    Control for “Maslow” style cnc
    Using Duet Controllers
    1.5k
      droftarts administrators @o_lampe
      @o_lampe I just realised the Maslow4 is quite different. The Maslow 1 and 2 (no idea what happened to Maslow 3) were polarbots, with a belt/chain from each top corner, but the Maslow 4 is more like a 2D quad-tower delta, and probably much closer to Hangprinter than previous versions. Again, the Hangprinter kinematics might do this, too.
      • o_lampeundefined
        o_lampe @droftarts
        @droftarts Maybe the Maslow_3 was a flop and that's why they again had to kickstart their next project? They even pulled the "Ukraine" card to gain more money.
        IMHO the Maslow_4 isn't a good design, using brushed DC motors and expensive ODrive controllers.
        there is a linkage for each belt around the centre of the effector, so that it's always a straight line between motor and 'pen'
        I think I figured out how to trick RRF to do the correct calculations without rotating belt links. It's similar to Delta-kinematics, where we have to measure rod length and horizontal distance between towers and effector.
        I just have to measure the horizontal distance from motorshaft (minus pulley radius) to the fixed link on the effector. Will add it in my next picture for reference.
        PS: I like the BotofTheCloth idea with it's strap-on corners. For a plotter or laser it might be good enough: Just buy a 8' x 6' plywood sheet and clamp the motors and idlers directly. No need for a permanent frame which only occupies workspace 99% of the time.
        CNCModellerundefined 1 Reply Last reply Reply Quote 0
        • CNCModellerundefined
          CNCModeller @o_lampe
          @o_lampe said in Control for “Maslow” style cnc:
          PS: I like the BotofTheCloth idea with its strap-on corners. For a plotter or laser it might be good enough: Just buy a 8' x 6' plywood sheet and clamp the motors and idlers directly. No need for a permanent frame which only occupies workspace 99% of the time.
          I had exactly the sam thought, personally the idea of having all of the moving parts in the plotter carriage with just a fixed anchor point at the corner of the 8x6 sheet would be ideal. Literally just put a screw in each corner and attach the belts, calibrate, and you’re r away. Ideally everything would retract into the plotter carriage for storage.
          I also like the idea of a diode laser to mark out for manual cuts and labelling.
          I could even see a larger version being used to layout where you put holes for steelwork or walls etc on a building concrete slab during construction.
          All interesting stuff…
          Polar Duet3 Mini + 1HCL
          https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
          Wanhao D4S: Duet2
          https://forum.duet3d.com/post/296755
          K40 Laser, Duet2
          https://forum.duet3d.com/post/312082
          Wanhao D5S
          https://www.youtube.com/CNCModellerUK
          • o_lampeundefined
            o_lampe
            I added steppers and a central tightening winch. The idea of the hidden weight is not too good, because it would almost move the same as if it was connected directly to the effector.
            This way it won't work with the strap-on corner idea, unless you are willing to drill 3 holes in the 8x6 everytime.
            • o_lampeundefined
              o_lampe
              I tried my luck and modified config for a 2D hangprinter.
              It seems RRF3.4.6 already has the latest version of HP-kinematics. It is oddly specific regarding spool diameter and all.
              m98 p"config.g"
              Error: Wrong number of values after '''D''', expected 3
              Q:Buildup fac 0.0070
              R:Spool r 75.00, 75.00, 75.00, 75.00
              U:Mech Adv 2, 2, 2, 4
              O:Lines/spool 1, 1, 1, 1
              L:Motor gear teeth 20, 20, 20, 20
              H:Spool gear teeth 255, 255, 255, 255
              J:Full steps/rev 25, 25, 25, 25
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
                @o_lampe What are the commands you are using to define it? I'd imagine that the C and D motors don't really matter in M669. Are the other values set in firmware? That might rather limit the usefulness of the Hangprinter kinematics.
                • o_lampeundefined
                  o_lampe @droftarts
                  @droftarts I figured, I could use any two of the ABC motor to define a 2D plane. So I took the BC motors, because they already defined the left and right corner. (A motor is the front/center motor)
                  Here's the basic config.g, but I don't know how to match XY with ABCD or how to define a tool for a plotter
                  G90                                                    ; send absolute coordinates...
                  M83                                                    ; ...but relative extruder moves
                  M550 P"Hangprinter_2D"                                     ; set printer name
                  M669 K6 A0.0:220.0:0.0 B-220.0:220.0:0.0 C220.0:220.0:0.0 D2000.0 P100.0 Q0.0 R1
                  M666 X0 Y0 Z0                                          ; put your endstop adjustments here, or let auto calibration find them
                  M552 S1                                                ; enable network
                  M586 P0 S1                                             ; enable HTTP
                  M586 P1 S0                                             ; disable FTP
                  M586 P2 S0                                             ; disable Telnet
                  M569 P0 S0                                             ; physical drive 0 goes forwards
                  M569 P1 S0                                             ; physical drive 1 goes forwards
                  M569 P2 S0                                             ; physical drive 2 goes forwards
                  M569 P3 S0                                             ; physical drive 3 goes forwards
                  M584 A0 B1 C2 D3                                             ; set drive mapping
                  M350 A16 B16 C16 D16 I1                                ; configure microstepping with interpolation
                  M92 A200.00 B200.00 C200.00 D0                       ; set steps per mm
                  M566 A900.00 B900.00 C900.00 D1200              ; set maximum instantaneous speed changes (mm/min)
                  M203 A24000.00 B24000.00 C24000.00 D4800            ; set maximum speeds (mm/min)
                  M201 A4000.00 B4000.00 C4000.00 D1000               ; set accelerations (mm/s^2)
                  M906 A200 B400 C400 D200 I70                        ; set motor currents (mA) and motor idle factor in per cent
                  M84 S10                                                ; Set idle timeout
                  M208 X-100:100 Y-100:100 Z0:10
                  M563 P0                                           ; define tool 0
                  G10 P0 X0 Y0 Z0                                       ; set tool 0 axis offsets
                  M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"     ; set voltage thresholds and actions to run on power loss
                  T0                                                     ; select first tool
                  //edit OK, I guess I found the reason for one of the errormessages: "D" on has one parameter in my config, but needs three....
                  YES, that solved most of it, although I still don't know, if I have to map AB drives to XY axes? I guess it should be done automatically by the kinematic model?
                  droftartsundefined 2 Replies Last reply Reply Quote 0
                    @o_lampe Looks like our Hangprinter documentation needs updating; there's a whole bunch of parameters not covered on the wiki page here https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_Hangprinter
                    Looks like you can define Q, R, U, O, L, H and J: https://github.com/Duet3D/RepRapFirmware/blob/47435151e110f373fc80721a2c265e38b8ec5e3b/src/Movement/Kinematics/HangprinterKinematics.cpp#L203
                    So it's coming up with sensible numbers for those as well, I guess. There's a reasonable amount of comments in HangprinterKinematics.cpp to hopefully work out what is going on!
                    o_lampeundefined 1 Reply Last reply Reply Quote 1
                      @o_lampe Also note that, as of RRF 3.5.0-beta4, Hangprinter support is removed from Duet 2 WiFi/Ethernet builds. RRF 3.4.6 is fine, though. Just in case you decide to update!
                      https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-350-beta4
                      [Duet 2] Hangprinter kinematics are no longer supported in the standard build of Duet2CombinedFirmware because of lack of flash memory space
                      • o_lampeundefined
                        o_lampe @droftarts
                        @droftarts I have made some progress and got motion in the right directions. But tightening the belts and adding some gravity needs a propper balance of forces. I played with the L&H values and Q&R as well, but didn't see a difference.
                        @CNCModeller How about window cleaning on skyscrapers? The strap-on corners will fit almost anywhere.
                        • o_lampeundefined
                          o_lampe
                          I played a bit more with the HP-kinematics, but there are some weird things I couldn't work out yet:
                          • No matter what I set as steps/mm, it always moves 1/3 of the requested length (XYZABCD, tried all)
                          • I can't move past X0. Positive X-moves are straight, but lower than X0, it starts to make a curve
                          • although I only have ABCD axes in the kinematic model, I have to set motor currents for XYZ??
                          Not very promissing.
                          I really don't want to dig out an old RAMPS controller and bite my teeth out, configuring Marlin 😞
                          • o_lampeundefined
                            o_lampe @o_lampe
                            I found the inverse kinematics which are pretty simple.
                            Just don't want to fall in this rabbit hole called "RRF compiling...with Eclipse"
                            ; inverse kinematics of Makelangelo polargraph plotter
                            function IK(P) {
                              A = Px - M1x;
                              B = Py - M1y;
                              M1P = square_root(A*A+B*B);
                              A = Px - M2x;
                              // B is the same
                              M2P = square_root(A*A+B*B);
                              return M1P,M2P;
                            • o_lampeundefined
                              o_lampe
                              I completely missed that M666 alters the Q,R,L,H,J... settings. Now I've set them to my best knowledge, but now the steppers don't energize.
                              I had to set a Q-value greater 0 to make it work.
                              The XY axes both work in the right direction, but they aren't perpendicular to each other.
                              m669
                              Kinematics is Hangprinter, 100 segments/sec, min. segment length 0.20mm
                              A:0.00, -200.00, 0.00
                              B:193.00, 241.00, 0.00
                              C:-193.00, 241.00, 0.00
                              D:0.00, 0.00, 200.00
                              P:Print radius: 200.0
                              m666
                              Q:Buildup fac 0.0000
                              R:Spool r 6.00, 6.00, 6.00, 6.00
                              U:Mech Adv 1, 1, 1, 1
                              H:Spool gear teeth 20, 20, 20, 20
                              J:Full steps/rev 200, 200, 200, 200
                              droftartsundefined 1 Reply Last reply Reply Quote 1
                              • droftartsundefined droftarts referenced this topic
                                @o_lampe I'm not sure where you are up to on your project, but a couple of notes might help from my Polargraph.
                                In the config.g you posted earlier (which you may already have changed), you have defined the ABCD axes in M584. However, Hangprinter maps the ABCD drives to XYZU. Because ABCD are really anchor points, rather than motor axes. All speeds, accelerations, motor currents etc are in terms of XYZU. See https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_Hangprinter#select-hangprinter-kinematics
                                I had this too. It was caused by the motor assignments, and I actually had the motors mapped incorrectly. Because you only want to use the B and C anchor points, you only use the Y and Z motor assignments. For a long time I was using X and Y! Made particularly confusing for me, because I have the Z motor driver for the Y axis, and E1 motor driver for Z axis. If only we had just called them driver 0 to 4! See the config.g in the Polargraph thread: https://forum.duet3d.com/topic/35248/duet-polargraph
                                I think you resolved the M666 problems, and I think mine are set similar to yours. As far as I can tell, it's mostly to do with gearing and spool wind up, so largely irrelevant for our application, just have to set sensible numbers.
