    JoergS5's CoreXY 5 axis (robot kinematics)
    My Duet controlled machine
    1.9k
      T3P3Tony administrators @JoergS5
      @JoergS5 yes, we have also discussed this. Using the LDC1612 to detect the nozzle.
        3rd edition? You'd think they would have got it right the first time. πŸ˜€
        JoergS5undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 3
        • JoergS5undefined
          JoergS5 @Phaedrux
          @Phaedrux 😁
            T3P3Tony administrators @Phaedrux
            @Phaedrux also that tape measure looks wrong...
              A Former User @T3P3Tony
              This post is deleted!
              • JoergS5undefined
                JoergS5
                I've change the kinematics from screw theory to geometric algebra. It works much better now, especially with the Z direction, I had some errors.
                Screw theory says that directions of axes must be reversed, depending on whether the axis is attached to the hotend or the table. I'm unsure whether it's the same with geometric algebra. This matters for Voron, whose Z axis is attached to the hotend part. If it matters, I'll have to add a paramter to specifify whether X, Y, Z axes are attached to hotend or bed.
                I expected that geometric algebra is slower than screw theory, but to my surprise it is faster: 15 microseconds (for both forward and inverse) compared to 30 of screw theory for each segment calculation. M669 R gives a statistic. (M669 R currently unhomes all axes, I don't know why).
                => Edit: I know why it unhomed, it was the seen variable in Config. I've added a D parameter (see documentation on the main page) to decide not to unhome if wished, if configuration is changed.
                I currently build bins and will upload to github together with the sources. Duet 2 still compiles without error.
                BC mode should work also, but I have no BC prototype and cannot test it.
                I saw an article to build a machine with two rotary axes with arbitrary angles, this I will investigate. It uses Paden-Kahan 2 to translate AC/BC angles into the machine angles. This will cost processing time however.
                T3P3Tonyundefined 1 Reply Last reply Reply Quote 2
                • JoergS5undefined
                  JoergS5
                  Short update about my activities:
                  I am aware that RRF is restricted by memory and performance. It has only a few KB or available RAM and every ms is important. So I thought about how to optimize the usage for robot kinematics and will try the following procedure:
                  • best performance is when the axes are perpendicular and AC/BC axes are in A/B/C directions. The calculation is easiest then and performance best
                  • the algorithms allow skew axes and arbitrary axes also, so I want to support them also
                  • so I'll establish a decision tree to use the simple, fast calculations when configuration uses the first case and full calculation for the other
                  • at every move, first is a call to LimitPosition, so I can check configuration changes there and cache values if possible
                  • one performance measure I didn't use yet is to cache AC/BC values for moves where AC/BC don't change. I'll implement this now
                  For memory usage of the bin file, I'll remove every code which is not used. I have a lot of code to calculate between transformation matrix, quaternions, Euler angles, CGA and skrew theory. I don't want to loose it, but storing it into RRF uses much memory. So I'll make a separate github project to store it there. The redundant solutions allow cross check of the calcuations.
                  For visualisation, the DWC is a bit problematic for me, as I don't want to migrate between C++ and TrueScript. I'll use C++ with OpenCV until I have a better solution (or someone can tell be a solution). So I can use one C++ code base.
                  An open topic with 5 axis is that rotations are not velocity constant. I'm thinking about how segmentation could be changed, but this is code outside kinematics, it is part of the core RRF. An intersting article to introduce into the topic and how it could be solved with a modified slerp is "Yan/Jeng/Chieng Five-Axis Slerp for Tool-Orientation Planning in a Five-Axis CNC Machine".
                  samlogan87undefined 1 Reply Last reply Reply Quote 0
                  • samlogan87undefined
                    samlogan87 @JoergS5
                    @JoergS5 I am very interested in your progress so far. I am about to build a mini mill and will at some stage get a 4th and 5th axis so if you need help testing let me know. I will most definitely be 3-4 months off getting it done as funds don’t allow it at the moment so the project is being drip fed
                    Custom Core-XY
                    • JoergS5undefined
                      JoergS5 @samlogan87
                      @samlogan87 my next step is to CNC including milling, so my activities will help your project. I have e.g. a boring head (german: Ausdrehkopf) which I want to integrate.
                        @JoergS5 said in JoergS5's CoreXY 5 axis (robot kinematics):
                        Just a note. this is only the case for Voron 2.x, V0 and Trident move the bed.
                        • JoergS5undefined
                          JoergS5 @T3P3Tony
                          @T3P3Tony thank you Tony for the comment. It's important to be aware where the axes are attached (hotend or bed), because this reverses the calculation.
                          I'll make a decision matrix in the documentation with sample config settings to make it clear. Especially with CNC and milling there are several variants, e.g. the A axis being at the drill side.
