    RRF can't "see" any of the stepper drivers, over night.
    1.2k
    • Exerqtorundefined
      Exerqtor @gloomyandy
      @gloomyandy Sure, config:
      ; Configuration file for Duet 3 Mini 5+ with Duet 3 Expansion Mini 2+ and 1LC (firmware version 3.5)
      ; For E3D Revo Micro, Bondtech LGX Lite & Voron TAP  --------------------------
      ; Basic setup
      M575 P1 S1 B57600                                                              ; Enable support for PanelDue
      ; Debugging
      M111 S0        ; Debugging off (S0) or on (S1)
      G21        ; Work in millimetres
      G90        ; Send absolute coordinates...
      M83        ; Set extruder to relative mode
      M550 P"Voron Trident"                                                          ; Set printer name
      G4 S2        ; Wait a moment for the CAN expansion boards to start
      ; Kinematics
      M669 K1 X-1:-1:0 Y1:-1:0 Z0:0:1                                                ; Select CoreXY mode and set kinematics matrix
      M552 S1        ; Enable network
      G4 S1        ; Wait a second
      M586 P0 S1        ; Enable HTTP (for DWC)
      M586 P1 S0        ; Enable FTP (for remote backups etc.) S0 / S0 = disabled / enabled
      M586 P2 S0        ; Disable Telnet
      ; Driver config
      ;          --- Drive map ---
      ; (While looking at the printer top down)
      ;             0.0-----0.1
      ;              |  0.2  |
      ;              |0.3|0.4|
      ;                Front
      ; Drives for XY
      M569 P0.0 S0        ; X (B) (physical drive 0.0) goes backwards
      M569 P0.1 S0        ; Y (A) (physical drive 0.1) goes backwards
      ; Drives for Z
      M569 P0.2 S0        ; Z1 (physical drive 0.2) goes backwards
      M569 P0.3 S0        ; Z2 (physical drive 0.3) goes backwards
      M569 P0.4 S0        ; Z3 (physical drive 0.4) goes backwards
      ; Drive for extruder
      M569 P121.0 S0        ; E (physical drive 121.0) goes backwards
      ; Motor mapping and steps per mm
      M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0                                             ; Set drive mapping
      M350 X16 Y16 Z16:16 E16 I1                                                     ; Configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00                                                      ; Set XYZ steps per mm (1.8deg motors)
      M92 E568.83        ; Set Extruder steps per mm (Bondtech LGX Lite 562 stock)
      ; Drive currents
      M906 X1750 Y1750 I40                                                           ; Set XY motor currents (mA) and ide current percentage
      M906 Z850 I40        ; Set Z motor currents (mA) and ide current percentage
      M906 E550 I40        ; Set E motor currents (mA) and ide current percentage
      M84 X Y Z E0 S30                                                               ; Set idle timeout
      ; Axis accelerations and speeds
      M566 X700.00 Y700.00 Z30.00 P1                                                 ; Set maximum instantaneous speed changes (mm/min) and jerk policy
      M203 X18000.00 Y18000.00 Z900.00                                               ; Set maximum speeds (mm/min)
      M201 X7000.00 Y7000.00 Z150.00                                                 ; Set accelerations (mm/s²)
      ; Extruder accelerations and speeds
      M566 E8000.00 P1                                                               ; Set maximum instantaneous speed changes (mm/min) and jerk policy
      M203 E15000.00        ; Set maximum speeds (mm/min)
      M201 E1800.0        ; Set accelerations (mm/s²)
      ; Reduced accelerations
      M201.1 X500 Y500 Z80 E500                                                      ; Set reduced acceleration for special move types (mm/s²)
      ; Printing and travel accelerations
      M204 P5000 T7000                                                               ; Set printing acceleration and travel accelerations (mm/s²)
      ; Movement
      M208 X-1 Y-10 Z0 S1                                                            ; Set axis minimal
      M208 X352 Y350 Z330 S0                                                         ; Set axis maximal
      M574 Z0 P"nil"        ; No endstop
      ; Z-probe (Voron TAP)
      M558 K0 P8 C"^121.io2.in" H2 R0.2 F300:180 T18000 A1 S0.03                     ; Set Z probe number ,type, input pin, dive height,recovery time, feed rate, travel speed, max probes & tolerance when probing multiple times
      G31 K0 P500 X0 Y0 Z-1.170                                                      ; Set Z probe trigger value, offset and trigger height (higher Z value = nozzle closer to bed)
      ; Bed leveling
      ;        --- Pivot point map ---
      ;              |   1   |
      ;              | 3 | 2 |
      ;                Front
      M671 X175:362:-49 Y390:12:12 S10                                               ; Leadscrew locations (Rear, Right, Left) M671 X175:388:-38 Y416.6:1.5:1.5 S10
      M557 X10:340 Y10:340 P12                                                       ; Define default mesh grid ( positions include the Z offset!)
      ; Accelerometer & Input shaping
      M955 P121.0 I05        ; Configure accelerometer
      M593 P"zvdd" F39.75 S0.0                                                       ; Use ZVDDD input shaping to cancel ringing at 41.8Hz with 0.0 damping factor
      ;  Heaters
      ; Bed heater
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"                            ; Configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0 Q5                                                          ; Create bed heater output on out0, map it to sensor 0 and set PWM frequency(Hz)
      M307 H0 B0 S1.00                                                               ; Disable bang-bang mode for the bed heater and set PWM limit
      M140 H0        ; Map heated bed to heater 0
      M143 H0 S110        ; Set temperature limit for heater 0 to 110°C
      M143 H0 A2 C0 S110                                                             ; Make sure bed heater stays below 110°C
      M143 H0 A1 C0 S125                                                             ; Make sure bed heater shuts down at 125°C
      ; Hodend heater
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"        ; Configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                                                         ; Create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                                               ; Disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300        ; Set temperature limit for heater 1 to 300°C
      ; Chamber heater
      M308 S4 P"121.temp1" Y"thermistor" T9600 B3950 A"Chamber"                      ; Configure sensor 4 as thermistor on pin e1temp
      M308 S2 Y"mcu-temp" A"MCU"                                                     ; Configure sensor 2 as MCU temperature
      M912 P0 S-2.9        ; MCU temp calibration parameters
      M308 S3 Y"drivers" A"DRIVERS"                                                  ; Configure sensor 3 as drivers temperature
      ;  Fans
      ;Part cooling
      M950 F0 C"121.out1" Q500                                                       ; Create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1 C"Part Cooling"                                                 ; Set fan 0 value. Thermostatic control is turned off
      ;Hotend fan
      M950 F1 C"121.out2" Q500                                                       ; Create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1 T45 C"Hotend Fan"                                                ; Hotend fan @ 100%, turns on if temperature sensor 1 reaches 45°C
      ;Electronics fan
      M950 F2 C"out5" Q500                                                           ; Create fan 2 on pin out3 and set its frequency
      M106 P2 L0.15 H2:3 T45:50 C"Electronics Fans"                                  ; Electronics fans start @ 30% when temperature sensor 2 reaches 45°C or sensor 3 (drivers report over temp)
      ;Exhaust fan
      M950 F3 C"out6" Q500                                                           ; Create fan 3 on pin out4 and set its frequency
      M106 P3 H-1 Q500 C"Exhaust fan"                                                ; Exhaust fan 3 value. Thermostatic control is turned off
      M563 P0 S"Revo Micro" D0 H1 F0                                                 ; Define tool 0
      G10 P0 X0 Y0 Z0        ; Set tool 0 axis offsets
      G10 P0 R0 S0        ; Set initial tool 0 active and standby temperatures to 0°C
      ;M563 P1 D1 H1 F0                                                               ; Define tool 1
      ;G10 P1 X0 Y0 Z0        ; Set tool 1 axis offsets
      ;G10 P1 R0 S0        ; Set initial tool 1 active and standby temperatures to 0°C
      ;M563 P2 D2 H1 F0                                                               ; Define tool 2
      ;G10 P2 X0 Y0 Z0        ; Set tool 2 axis offsets
      ;G10 P2 R0 S0        ; Set initial tool 2 active and standby temperatures to 0°C
      ;M563 P3 D3 H1 F0                                                               ; Define tool 3;;
      ;G10 P3 X0 Y0 Z0        ; Set tool 3 axis offsets
      ;G10 P3 R0 S0        ; Set initial tool 3 active and standby temperatures to 0°C
      ; Filament monitoring
      ; Monitor before extruder (runout sensor)
      M591 P1 C"121.io0.in" S1 D0                                                    ; Filament monitor connected to 121.io0.in
      ; Monitor between extruder & hotend
      ;M591 P1 C"121.io0.in" S1 D0                                                    ; filament monitor connected to 121.io0.in
      ;  Other
      M950 P0 C"out2"        ; Create output Port0 attached to out2 connector for LED lights
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                             ; Set voltage thresholds and actions to run on power loss
      M572 D0 S0.0        ; Disable Pressure Advance
      M98 P"/sys/lib/init.g"                                                         ; Iniate external configs
      M501        ; Load config-override.g
      T0        ; Select tool 0
      ;M929 P"eventlog.txt" S1                                                        ; Start logging warnings to file eventlog.txt
      ;M929 P"infolog.txt" S2                                                         ; Start logging info to file infolog.txt
      M929 P"debuglog.txt" S3                                                        ; Start logging debug info to file debuglog.txt
      Response when deploying M98 p"config.g":
      20.8.2023, 12:27:53	Debug from 121: temp timeout on sensor 1
                              Warning: Heater 1 predicted maximum temperature at full power is 543°C
      20.8.2023, 12:27:52	M98 p"config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Accelerometer 121:0 type LIS3DH with orientation 5 samples at 1344Hz with 10-bit resolution
      Regarding the power rail indicator LED's, all are on (and bright).
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @Exerqtor
        @Exerqtor Might also be worth posting a high res picture of the board (when powered on so any leds can be checked).
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          @gloomyandy said in RRF can't "see" any of the stepper drivers, over night.:
          Tried my best with the pics:
          (Regarding the plug on IO_0 / PanelDue being a JST connector, it's just temporary until I get some 5pin molex connectors.)
          I should add that I've tried to reinstal RFF 3.5b4 with no luck, roll back to 3.5b2 with no luck and now i'm back on 3.5b4 since it didn't help.
          Could totally whiping the firmware of the board and doing a fresh install with bosa maybe be a way to go? 🤔
            dc42 administrators @Exerqtor
            @Exerqtor as RRF has failed to find any of the stepper drivers, it looks as though UART communication with them has failed. Here are some possible reasons for that:
            • No power reaching the stepper drivers. Power is reaching the VIN measurement circuit, so the fuse should be OK.
            • Something has gone wrong with the circuitry that interfaces to the drivers via UART.
            • One of the drivers has failed and in doing so has shorted out the UART signal, thereby interrupting the comms with the other drivers too.
            Does any of the TMC2209 stepper driver chips show signs of damage?
            Exerqtorundefined 2 Replies Last reply Reply Quote 0
            • Exerqtorundefined
              Exerqtor @dc42
              @dc42 I've had a good look at them and i can't see any damage, misscoloring, cracks etc. That goes for the rest of the board too TBH. everything looks mint, can't smell any magic smoke residue either.
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 said in RRF can't "see" any of the stepper drivers, over night.
                Here is some macro pictures of the drivers:
                • Exerqtorundefined
                  Exerqtor @Exerqtor
                  Don't know if it's some kind of measurements or tests i should do, or if the next step should be a waranty return or something?
                    Can you disconnect all wiring except for USB?
                    Does anything get hot to the touch shortly after connecting usb power?
                    • Exerqtorundefined
                      Exerqtor @Phaedrux
                      @Phaedrux said in RRF can't "see" any of the stepper drivers, over night.:
                      I'll try it this afternoon. Regarding heat i haven't noticed anything, either right after turning the printer on or while standing there idle. I haven't got a thermal camera so i can't say it ain't any "blips" with hot spots when it boots though.
                      Oook, that's fucking weird (pardon my french)... I just disconnected everything except the CAN connector, bed (out0), wifi antenna & power to the board. Fired it up, and the problem was still there.
                      So i pulled the whole board out of the machine and powered it by USB with only the wifi antenna connected, now all drivers show up again:
                      M122
                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Board ID: DXGUZ-U196U-D65J0-40KMN-1Y03Z-RKST9
                      Used output buffers: 1 of 40 (18 max)
                      Error in macro line 56 while starting up: Response timeout: CAN addr 121, req type 6018, RID=0
                      Static ram: 102996
                      Dynamic ram: 123720 of which 40 recycled
                      Never used RAM 12444, free system stack 146 words
                      Tasks: NETWORK(1,ready,6.3%,243) HEAT(3,nWait,0.0%,343) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,939) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.0%,124) MAIN(1,running,43.8%,704) IDLE(0,ready,49.1%,29) AIN(4,delaying,0.8%,274), total 100.0%
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 00:00:48 ago, cause: power up
                      Last software reset at 2023-08-20 10:59, reason: User, Gcodes spinning, available RAM 9188, slot 2
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 48829, completed 48829, timed out 0, errs 0
                      MCU temperature: min 21.7, current 22.6, max 25.1
                      Supply voltage: min 0.5, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
                      Heap OK, handles allocated/used 99/31, heap memory allocated/used/recyclable 2048/968/508, gc cycles 0
                      Events: 0 queued, 0 completed
                      Driver 0: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 5: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 6: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2023-08-23 17:24:30
                      Cache data hit count 44358833
                      Slowest loop: 5.58ms; fastest: 0.17ms
                      === Storage ===
                      Free file entries: 18
                      SD card longest read time 3.7ms, write time 4.4ms, max retries 0
                      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                      no step interrupt scheduled
                      === DDARing 0 ===
                      === DDARing 1 ===
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC is idle in state(s) 0
                      Daemon is doing "G4 S1        " in state(s) 0 0, running macro
                      Aux2 is idle in state(s) 0
                      File2 is idle in state(s) 0
                      Queue2 is idle in state(s) 0
                      Q0 segments left 0, axes/extruders owned 0x0000803
                      Code queue 0 is empty
                      Code queue 1 is empty
                      === CAN ===
                      Messages queued 409, received 0, lost 0, boc 0
                      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 17), ts 245/0/0
                      Tx timeouts 0,0,244,19,0,143 last cancelled message type 30 dest 127
                      === Network ===
                      Slowest loop: 7.01ms; fastest: 0.00ms
                      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                      HTTP sessions: 2 of 8
                      = WiFi =
                      Interface state: active
                      Module is connected to access point
                      Firmware version 2.1beta4
                      MAC address d8:bf:c0:14:e6:36
                      Module reset reason: Power up, Vcc 3.32, flash size 2097152, free heap 43128
                      WiFi IP address 192.168.10.50
                      Signal strength -51dBm, channel 1, mode 802.11n, reconnections 0
                      Clock register 00002001
                      I powered it down again and started inspecting the board, and it looks like it's some kind of ressidue (like possibly solder paste or something) in the general area around Driver0 and it's surrouding caps, resistors etc.
                      I'll try to take a picture of the above mentioned ressidue, and try to clean just that spot. Then put it back in the machine and see what happens.
                      • Exerqtorundefined
                        Exerqtor @Phaedrux
                        @Phaedrux Ok, so I cleaned the board and powered it by USB again and all still seemed good..
                        So i put it back in the printer, ONLY connecting power and the wifi antenna. Booted, and: no drivers.
                          Can you connect it to VIN for power when outside the printer and see if it still happens? And power by USB inside the printer?
                          Is there something shorting on the back of the board when it's installed?
                          Is there some mounting pressure flex when installed?
                          Exerqtorundefined 1 Reply Last reply Reply Quote 1
                          • Exerqtorundefined
                            Exerqtor @Phaedrux
                            @Phaedrux Yeah i can, and it's the same exact behaviour.
                            So it can only see the drivers if not powered by VIN.
                            Regarding how it's mounted, it's mounted with the stock Voron board mounts and click-on DIN rail mounts. Both printed in ABS, with ABS washers between the PCB and screws on the front side.
                            Nothing shorting it while inside the printer either.
                            When i had the board out of the machine it was still screwed on to the mounts, so twisting/pressure ain't the issue.
                              Phaedrux Moderator @Exerqtor
                              @Exerqtor said in RRF can't "see" any of the stepper drivers, over night.:
                              Can it see (and move) the drivers if powered by vin and usb at the same time? Be careful with USB ground loops.
                              • Exerqtorundefined
                                Exerqtor @Phaedrux
                                @Phaedrux i haven't tried that since i thought that was a big no-no 🤣 i can try it this afternoon. What precautions should i take in regard to USB ground loops?
                                  @Exerqtor See https://docs.duet3d.com/User_manual/Overview/USB_ground_loops
                                  • Exerqtorundefined
                                    Of course it's covered in the docs, the "one" place i didn't look 🤦‍♂️
                                    Ok so running the usb to a laptop running on battery sounds like the safest and easiest way to go. I'll do that later and report how it turns out.
                                    • Exerqtorundefined
                                      Exerqtor @Phaedrux
                                      I just hooked up both VIN & powered it from USB via a laptop running on the battery. No drivers visible.
                                      M122
                                      Used output buffers: 10 of 40 (24 max)
                                      Static ram: 102996
                                      Dynamic ram: 124276 of which 16 recycled
                                      Never used RAM 11912, free system stack 156 words
                                      Tasks: NETWORK(2,nWait,17.1%,215) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,0.3%,110) MAIN(1,running,81.5%,704) IDLE(0,ready,0.2%,29) AIN(4,delaying,0.8%,266), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:02:32 ago, cause: software
                                      Last software reset at 2023-08-24 17:31, reason: User, Gcodes spinning, available RAM 12404, slot 0
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      MCU revision 3, ADC conversions started 152189, completed 152189, timed out 0, errs 0
                                      MCU temperature: min 24.4, current 27.0, max 27.0
                                      Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/588/192, gc cycles 2
                                      Driver 0: not present
                                      Driver 1: not present
                                      Driver 2: not present
                                      Driver 3: not present
                                      Driver 4: not present
                                      Driver 5: not present
                                      Driver 6: not present
                                      Date/time: 2023-08-24 17:34:05
                                      Cache data hit count 252956637
                                      Slowest loop: 11.79ms; fastest: 0.14ms
                                      === Storage ===
                                      SD card longest read time 4.5ms, write time 4.4ms, max retries 0
                                      === DDARing 0 ===
                                      === DDARing 1 ===
                                      Heater 1 is on, I-accum = 0.0
                                      === Filament sensors ===
                                      Extruder 0 sensor: no filament
                                      === CAN ===
                                      Messages queued 1145, received 2609, lost 0, boc 0
                                      Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 18 (min 18), ts 636/636/0
                                      Tx timeouts 0,0,0,0,0,0
                                      === Network ===
                                      Slowest loop: 25.23ms; fastest: 0.06ms
                                      HTTP sessions: 1 of 8
                                      = WiFi =
                                      Module reset reason: Power up, Vcc 3.31, flash size 2097152, free heap 43132
                                      Signal strength -49dBm, channel 1, mode 802.11n, reconnections 0
                                        Quite strange. When and where was the board purchased?
                                        • Exerqtorundefined
                                          Exerqtor @Phaedrux
                                          @Phaedrux Yeah it's pretty weird, especially since it worked perfectly one evening, then this just happens while standing idle over night.
                                          I just bought the board second hand from a dude here in Norway. He purchased the board from E3D in november 2022 (i have a printout of the order confirmation mail he got, with order number).
                                            Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
