    Hollow shaft extruder
    345
    41.2k
    • breedundefined
      breed @oliof
      @oliof yep that could be. Didn't think of that.
      • o_lampeundefined
        o_lampe
        I couldn't resist and tested the NEMA08 motor with filament:
        YT-short
        It looks like it's made for it, but as expected the torque is too low.
        Maybe with a pushing stationary BLDC motor with limitted torque? SimpleFOC is pretty good with torque control. And the weight of the sensor/driver and step/dir controller (rp2040) wouldn't matter anymore because it's stationary.
        • zero Kundefined
          zero K
          Hi
          OK, compared with yours, it will be something like a monster hollow shaft extruder.
          But the first step is done, some parts didn´t arrive yet, may be til next weekend.20230903_214822v1.jpg
          Gruß, zero K
          • breedundefined
            breed
            Been playing around this week in cad. 8mm roller would have to be made on a lathe. 683 bearings. Would make a 2mm lead 2 start thread on the filament. https://www.printables.com/model/573540-extruder-8mm-quick-release
            o_lampeundefined 1 Reply Last reply Reply Quote 2
            • o_lampeundefined
              o_lampe @breed
              @breed That's an interesting approach. The front door is very nice!
              But given the relative high RPM we'd need for extruding, I'd prefer a perfectly balanced design, without the knurled screw.
              The roller has two bearings inside, I guess , but I don't see a shaft for them?
              I've made a few suggestions in a quick sketch.
              • raise the screw to align with the bearings for equal clamping forces ( red cross marks the spot 🙂 )
              • the cut in the door for the filament is a weak spot in the door. Clamping forces might bend the door and make the bearings contact each other.
                I enforced the door on the outside to have same thickness all around. ( grey semicircle )
              • mrehorstdmdundefined
                mrehorstdmd @o_lampe
                @o_lampe The bearings in the door seem to be misoriented- the filament isn't going to be rotating, is it? Also, the threaded insert in the body is going to get jacked out of the body by the spring force on the screw. I think a nut on the back side of the body would be a better way to go. How are you going to rotate the filament drive screw?
                • o_lampeundefined
                  o_lampe @mrehorstdmd
                  @mrehorstdmd said in Hollow shaft extruder:
                  The whole part is mounted on the stepper shaft and rotates. That's why I'm worried about the knurled screw being a substantial offcenter mass...
                    @o_lampe I see. I thought the screw was the only rotating part. Interesting approach- much easier to fabricate compared to the designs in the posts above.
                      A Former User
                      This post is deleted!
                      • o_lampeundefined
                        Yes it is, although you'd need a lathe to make the screw. Same problem as most other screw extruder designs.
                        I'm also unsure, if the pressure bearings add some extra friction, because they don't roll off in line with the filament motion.
                        All other designs have the same cant angle for all bearings/screws for a reason.
                        breedundefined 1 Reply Last reply Reply Quote 0
                        • breedundefined
                          breed @o_lampe
                          @o_lampe I didn't consider the filament path being a spot where it might flex, that's a good point. The non canted bearings in the door, I considered trying to find a way of adding a 20 degree angle, but then I got to thinking that would decrease the length that the filament is backed and pushed firmly into the groved roller. That length is already limited by the angle of the grooved roller. The shaft for the roller I was intending to be 3mm carbon rod. The bolt and spring for the door is offset because the outer frame is actually 2 pieces so the roller assembly can be inserted. I have a couple different designs I'm playing with in cad and have ordered some sls parts to mess with. Waiting currently on shoulder bolts from China, apparently the boat must be stuck in a canal somewhere. As far as balancing I could prob get it close by calculating up the individual pieces with their specifical gravity and get close. I don't know if I'll try and make this, I might, just figured I'd throw it out for people to think about.
                          • breedundefined
                            breed
                            updated on printables
                            o_lampeundefined 1 Reply Last reply Reply Quote 1
                            • o_lampeundefined
                              o_lampe @breed
                              @breed That looks better. If you want to counterbalance the hinge-bolt, you might want to put the two clamping bolts to the back and use inserts in the door?
                              But you'll need some fine tuning anyway, I guess. No one likes horizontal vibrations on his effector.
                              • zero Kundefined
                                zero K
                                May be PEEK countersunk head screws are an option for this.
                                Gruß, zero K
                                • tombrazierundefined
                                  tombrazier
                                  Hi guys, I have been on holiday for a few week, hence the radio silence.
                                  Nice work from several of you.
                                  @zero-K how does your extruder do?
                                  @breed Your pressure bearings that aren't canted will probably be fine with many filaments. Quite some time back I tried a VDE-100 with only plain bearings (i.e. no edge) and it had very little grip. I think that was with PLA. I conclude that filament slides over plain bearings very easily. Something like TPU might be a different matter, though.
                                  @o_lampe I got the carriers, thanks. Now I have my work cut out for me grinding bearings! On the plus side, one of the users on the 3D Printing discord server is working on a Dremel attachment to help with this.
                                  • lee.iii.willundefined
                                    lee.iii.will @oliof
                                    @oliof I'd be interested as well. Would this be a hollow shaft nema 14 round pancake?
                                    I like the greater performance to weight of the ratio of the BLDC but I think I'll stick with stepper unless someone has a single board solution to running a magnetic encoder and simplefoc.
                                    I picked up a hollow shaft nema 14 mentioned earlier in this thread. I'm planning to test with some hardened steel pipe cutter blades.
                                    Has anyone used a dual shaft stepper with a push/pull configuration? If the back to back bearings bode well for pushing force, additional blade contact could do the same.
                                    • o_lampeundefined
                                      o_lampe @lee.iii.will
                                      @lee-iii-will said in Hollow shaft extruder:
                                      My small NEMA08 has a dual shaft, but I haven't thought of a push/pull config yet. The problem will be to align both cuts into one.
                                      The back2back solution seems better, because the bearings support each other against the offcenter-pressure they have to endure.
                                      Your pipe cutter blades won't have that problem, but will they be small enough to mesh? So far everything above 8-9mm diameter has shown issues.
                                      lee.iii.willundefined 1 Reply Last reply Reply Quote 0
                                        lee.iii.will @o_lampe
                                        @o_lampe I did initially think of the cut alignment as an issue but I think the solution should be easy enough. My initial solution was to mount one roller set, feed filament and then thread the other roller set onto the filament and shaft at the same time for alignment. You may be absolutely right about the back to back design being more efficient though.
                                        I did see discussion about the diameter of the threaded rollers in some places when I was researching this last year. I've got a micro pipe cutter that has a cutting wheel < 10mm, but I'm still trying to source replacement blades.
                                        tombrazierundefined 1 Reply Last reply Reply Quote 0
                                          tombrazier @lee.iii.will
                                          @lee-iii-will One thing to watch out for with a large gap between the pusher and puller sets of wheels is when thread compression happens. The larger the distance along the filament between wheels the greater the alignment challenge when the thread pitch changes. On the other hand, with greater misalignment there will also be more force against the side of the groove and potentially more thrust. I think whether it works or not can only really be established by testing.
                                          Hardened steel wheels are interesting. I have assumed (without actually testing it) that sharpened bearing flanges will be chewed up by glass or carbon filled filament. I would hope hardened steel might be able to handle these filaments.
                                          • breedundefined
                                            breed
                                            https://a.aliexpress.com/_mK0e0jY
                                            Anyone seen this yet
                                            tombrazierundefined A Former User? 2 Replies Last reply Reply Quote 1
