    Duet3D is useless as a CNC Controller!
    CNC
    1.1k
    • chimaeraghundefined
      chimaeragh @Atair
      @Atair said in Duet3D is useless as a CNC Controller!:
      s for the GCode - i went with the default-ish Mach3 postprocessor (using RhinoCam / VisualMill), and there the arcs got messed up (the two 'lower' ones - out of 4 total).
      I think this may be the cause of the issues you are having. A Mach3 postprocessor will not produce g-code that works well with RepRap firmware.
      Duet 2 Wifi, Ooznest Workbee CNC 1510
      • Atairundefined
        Atair @Atair
        and one additional suggestion - why no option to parse the code? check for soft limits etc. I can only upload it and then run it - any syntax or user errors show only when i am already cutting.. As the preview in my - 1-2 year old version - cant give me any indication of problems..
        So even with an update to the latest firmware etc. - i think an option for a sanity check would be in order - which in turn would need a separate method besides run. 'Parse File' maybe?
        T3P3Tonyundefined Sindariusundefined 2 Replies Last reply Reply Quote 0
          T3P3Tony administrators @Atair
          @Atair there is the option to simulate a job.
          Atairundefined 1 Reply Last reply Reply Quote 1
          • Atairundefined
            Atair @T3P3Tony
            @T3P3Tony Thanks, found all i need after a firmware update (3.5.0 RC). The GCode viewer is a bit erratic, but it works.
            What are good value ranges for the M669 Snnn Segments per second? I have it at 10 for now, it works, but still a little laggy.
            jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @Atair
              @Atair a value of 1 for S and T is fine
              • Sindariusundefined
                Sindarius @Atair
                @Atair Sorry I am late to this, been a bit under the weather the past few days. When visualizing g-code for CNC Routers etc. I recommend setting the following settings.
                Force line rendering (Make sure quality is not set to max)
                Render G1 - Early on I ran into some cases where slicers were use G1 for everything including travels for 3d printers. I added this flag to help address G0/G1. Though I think with Fusion 360's changes they force all moves to G1 on their hobbyist versions so depending on what you use to generate g-code there could still be render issues.
                With those settings you should have a better view of the toolpathing. Here is a sample of some drag knife tool pathing
                  dc42 administrators @Atair
                  What is it that you find laggy: the response to a pause command, or something else?
                  At low speeds the T parameter (minimum segment length) matters too. In your example with S=10 and assuming the default T=0.2mm, if the speed is 2mm/sec or greater then the S parameter will define the segment time (0.1sec); but if the speed is lower than 2mm/sec then the T parameter will define the segment length. For example, at 1mm/sec the segments will be 0.2mm long and will take 0.2sec each. If you want to maintain 0.1sec response time to a pause command then you would need to reduce T to 0.1mm.
                  Atairundefined 3 Replies Last reply Reply Quote 0
                  • Atairundefined
                    Atair @dc42
                    @dc42 i see, both parameters are relevant, my question was more in the direction of performance limits. (I am mostly interested in live feed rate adjustments)
                    Now with S10 it works, although i had two instances of gcode lines being interpreted wrong. I could not reproduce it, but both times it happend, the tooldhead was under load.
                    It was not lost steps, but the head moving to a totally wrong position.. Could be of course something different, but could also be data corruption.
                    Edit: and both times it was on the last segment of the gcode.. maybe there is something after all.. If i find out more i will post it.
                    • Atairundefined
                      Atair @dc42
                      @dc42 ok i just ran another job.. and this time it did not fail, but also did not finish. main3.gcode
                      it just does not do the last line - a simple z axis move, and instead just stays there. i have to manually cancel it, and then reboot the controller.
                      I assume it is because of the S10? or some other thing with the current RC version?
                      using Duet Web Control 3.5.0-rc.1
                      thanks
                      • Atairundefined
                        Atair @dc42
                        @dc42 ran the same code a second time, this time on the start of the last segment:
                        Line 423: G1 X263.075 Y-0.997 Z-7.000 F300.0
                        it never started this line, instead went diagonally towards zero i guess.. so happend 3x in a row - i was lucky that it is plywood and it did not break anything important, but there seems to be a real problem with this latest RC..
                        It never reached the last line, Line 424: G1 X263.075 Y-0.997 Z10.000 F1200.0, (the Z-Lift)
                        I also have a second job, here: 4Holes.gcode It runs before the main cut, and never has any problems. I guess the lines are too short to have any effect with the segmentation.
                        Here my config.g in case that helps (there is also the M669 S10 command)
                        config.g
