    Duet 2 Ethernet disconnect when printing and paneldue connected
    PanelDue
    2.4k
      Thanks for the info. 7i is the hardware version.
      Can you gather another M122 report after having this issue happen?
      Shokiundefined 1 Reply Last reply Reply Quote 0
      • Shokiundefined
        Shoki @Phaedrux
        @Phaedrux The M122 I show above are sent directly after an error.
          @Shoki said in Duet 2 Ethernet disconnect when printing and paneldue connected:
          Are they after a reboot though?
          Can you get the fault to happen, then switch PD to the setup screen so that DWC can connect, then run M122?
          • Shokiundefined
            Shoki @Phaedrux
            @Phaedrux Not after a reboot of the Duet. Just when I can have access back to the DWC.
            As I said, while this happen, the printer is printing and continuing like nothing happened.
            The thing is, I don't need to switch to the setup screen to get the DWC to connect back, it comes back on its own after 3-5 seconds.
              Can you share the rest of your config files for your machine? Homing files, tool change, etc?
              • Shokiundefined
                Shoki @Phaedrux
                @Phaedrux I will download them and send them when I'm back to work on thurday !
                Thanks a lot for taking the time to help me figure it out.
                edspedundefined 1 Reply Last reply Reply Quote 0
                • edspedundefined
                  edsped @Shoki
                  @Shoki I had the exact same issue... I even went so far as to switch from a Duet2 Wifi to a Duet3, I'm happy I did but it did not solve the issue. I ultimately thought the PanelDue was faulty then I decided to keep trying. I erased the firmware on the paneldue several times then updated it to the latest firmware over USB using Bossa per instructions and now my issue seems to be resolved. On a side note I no longer see results of G32 on the consol of the PanelDue and it shows 0.0.0.0 as the IP but at least I don't have constant wifi disconnects.
                  See my original post here I fought this for almost a year and finally resolved within the past week.
                  edit: one common thread is that we both run tool changers, only I'm running a Jubilee
                  edit edit: I see you found my post... DOH...
                  • edspedundefined
                    edsped
                    @Phaedrux @Shoki If there's anything I can do to help let me know... I should update my post that my problem seems to be resolved.
                    • Shokiundefined
                      Shoki @edsped
                      @edsped Thanks for replying with your solution. I will try it tomorrow and post the result here.
                      • edspedundefined
                        edsped @Shoki
                        @Shoki Out of curiousity, before wiping see if the paneldue shows the IP address of the printer. I know mine used to but now it only shows 0.0.0.0 and I'm not sure if it's because I'm running a Duet3 with SBC or if wiping the paneldue had something to do with it. I didn't really pay attention to the IP on the paneldue and only noticed that it no longer showed the correct IP after everything was working properly.
                        I feel your pain though as it's been incredibly frustrating.
                          Phaedrux Moderator @edsped
                          @edsped said in Duet 2 Ethernet disconnect when printing and paneldue connected:
                          This is the reason because the SBC is handling all networking.
                          • edspedundefined
                            edsped @Phaedrux
                            @Phaedrux I realize I'm hijacking the thread but could the reason the paneldue didn't initially work with the Duet3 w/SBC be that it was still using the IP from the Duet2 or is the IP just passed through from config.g during boot up?
                              The paneldue only gets information from the duet. When the Duet is in SBC mode, it has no IP address of it's own.
                                dc42 administrators @Phaedrux
                                To those of you who are having this issue: which PanelDue do you have, and what firmware version is the PanelDue running? Look on the Status page check.
                                edspedundefined Shokiundefined 2 Replies Last reply Reply Quote 0
                                • edspedundefined
                                  edsped @dc42
                                  @dc42 My problem appears to be solved. I did move from the Duet2 WiFi to the Duet 3, the problem persisted, I did a reset and wipe of the PanelDue 7i several times then installed latest beta from Github using Bossa over USB and my problem is gone. Not that it's a big deal but I no longer get pertinent information in the PanelDue console but I'm assuming it has to do with me running the 6HC in SBC mode as the IP is also 0.0.0.0 I'm just happy I have some control at the printer itself.
                                  • Shokiundefined
                                    Shoki @dc42
                                    @edsped I erased the firmware and updated it again via Bossa and USB, it did not solve anything. The IP adress was showing both before and after the update.
                                    @dc42 This is a PanelDue 7i, running now firmware version 3.5.0-rc7-7.0i.
                                    @Phaedrux
                                    This is the result of a M122 command after a print where the error appeared multiple time, no reboot of the Duet after the print :
                                    M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.1 (2023-08-31 16:16:15) running on Duet Ethernet 1.02 or later + DueX5v0.11
                                    Board ID: 0JD2M-9F8TA-GJ4TN-6J1F8-3SN6P-K7UY5
                                    Used output buffers: 1 of 26 (26 max)
                                    Static ram: 23076
                                    Dynamic ram: 75432 of which 0 recycled
                                    Never used RAM 11132, free system stack 124 words
                                    Tasks: NETWORK(1,ready,22.3%,196) HEAT(3,nWait,0.1%,308) Move(4,nWait,0.3%,261) DUEX(5,nWait,0.0%,26) MAIN(1,running,77.2%,625) IDLE(0,ready,0.0%,29), total 100.0%
                                    Owned mutexes:
                                    Last reset 01:04:56 ago, cause: power up
                                    Last software reset at 2023-10-23 13:49, reason: User, Gcodes spinning, available RAM 10996, slot 1
                                    Error status: 0x04
                                    Aux0 errors 0,0,0
                                    MCU temperature: min 30.1, current 36.2, max 42.5
                                    Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1320/912, gc cycles 0
                                    Events: 0 queued, 0 completed
                                    Driver 0: standstill, SG min 0
                                    Driver 1: standstill, SG min 0
                                    Driver 2: standstill, SG min 0
                                    Driver 3: standstill, SG min 0
                                    Driver 4: standstill, SG min 0
                                    Driver 5: standstill, SG min n/a
                                    Driver 6: standstill, SG min n/a
                                    Driver 7: standstill, SG min n/a
                                    Driver 8: standstill, SG min 251
                                    Driver 9: standstill, SG min n/a
                                    Driver 10:
                                    Driver 11:
                                    Date/time: 2023-10-25 12:55:42
                                    Slowest loop: 220.50ms; fastest: 0.15ms
                                    === Storage ===
                                    Free file entries: 10
                                    SD card longest read time 2.1ms, write time 0.0ms, max retries 0
                                    DMs created 83, segments created 27, maxWait 6179ms, bed compensation in use: none, height map offset 0.000, ebfmin -0.92, ebfmax 1.00
                                    no step interrupt scheduled
                                    Moves shaped first try 1301, on retry 100, too short 1539, wrong shape 35, maybepossible 19
                                    === DDARing 0 ===
                                    Scheduled moves 3233, completed 3233, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                    Heater 0 is on, I-accum = 0.0
                                    Movement locks held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Q0 segments left 0
                                    Code queue 0 is empty
                                    === DueX ===
                                    Read count 0, 0.00 reads/min
                                    === Network ===
                                    Slowest loop: 84.28ms; fastest: 0.04ms
                                    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                    HTTP sessions: 1 of 8
                                    Interface state active, link 100Mbps full duplex
                                    This is my config.g
                                    ; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer
                                    ;  General preferences
                                    M111 S0 				; Debugging off
                                    G21 					; Work in millimetres
                                    G90 					; Send absolute coordinates...
                                    M83 					; ...but relative extruder moves
                                    M555 P2 				; Set firmware compatibility to look like Marlin
                                    M669 K1 				; Select CoreXY mode
                                    ;        Network
                                    M550 P"ToolChanger" 	; Set machine name
                                    M553 P***     ; Ethernet Settings - Mask
                                    M554 P***     ; Ethernet Settings - Passerelle
                                    M552 P***     ; Ethernet Settings - Adresse
                                    M552 S1					; Enable Networking
                                    M586 P0 S1 				; Enable HTTP
                                    M586 P1 S0 				; Disable FTP
                                    M586 P2 S0 				; Disable Telnet
                                    ;         Drive
                                    ;Drive directions
                                    M569 P0 S0 											; Drive 0 (X)
                                    M569 P1 S0 											; Drive 1 (Y)
                                    M569 P2 S1 											; Drive 2 (Z)
                                    M569 P3 S0 											; Drive 3 (C)
                                    M569 P4 S0 											; Drive 4 (E0)
                                    M569 P5 S0 											; Drive 5 (E3)
                                    M569 P6 S0											; Drive 6 (E2)
                                    M569 P7 S0 											; Drive 7 (E1)
                                    M569 P8 S1 											; Drive 8 (W)
                                    M569 P9 S0 											; Drive 9 UNUSED Future 5 axes
                                    ;Drive mapping and control
                                    M584 X0 Y1 Z2 C3 W8 E4:7:6:5 						; Stepper motor connection points, see C:\Users\YN14386\Documents\Documentation\Toolchanger for wiring diagram
                                    M208 X-25:338.5 Y-49:243 Z-0.2:300 C-45:360 W-3:65 	; Set axis maxima & minima
                                    M92  X100 Y100 Z800 C91.022 W360 E392:392:392:392	; Set steps per mm assuming x16 microstepping
                                    M350 X16 Y16 Z16 I1									; Configure microstepping with interpolation for the extruders
                                    M350 E16:16:16:16 I1 								; Configure microstepping with interpolation for the XYZ movements
                                    M350 C16 I1  										; Configure microstepping with interpolation for the coupler
                                    M350 W16 I1											; Configure microstepping with interpolation for the pebble wiper
                                    ;Drive speeds and acceleration
                                    M203 X35000 Y35000 Z1200 C5000 W2400 E5000:5000:5000:5000	; Set maximum speeds (mm/min)
                                    M201 X2000 Y2000 Z400 C500 W800 E2500:2500:2500:2500		; Set maximum accelerations (mm/s^2) was X6000 Y6000
                                    M566 X300 Y300 Z20 C2 W100 E400:400:400:400					; Set the jerk : maximum instantaneous speed changes  (mm/min)
                                    ; reset this to 400 400
                                    ; Motor current
                                    M906 X1800 Y1800 Z1330 I30   						; Idle motion motors to 30%
                                    M906 E1000:1000:1000:1000 C500 I10     				; Idle extruder and cooupler motors to 10%
                                    M906 W600 I20										; Idle pebble wiper to 20%
                                    ;        Endstops
                                    ;X and Y axis
                                    M574 X1 Y1 S3 					; Set X / Y endstop stall detection
                                    M915 X Y S3 F0 H400 R1   		; Stall Detection for the X and Y Axes ;
                                    ; Coupler Axis
                                    M574 C0 Z0  				    ; No C Z endstop, it just crashes
                                    ;P axis
                                    M574 W1 S3 						; Set W endstop stall detection
                                    ;Z axis
                                    M558 P8 C"zstop" H3 F360 I0 T20000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                                    G31 P200 X0 Y0 Z0	 				; Set Z probe trigger value, offset and trigger height
                                    M557 X10:290 Y20:180 S40 			; Define mesh grid
                                    ;M557 X10:290 Y20:180 S280:160		; Define mesh grid to test quickly
                                    ;M376 H15							; bed compensation taper
                                    ;         Heaters
                                    ;Tool 0
                                    M308 S1 P"e1temp"      Y"thermistor" A"Heater 0" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                                    M950 H1 C"e1heat" T1													; Set heater number (H) and connection point (C)
                                    M143 H1 S285															; Set temperature limit for heater to 285C
                                    ;Tool 1
                                    M308 S2 P"duex.e2temp" Y"thermistor" A"Heater 1" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                                    M950 H2 C"duex.e2heat" T2												; Set heater number (H) and connection point (C)
                                    M143 H2 S290															; Set temperature limit for heater to 285C
                                    ;Tool 2
                                    M308 S3 P"duex.e3temp" Y"thermistor" A"Heater 2" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                                    M950 H3 C"duex.e3heat" T3												; Set heater number (H) and connection point (C)
                                    M143 H3 S285 															; Set temperature limit for heater to 285C
                                    ;Tool 3
                                    M308 S4 P"duex.e4temp" Y"thermistor" A"Heater 3" T100000 B4725 C7.06e-8 ; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                                    M950 H4 C"duex.e4heat" T4												; Set heater number (H) and connection point (C)
                                    M143 H4 S285 															; Set temperature limit for heater to 285C
                                    ;Heated bed
                                    M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 				; Set thermistor number (S), connection point (P), name (A) and parameters (YTBC)
                                    M950 H0 C"bedheat" T0													; Set heater number (H) and connection point (C)
                                    M143 H0 S115 															; Set temperature limit for bed heater to 110C
                                    M140 H0																	; Bed heater is heater 4
                                    ;        Fans
                                    ;Tool 0
                                    M950 F4 C"fan1"					; Set hotend fan number (F) and connection point (C)
                                    M106 P4 S255 H1 T60				; Link fan to Heater (H) and turn it for temperature above 60C (T)
                                    M950 F0 C"fan2"					; Part cooling fan connection point
                                    M106 P0 S0 C"Tool 0"			; Turn off the part cooling fan.
                                    ;Tool 1
                                    M950 F5 C"duex.fan3"			; Set hotend fan number (F) and connection point (C)
                                    M106 P5 S255 H2 T60 			; Link fan to Heater (H) and turn it for temperature above 60C (T)
                                    M950 F1 C"duex.fan4"			; Part cooling fan connection point
                                    M106 P1 S0 C"Tool 1"			; Turn off the part cooling fan.
                                    ;Tool 2
                                    M950 F6 C"duex.fan5"			; Set hotend fan number (F) and connection point (C)
                                    M106 P6 S255 H3 T60 			; Link fan to Heater (H) and turn it for temperature above 60C (T)
                                    M950 F2 C"duex.fan6"			; Part cooling fan connection point
                                    M106 P2 S0 C"Tool 2"			; Turn off the part cooling fan.
                                    ;Tool 3
                                    M950 F7 C"duex.fan7"			; Set hotend fan number (F) and connection point (C)
                                    M106 P7 S255 H4 T60				; Link fan to Heater (H) and turn it for temperature above 60C (T)
                                    M950 F3 C"duex.fan8"			; Part cooling fan connection point
                                    M106 P3 S0 C"Tool 3"			; Turn off the part cooling fan.
                                    ;         Tools
                                    ;Tool 0
                                    M563 P0 S"Tool 0" D0 H1 F0 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                                    G10 P0 X0 Y0 Z0 						; Reset tool axis offsets
                                    G10 P0 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                                    ;Tool 1
                                    M563 P1 S"Tool 1" D1 H2 F1 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                                    G10 P1 X0 Y0 Z0 						; Reset tool axis offsets
                                    G10 P1 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                                    ;Tool 2
                                    M563 P2 S"Tool 2" D2 H3 F2 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                                    G10 P2 X0 Y0 Z0 						; Reset tool axis offsets
                                    G10 P2 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                                    ;Tool 3
                                    M563 P3 S"Tool 3" D3 H4 F3 				; Define the tool : its number (P), its name (S), its extruder drive (D), its heater (H) and its part cooling fan (F)
                                    G10 P3 X0 Y0 Z0 						; Reset tool axis offsets
                                    G10 P3 R0 S0 							; Reset initial tool active and standby temperatures to 0C
                                    ;       PID tune
                                    ; run M303 T0 S230 with the tool you want to autotune (T) and the target temperature (S)
                                    ; for the bed, run M303 H4 S80 with the target temperature (S)
                                    ;Tool 0
                                    M307 H1 R4.405 K0.459:0.607 D1.76 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
                                    ;Tool 1
                                    M307 H2 R4.395 K0.424:0.670 D1.72 E1.35 S1.00 B0 V24.3
                                    ;Tool 2
                                    M307 H3 R4.902 K0.455:0.686 D1.64 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
                                    ;Tool 3
                                    M307 H4 R5.197 K0.520:0.759 D1.42 E1.35 S1.00 B0 V24.3  ;PID parameter for a heater (H)
                                    ;Bed
                                    M307 H0 R1.286 K0.265:0.000 D3.49 E1.35 S1.00 B0 ; PID parameter for the bed heater (H) for magnetic + PEI
                                    ;     tool offsets
                                    ; !ESTIMATED! offsets for:
                                    ; V6-tool: X-9 Y39 Z-5
                                    ; Volcano-tool: X-9 Y39 Z-13.5
                                    ; Hemera-tool: X20 Y43.5 Z-6
                                    global xmicroscope = 338.4  ;
                                    global ymicroscope = 98.3   ;
                                    ; for the XY calibration, major divisions are 0.1 mm and minor are 0.05 mm
                                    ;G1 X336.8  Y99.5 F6000
                                    ;G10 P0 X20.00 Y43.50				    ; Tool 0 is the reference
                                    ;G10 P1 X19.65 Y43.55					; Tool 1 was Y 43.25
                                    ;G10 P2 X19.70 Y43.60        			; Tool 2 was X 19.55 Y 43.50
                                    ;G10 P3 X19.75 Y43.45        			; Tool 3 was Y 43.30
                                    ; X and Y offsets are set in the toolXYoffset files
                                    M98 P"0:/sys/toolXYoffset0.g"
                                    M98 P"0:/sys/toolXYoffset1.g"
                                    M98 P"0:/sys/toolXYoffset2.g"
                                    M98 P"0:/sys/toolXYoffset3.g"
                                    ; Z (and W) offsets are set in the toolZoffset files
                                    M98 P"0:/sys/toolZoffset0.g"
                                    M98 P"0:/sys/toolZoffset1.g"
                                    M98 P"0:/sys/toolZoffset2.g"
                                    M98 P"0:/sys/toolZoffset3.g"
                                    ;    Pressure advance
                                    ;Default pressure advance for PLA, different values should be set in the slicer
                                    M572 D0 S0.025 						; pressure advance T0
                                    M572 D1 S0.025 						; pressure advance T1
                                    M572 D2 S0.025 						; pressure advance T2
                                    M572 D3 S0.025 						; pressure advance T3
                                    ;         Others
                                    M593 F42.2						; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
                                    ; Pebble wiper servo motor
                                    M950 S0 C"duex.pwm5" Q500
                                    M575 P1 S1 B57600				; Enable LCD
                                    G29 S2							; disable mesh
                                    T-1								; deselect tools
                                    ;*******Macro parameters*******
                                    global homingSpeed = 4800
                                    global movementSpeed = 18000
                                    global zmovementSpeed = 900
                                    global centerX = 155
                                    global centerY = 100
                                    global backX = 155
                                    global backY = 210
                                    global centerProbeX  = {global.centerX - sensors.probes[0].offsets[0]}
                                    global centerProbeY  = {global.centerY - sensors.probes[0].offsets[1]}
                                    global toolSafeY     = 150
                                    global notoolSafeY   = 210
                                    global toolapproachY = 217
                                    global tool0X = -3.4
                                    global tool0Y = 227.0
                                    global tool1X = 87.2
                                    global tool1Y = 227.2
                                    global tool2X = 221.8
                                    global tool2Y = 227.9
                                    global tool3X = 312.4
                                    global tool3Y = 227.9
                                    homeall.g
                                    ; homeall.g
                                    ; called to home all axes
                                    T-1
                                    M98 P"homey.g"			; Home Y
                                    M98 P"homex.g"			; Home X
                                    M98 P"homez.g"			; Home Z
                                    M98 P"homeW.g"			; Home W (Pebble Wiper)
                                    M98 P"homec.g"			; Home C (ToolHead)
                                    M98 P"0:/macros/Utility/Move to back"
                                    homec.g
                                    ; homec.g
                                    ; called to home the C axis (coupler)
                                    M291 P" " R"Homing C" S0 T1
                                    G91
                                    M913 C70					; XY MOTORS TO 60% CURRENT
                                    G1 H2 C-500 F5000
                                    G92 C-45
                                    G90
                                    M913 C100					; XY MOTORS TO 100% CURRENT
                                    ;Open Coupler
                                    M98 P"0:/macros/Utility/Coupler - Unlock"
                                    M300 P100 S440
                                    homew.g
                                    ; called to home the W axis (Pebble)
                                    M291 P" " R"Homing W" S0 T1
                                    G91 							; use relative positioning
                                    G1 H2 W-0.5 F600		   		; energise motors to ensure they are not stalled
                                    M400 							; make sure everything has stopped before we change the motor currents
                                    M913 W40 					    ; drop motor currents to 40%
                                    M915 H200 W S3 R0 F0 			; set W sensitivity to 3, do nothing when stall, unfiltered
                                    G1 H1 W-80 F1200				; move to the top stopping at the endstop
                                    M300 P100 S440 					; play beep sound
                                    M400 							; make sure everything has stopped before we reset the motor currents
                                    M913 W100 						; motor currents back to 100%
                                    G90 							; back to absolute positioning
                                    G1 W0 F2400 					; move away from end
                                    homex.g
                                    ; homex.g
                                    ; called to home the x axis
                                    if state.currentTool ==-1
                                        M291 P" " R"Homing X" S0 T1
                                        G91                                ; relative positioning
                                        G1 H2 X0.5 Y-0.5 F6000   		; energise motors to ensure they are not stalled
                                        M913 X20 Y20 					; drop motor currents to 20%
                                        M915 H200 X Y S3 R0 F0 			; set X and Y to sensitivity 3, do nothing when stall, unfiltered
                                        G1 Z5 F{global.zmovementSpeed} H2  ; lift Z relative to current position
                                        G1 H1 X-1000 F{global.homingSpeed} ; move quickly to X axis endstop and stop there (first pass)
                                        G1 H1 X2 F{global.movementSpeed}					; move away from end
                                        G1 Z-5 F{global.zmovementSpeed} H2 ; go back to the previous Z
                                        G90                                ; absolute positioning
                                        M913 X100 Y100 					; motor currents back to 100%
                                    else
                                        M291 P" " R"Function not available when tool selected" S0 T2
                                    homey.g
                                    ; homey.g
                                    ; called to home the y axis
                                        M291 P" " R"Homing Y" S0 T1
                                        G1 H1 Y-1000 F{global.homingSpeed} ; move quickly to X axis endstop and stop there (first pass)
                                        G1 H1 Y2 F{global.movementSpeed}   ; move away from end
                                    else
                                    homez.g
                                    ; homez.g
                                    ; called to home the Z axis
                                        M291 P" " R"Homing Z" S0 T1
                                        G1 X{global.centerProbeX} Y{global.centerProbeY} F{global.movementSpeed} ; go to first probe point
                                        G30        ; home Z by probing the bed
                                    else
                                    tfree0.g
                                    ; tfree0.g
                                    ; called when tool 0 is freed
                                    ;retract nozzle
                                    M98 P"retract_quick.g"
                                    ;Move In
                                    G53 G1 X{global.tool0X} Y{global.toolSafeY} F12000
                                    G53 G1 Y{global.toolapproachY} F6000
                                    G53 G1 Y{global.tool0Y} F3000
                                    ;retract nozzle
                                    M98 P"retract.g"
                                    ;Open Coupler
                                    ;Move Out
                                    G53 G1 Y{global.notoolSafeY} F{global.movementSpeed}
                                    tpost0.g
                                    ; tpost0.g
                                    ; called after tool 0 has been selected
                                    ;heatup
                                    M116 P0
                                    ;retract nozzle
                                    M98 P"retract_recover.g"
                                    ;restore to correct height
                                    G0 R2 Z0 F5000
                                    ;restore brush to correct height
                                    G0 R2 W0 F1200
                                    ;Move Out
                                    G53 G1 Y{global.toolSafeY} F6000
                                    M106 R2	; restore print cooling fan speed
                                    tpre0.g
                                    ; tpre0.g
                                    ; called before tool 0 is selected
                                    ;Unlock Coupler
                                    ;Move to location
                                    G1 X{global.tool0X} Y{global.notoolSafeY} F{global.movementSpeed}
                                    ;Move in
                                    G1 Y{global.toolapproachY} F{global.movementSpeed}
                                    ;Collect
                                    ;Close Coupler
                                    M98 P"0:/macros/Utility/Coupler - Lock"
                                    And these two are separated but called from the config.g as they are set by macros.
                                    toolZoffset0.g
                                    ; Offset for tool 0
                                    ; Smaller negativ values means closer to bed - Z and W must have the same value
                                    G10 P0 Z-7.930 W-7.930
                                    toolXYoffset0.g
                                    ; Offset for tool 0
                                    G10 P0 X21.0 Y43.45
                                      dc42 administrators @Shoki
                                      @Shoki I'm guessing that the PanelDue might be generating excessive traffic, overloading the Duet output buffers. If that's the case then if you switch to the PanelDue Setup screen, DWC may reconnect.
                                      • Shokiundefined
                                        Shoki @Shoki
                                        @dc42 I don't need to do anything for it to reconnect. It comes back on it's own after a few seconds. It's just very annoying and sometimes the disconnection are so frequent I don't have time to send gcode commands manually in the console of the DWC, which is very annoying.
                                        So you think it's something that can't be fixed : too much information displayed on the PanelDue because it's a Toolchanger ?
                                        I tried to disable all my tools except one in my config.g. So that only a single tool was displayed on the PanelDue and I still had the problem...
                                        I guess if it can't be fixed I will just add an on/off switch next to the screen so that I can power it on when I need it and leave it off when I don't.
                                          I'd be curious to see what happens if you went back to an older version of the PanelDue firmware like 1.24
                                          https://github.com/Duet3D/PanelDueFirmware/releases/tag/1.24
                                          • edspedundefined
                                            edsped @Phaedrux
                                            @Phaedrux Not so sure it will help. I believe I went through just about every firmware when I was fighting this. The only thing I didn't do was update over USB until I got the 6HC. I'm going to follow this as I putzed with it for almost a year before tossing in the towel.
