    Hollow shaft extruder
    345
    43.9k
    • tombrazierundefined
      tombrazier
      I have finally had a chance to play about with all the new toys.
      The 3 x double bearing idea doesn't work very well in my tests so far. I have found that with a 0.1mm bite depth the torque applied on the filament is too large. Reducing the bite depth to 0.07mm helps but the grip is a lot worse than the best I have seen with other configurations. This is using the SLA printed carriers. One test left to do for a definite change-only-one-variable test would be to print a carrier myself in PLA. But my guess is that won't improve matters and so it's not high on my priority list.
      The SLA carrier with three single bearings with 9.1mm edges works fairly well in printing but I have not had time to test it extensively.
      The LDO motors work nicely, but running them at their rated current of 1A RMS they get way too hot. I have found that 700mA RMS is acceptable if room temperature is low enough - they get about 30°C hotter than ambient. At 700mA I can drive the filament at 50mm/s and accelerate at 1500mm/s^2 without a motor stall. Jerk speed is 7mm/s (this is relevant for linear advance in Marlin and, I think, for the equivalent in RRF).
      20231023_123232.mp4
      Total extruder mass is 53g. It is a drop-in replacement for my 39mm Nema 17 style motor because the mounting hole spacing is the same as the diagonal distance between Nema 17 holes. I just had to print a smaller holding clamp.
      o_lampeundefined 1 Reply Last reply Reply Quote 1
      • o_lampeundefined
        o_lampe
        I was able to squeeze a bigger BLDC motor in the 44mm space of the sherpa mini.
        • o_lampeundefined
          o_lampe @tombrazier
          @tombrazier said in Hollow shaft extruder:
          Is that the retraction speed or can you actually extrude at 50mm/s? What are actual PLA print speeds with 0.4mm nozzle and say 0.3mm layer?
          It's always hard to compare apples with oranges, but in the end I'd like to know if it's worth going the extra mile with the dual motor setup I'm working on.
          rqthreeundefined tombrazierundefined 2 Replies Last reply Reply Quote 0
          • rqthreeundefined
            rqthree @o_lampe
            @o_lampe said in Hollow shaft extruder:
            Tom, although I've been using my "original" NEMA 14 VDE for well over two years, I still tinker with ideas. I never could get a NEMA 11 pancake to drive reliably, but TWO of them, rotating in the same direction but mounted back-to-back, seems like the cat's meow. Because they are back-to-back, they eliminate torque on the filament. Of course, you need two motors, and two bearing carriers. But one carrier is "right hand thread", and the other is, of necessity, "left hand thread", so the grooves scored in the filament only cross each other once per revolution. There is no issue with getting the two grooves to track each other, because they can't, and don't need to. They are independent of each other. There is still only one knife edge per carrier, per my reasoning above.
            Of course this bumps the complexity and cost by 2x, and the weight up to 65 whole grams! Prototype with 30 degree cant angles.
            EDIT Nov.1, 2023: A very brief video of the Push-Me_Pull_You VDE running (change the .doc extension to .mov).
            Cons: as noted, twice as heavy and twice as complicated, needs left AND right hand drive carriers.
            Pros: handles extremely flexible TPU with no hot end anchoring at all, 5 times the filament force (5 kilos vs 1 kilo) at 0.2 amps (paralleled NEMA 11 motors, no heat issues at all), motors can attain 4500 RPM, and 3000 RPM while actually driving filament (150 mm/sec at 30 degree cant angle). Feed and retraction very repeatable, as the two drivers don't interact.
            The Take Away: Not worth the size, weight (80 grams), and expense, unless you are after extreme extrusion speeds. I'll stick to my tried-and-true single knife NEMA 14.
            IMG_1951.DOC
            o_lampeundefined fmaundefined 2 Replies Last reply Reply Quote 3
            • o_lampeundefined
              o_lampe @rqthree
              @rqthree The left/right rotation is a good idea.
              Otherwise It is a bit similar to my dual motor approach, but I'll put a Bowden tube between the two. No weight panelty and free choice for the remote motor.
              I'm also a bit worried about temperatures and sketched up a thin watercooling plate to fit between your motors. A bit more weight doesn't make much of a difference, you already fouled there anyway 🙂
              rqthreeundefined 1 Reply Last reply Reply Quote 0
              • fmaundefined
                fma @rqthree
                @rqthree very cute extruder!
                Do you have some more informations about the motors and all vitamins used? Would you share your 3D models?
                Thanks,
                Frédéric
                  tombrazier @o_lampe
                  That's retraction speed. I think the motor can move at that speed while printing without stalling (but will have to confirm for sure). However with compression of the helical thread actual extrusion speed will be a whole lot lower. I specced the motor for extruding about 16mm/s which would give about 320mm/s linear printing speed with 0.4mm x 0.3mm lines. However with nozzle back-pressure I don't expect to get 16mm/s.
                  • o_lampeundefined
                    o_lampe
                    I've verified my NEMA08 motor temp-curve and the rated current of 0.6A is quite reasonable. For PLA printing the motor-surface temp at 0.5A is a bit too high.
                    The filament got soft when I extruded very slow (0.5mm/s). At normal print speeds I don't expect problems, but the first layer speed is usually slower and might fail.
                    Will try with 0.45A for longer periods and add some airflow over the stepper by designing an intake fan shroud for the hotend fan.
                    I also noticed that 20° cant angle doesn't self-lock the filament motion completely, but that is part of my pacemaker strategy. Luckily I've written the code for the remote torque_push motor in such way, that it goes idle without incomming steps. 🤞
                    • rqthreeundefined
                      rqthree @fma
                      @fma said in Hollow shaft extruder:
                      Thanks,
                      Frederic, here you go. Change the file extension to .zip from .doc. This forum does not accept zip files.
                      VDE_NEMA11.doc
                      fmaundefined 2 Replies Last reply Reply Quote 0
                      • fmaundefined
                        fma @rqthree
                        @rqthree Thank you very much!
                        Frédéric
                        • breedundefined
                          breed
                          Those rollers that were on funssor store on AliExpress a month or so ago finally showed up. They don't look anywhere near as bad as far as machining quality goes compared to the pictures. Id be hard to pressed to make better ones on the lathe. I'll send some pictures later today, gotta get to bed so I can watch some college football today.
                          o_lampeundefined 1 Reply Last reply Reply Quote 3
                          • o_lampeundefined
                            o_lampe @breed
                            @breed I have them on my watchlist, but wait until the price drops.
                            If it's good enough with one flanged bearing (according to @rqthree ) it doesn't make sense to use three long threaded rods.
                            I was thinking if making them conical in both directions would be better? But the contact area is so small, it doesn't matter...
                            • fmaundefined
                              fma @rqthree
                              @rqthree There is a problem with these files: Carrier_Assy.FCStd and Knife_Bearing.FCStd ; I'm unable to open them, neither other people at my hackerspace (they freeze or crash FreeCAD).
                              Could you save them as STEP files?
                              Thanks,
                              Frédéric
                              • rqthreeundefined
                                rqthree @fma
                                Thanks,
                                The files are fine, but were generated with a very high definition version of FreeCad. They will eventually open, but may take many minutes on a pretty high power workstation. In any case, the two files you reference are not at all important, and just show the over-all arrangement of parts.They don't contain any critical dimensions or data not seen in the other files.
                                fmaundefined 1 Reply Last reply Reply Quote 0
                                • fmaundefined
                                  fma @rqthree
                                  @rqthree Ok, I see!
                                  Frédéric
                                  • fmaundefined
                                    fma
                                    @rqthree BTW, how do you get the sharp edge on the flanged bearing? With a lathe?
                                    Frédéric
                                    • rqthreeundefined
                                      rqthree @fma
                                      @fma , yes, I use a collet chuck in a jewelers lathe, with an abrasive disc on a rotary tool. Others, like Tom Brazier, have come up with clever methods that don't require a lathe.
                                      • fmaundefined
                                        fma @rqthree
                                        @rqthree Thanks, I'll read the entire thread again to see how other guys do...
                                        Frédéric
                                        • rqthreeundefined
                                          rqthree @o_lampe
                                          The dual motor Push-Me-Pull-You VDE works fine at 0.2 amps driving two paralleled NEMA 11 motors. The motors get slightly warm after several hours of continuous operation, but nothing that affects even PLA.
                                            tombrazier
                                            @rqthree I vote we call this push pull version VDE337.
