Resume APF not working
What firmware is on the PanelDue?
@Phaedrux PanelDue firmware is 3.4.1
It's possible this is a bug. I don't think it's been tested for previously so it may be a missing feature.
@Phaedrux so which firmware i have to use?
Ideally the latest stable, but what I'm saying about power resume from the secondary panel due SD card is that the feature isn't supported in any firmware at the moment.
@Phaedrux So when we get updated firmware its causing problems at customer end.
@R006 said in Resume APF not working:
Can you be more specific?
@Phaedrux
In what context?
Sometimes they use PanelDue SD card for printing -
I don't have a time frame on that, sorry. Thank you for bringing it to our attention though. Secondary SD card printing is fairly uncommon.
@Phaedrux okay,
Any suggestions on how I can update this from my end? -
Update what?
@Phaedrux
If I want to fix this problem which firmware should be update panel or mainboard? -
It likely doesn't work in any current firmware.
@Phaedrux
Ok.
Thank you for your support.
And waiting for update in firmware. -
@R006 I think the issue may be that the SD card in PanelDue was not mounted when you ran M916. Try viewing the contents of that SD card before you run M916. Alternatively, add command M21 P1 to your resurrect-prologue.g file.
@dc42 thank you it's working.
@R006 thanks, I've logged https://github.com/Duet3D/RepRapFirmware/issues/912/
