    RRF can't "see" any of the stepper drivers, over night.
    1.2k
    • Exerqtorundefined
      Exerqtor @Exerqtor
      Don't know if it's some kind of measurements or tests i should do, or if the next step should be a waranty return or something?
        Can you disconnect all wiring except for USB?
        Does anything get hot to the touch shortly after connecting usb power?
        Exerqtorundefined 2 Replies Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @Phaedrux
          @Phaedrux said in RRF can't "see" any of the stepper drivers, over night.:
          I'll try it this afternoon. Regarding heat i haven't noticed anything, either right after turning the printer on or while standing there idle. I haven't got a thermal camera so i can't say it ain't any "blips" with hot spots when it boots though.
          Oook, that's fucking weird (pardon my french)... I just disconnected everything except the CAN connector, bed (out0), wifi antenna & power to the board. Fired it up, and the problem was still there.
          So i pulled the whole board out of the machine and powered it by USB with only the wifi antenna connected, now all drivers show up again:
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
          Board ID: DXGUZ-U196U-D65J0-40KMN-1Y03Z-RKST9
          Used output buffers: 1 of 40 (18 max)
          Error in macro line 56 while starting up: Response timeout: CAN addr 121, req type 6018, RID=0
          Static ram: 102996
          Dynamic ram: 123720 of which 40 recycled
          Never used RAM 12444, free system stack 146 words
          Tasks: NETWORK(1,ready,6.3%,243) HEAT(3,nWait,0.0%,343) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,939) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.0%,124) MAIN(1,running,43.8%,704) IDLE(0,ready,49.1%,29) AIN(4,delaying,0.8%,274), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:48 ago, cause: power up
          Last software reset at 2023-08-20 10:59, reason: User, Gcodes spinning, available RAM 9188, slot 2
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 48829, completed 48829, timed out 0, errs 0
          MCU temperature: min 21.7, current 22.6, max 25.1
          Supply voltage: min 0.5, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
          Heap OK, handles allocated/used 99/31, heap memory allocated/used/recyclable 2048/968/508, gc cycles 0
          Events: 0 queued, 0 completed
          Driver 0: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 6: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2023-08-23 17:24:30
          Cache data hit count 44358833
          Slowest loop: 5.58ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 18
          SD card longest read time 3.7ms, write time 4.4ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
          no step interrupt scheduled
          === DDARing 0 ===
          === DDARing 1 ===
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is doing "G4 S1        " in state(s) 0 0, running macro
          Aux2 is idle in state(s) 0
          File2 is idle in state(s) 0
          Queue2 is idle in state(s) 0
          Q0 segments left 0, axes/extruders owned 0x0000803
          Code queue 0 is empty
          Code queue 1 is empty
          === CAN ===
          Messages queued 409, received 0, lost 0, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 17), ts 245/0/0
          Tx timeouts 0,0,244,19,0,143 last cancelled message type 30 dest 127
          === Network ===
          Slowest loop: 7.01ms; fastest: 0.00ms
          Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 2 of 8
          = WiFi =
          Interface state: active
          Module is connected to access point
          Firmware version 2.1beta4
          MAC address d8:bf:c0:14:e6:36
          Module reset reason: Power up, Vcc 3.32, flash size 2097152, free heap 43128
          WiFi IP address 192.168.10.50
          Signal strength -51dBm, channel 1, mode 802.11n, reconnections 0
          Clock register 00002001
          I powered it down again and started inspecting the board, and it looks like it's some kind of ressidue (like possibly solder paste or something) in the general area around Driver0 and it's surrouding caps, resistors etc.
          I'll try to take a picture of the above mentioned ressidue, and try to clean just that spot. Then put it back in the machine and see what happens.
          • Exerqtorundefined
            Exerqtor @Phaedrux
            @Phaedrux Ok, so I cleaned the board and powered it by USB again and all still seemed good..
            So i put it back in the printer, ONLY connecting power and the wifi antenna. Booted, and: no drivers.
              Can you connect it to VIN for power when outside the printer and see if it still happens? And power by USB inside the printer?
              Is there something shorting on the back of the board when it's installed?
              Is there some mounting pressure flex when installed?
              Exerqtorundefined 1 Reply Last reply Reply Quote 1
              • Exerqtorundefined
                Exerqtor @Phaedrux
                @Phaedrux Yeah i can, and it's the same exact behaviour.
                So it can only see the drivers if not powered by VIN.
                Regarding how it's mounted, it's mounted with the stock Voron board mounts and click-on DIN rail mounts. Both printed in ABS, with ABS washers between the PCB and screws on the front side.
                Nothing shorting it while inside the printer either.
                When i had the board out of the machine it was still screwed on to the mounts, so twisting/pressure ain't the issue.
                  Phaedrux Moderator @Exerqtor
                  @Exerqtor said in RRF can't "see" any of the stepper drivers, over night.:
                  Can it see (and move) the drivers if powered by vin and usb at the same time? Be careful with USB ground loops.
                  • Exerqtorundefined
                    Exerqtor @Phaedrux
                    @Phaedrux i haven't tried that since i thought that was a big no-no 🤣 i can try it this afternoon. What precautions should i take in regard to USB ground loops?
                    gloomyandyundefined 1 Reply Last reply Reply Quote 0
                    • gloomyandyundefined
                      gloomyandy @Exerqtor
                      @Exerqtor See https://docs.duet3d.com/User_manual/Overview/USB_ground_loops
                      • Exerqtorundefined
                        Exerqtor @gloomyandy
                        @gloomyandy said in RRF can't "see" any of the stepper drivers, over night.:
                        Of course it's covered in the docs, the "one" place i didn't look 🤦‍♂️
                        Ok so running the usb to a laptop running on battery sounds like the safest and easiest way to go. I'll do that later and report how it turns out.
                        • Exerqtorundefined
                          Exerqtor @Phaedrux
                          I just hooked up both VIN & powered it from USB via a laptop running on the battery. No drivers visible.
                          M122
                          Used output buffers: 10 of 40 (24 max)
                          Static ram: 102996
                          Dynamic ram: 124276 of which 16 recycled
                          Never used RAM 11912, free system stack 156 words
                          Tasks: NETWORK(2,nWait,17.1%,215) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,0.3%,110) MAIN(1,running,81.5%,704) IDLE(0,ready,0.2%,29) AIN(4,delaying,0.8%,266), total 100.0%
                          Owned mutexes:
                          Last reset 00:02:32 ago, cause: software
                          Last software reset at 2023-08-24 17:31, reason: User, Gcodes spinning, available RAM 12404, slot 0
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          MCU revision 3, ADC conversions started 152189, completed 152189, timed out 0, errs 0
                          MCU temperature: min 24.4, current 27.0, max 27.0
                          Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/588/192, gc cycles 2
                          Driver 0: not present
                          Driver 1: not present
                          Driver 2: not present
                          Driver 3: not present
                          Driver 4: not present
                          Driver 5: not present
                          Driver 6: not present
                          Date/time: 2023-08-24 17:34:05
                          Cache data hit count 252956637
                          Slowest loop: 11.79ms; fastest: 0.14ms
                          === Storage ===
                          SD card longest read time 4.5ms, write time 4.4ms, max retries 0
                          === DDARing 0 ===
                          === DDARing 1 ===
                          Heater 1 is on, I-accum = 0.0
                          === Filament sensors ===
                          Extruder 0 sensor: no filament
                          === CAN ===
                          Messages queued 1145, received 2609, lost 0, boc 0
                          Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 18 (min 18), ts 636/636/0
                          Tx timeouts 0,0,0,0,0,0
                          === Network ===
                          Slowest loop: 25.23ms; fastest: 0.06ms
                          HTTP sessions: 1 of 8
                          = WiFi =
                          Module reset reason: Power up, Vcc 3.31, flash size 2097152, free heap 43132
                          Signal strength -49dBm, channel 1, mode 802.11n, reconnections 0
                            Quite strange. When and where was the board purchased?
                            Exerqtorundefined 1 Reply Last reply Reply Quote 0
                            • Exerqtorundefined
                              Exerqtor @Phaedrux
                              @Phaedrux Yeah it's pretty weird, especially since it worked perfectly one evening, then this just happens while standing idle over night.
                              I just bought the board second hand from a dude here in Norway. He purchased the board from E3D in november 2022 (i have a printout of the order confirmation mail he got, with order number).
                                Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                • Exerqtorundefined
                                  Exerqtor @Phaedrux
                                  Thanks @Phaedrux, mail sent ✌
                                  • jonasr75undefined
                                    jonasr75
                                    G1: G0/G1: insufficient axes homed
                                    I follow the topic.
                                    I have a similar problem, but not quite this one. I also get the following error message: "G1: G0/G1: insufficient axes homed". Could this not be an endstop problem? I have a DueX5 extension board as I drive 3 pcs Z nema17 stepper motors. However, on the DueX5 board, I see a small "crater" on the first chip of the TMC2660 stepper. Could this chip be broken and cause the homing process to fail? I haven't run the M122 command yet.
                                      Phaedrux Moderator @jonasr75
                                      @jonasr75 Best to start a new thread. Provide all the details including your config.g and a photo of your driver.
                                      jonasr75undefined 1 Reply Last reply Reply Quote 1
                                      • jonasr75undefined
                                        jonasr75 @Phaedrux
                                        @Phaedrux ok, i have started a new thread:
                                        https://forum.duet3d.com/topic/33921/homing-error-in-x-y-axes
                                        • Exerqtorundefined Exerqtor referenced this topic
