    Duet 3 Mini 5+ no 24v on OUT 1 2 5 6
    552
    • SpeedyDadundefined
      SpeedyDad
      I'm installing a Duet 3 Mini 5+ and have no voltage on OUT1, OUT 2, OUT5, or OUT6. Are they all connected? The diagram shows fused. Fused in what way? OUT3 and OUT4 have 24v (I changed the jumper).
      oliofundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @SpeedyDad
        @SpeedyDad see
        https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#description-of-connections
        All OUTS should be connected. The fuses are blade fuses like on cars, you can see them on the product image on the same page I linked to (the two pieces marked 10 and 15):
        SpeedyDadundefined 1 Reply Last reply Reply Quote 1
        • gloomyandyundefined
          gloomyandy @SpeedyDad
          @SpeedyDad How are you measuring the voltage? In particular what pin/connector are you using for the negative side of the measurement?
          SpeedyDadundefined 1 Reply Last reply Reply Quote 0
            SpeedyDad @oliof
            @oliof Yup. Both fuses are visually fine and tested for continuity.
              SpeedyDad @gloomyandy
              @gloomyandy Testing with a multimeter. Positive lead on the positive pin and negative lead on the negative pin f each of the OUT connectors. The positive leads are the ones closest to the side of the board with the VIN screw terminals.
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
                @SpeedyDad The negative side of those connectors are switched so will be floating if you have not programmed them to be on. If you want to check for a +ve voltage on the out +ve pin use the main board gnd for the -ve side of your multimeter.
                SpeedyDadundefined 2 Replies Last reply Reply Quote 0
                  @gloomyandy Ah, thanks. That explains it. Still used to my DuetWifi where everything is just on. It is for my board fan so maybe I'll just simplify it and wire it directly to the main VIN and GND.
                    @gloomyandy said in Duet 3 Mini 5+ no 24v on OUT 1 2 5 6:
                    OK, sorry for being a noob but how do I "switch" the negative pin on? I've looked through the documentation but must have missed it.
                    I tried the M950 followed by the M106 but get "Error: Pin 'out5' is not free"
                      A Former User @SpeedyDad
                      This post is deleted!
                        SpeedyDad @A Former User
                        @Herve_Smith said in Duet 3 Mini 5+ no 24v on OUT 1 2 5 6:
                        @SpeedyDad said in Duet 3 Mini 5+ no 24v on OUT 1 2 5 6:
                        looks like you are attempting to control a fan, if so This documentation should help you
                        Yes, I know that. That's where I got the info to use M950 and M106 as stated above
                            then please show the EXACT code you have created from reading that so we can see what you have done.
                            Pretty much copy/pasted the lines from the connecting a fan page and substituted my fan number and the pin number.
                            M950 F2 C"out5" Q500 ; create fan 0 on pin out3 and set its frequency
                            M106 P2 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
