin to allow probing to take place
                                      G30 S-1                                         ; Home the Z axis by probing the bed
                                      M98 P"retractprobe.g"
                                      • oliofundefined
                                        oliof @oldironjunkie
                                        @oldironjunkie 2 questions
                                        1. why are your macros called extendpin.g and not deployprobe.g? Likewise for retractpin.g and retractprobe.g...
                                        2. Why are you not using M401/M402 but M98 P"deployprobe.g" and M98 P"retractprobe.g"?
                                        A Former User? oldironjunkieundefined 2 Replies Last reply Reply Quote 1
                                          A Former User @oliof
                                            oldironjunkie @oliof
                                            @oliof I was using those names beacause that is what I was sent by a friend of mine. It has changes since. I will post the final files once it is done, working and tested. I am in the process of doing that now but unfortunatly life just gets in the way.
