    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    10.0k
      deckingman @Exerqtor
      @Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
      @deckingman
      I have no idea to be honest, but at least it's a genuine Meanwell UHP-200-24 for the 24v rail, the bed is mains powered through a SSR, and the Duet 5v rail is running of a genuine Meanwell RS-25-5.
      The mains voltage are on the higher side here, BUT it's stable @ 245v, and both the PSU's are rated to handle everything between 88 - 264v.
      So it SHOULD be enough power on hand unless the 24v is wonky.
      Yes I wasn't thinking about the capability of the PSU, just the fact that the M122 shows Vin varying from 22.9 to 26.1 when the machine is idle. Maybe there are some fast transient excursions that ought not to be there. Given everything else that you've tried, it might be worth looking into further.....
      • Exerqtorundefined
        Exerqtor @A Former User
        @KenW
        I hear you, but if it turns out being the disconnects/connects causing the crashing issues, this is a issue that needs solving on the Duet side. NOT by changing out any of the other WiFi equipment (Ubiquity Unifi network, with a dedicated 2.5Ghz SSID).
        The Duet is leaving the house before any of the AP's if we put it that way 😂😂😂😂
        Regarding the voltage issues, I haven't got the feeling that's the cause since the voltages are still WAY within the Duets operating specs after all.
        @deckingman
        Yeah that's true, I just have a sneaking feeling this all mess has the route in something related to the WiFi module at this point.
        Other than that it had another crash a coupe hours ago that I just saw.
        I've been connecting to the printer with both my phone and laptop intermittently do check if anythings happening (hence the two other IP's)
        debug log:
        2023-10-29 12:40:42 [warn] HTTP client 192.168.10.x login succeeded (session key 451652038)
        2023-10-29 12:59:12 [warn] HTTP client 192.168.10.2xx login succeeded (session key 947195611)
        2023-10-29 13:47:02 [warn] HTTP client 192.168.10.xxx login succeeded (session key 834710639)
        2023-10-29 13:51:46 [warn] HTTP client 192.168.10.xxx disconnected
        2023-10-29 14:00:05 [warn] HTTP client 192.168.10.xxx login succeeded (session key 2059405738)
        2023-10-29 14:00:55 [warn] HTTP client 192.168.10.xxx disconnected
        2023-10-29 16:39:10 [warn] HTTP client 192.168.10.xxx login succeeded (session key 3826474446)
        2023-10-29 17:28:47 [warn] HTTP client 192.168.10.xxx login succeeded (session key 2170746625)
        2023-10-29 18:20:29 [warn] HTTP client 192.168.10.xxx login succeeded (session key 3718996851)
        power up + 00:00:03 [info] Event logging started at level debug
        power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1 (2023-08-31 16:16:56)
        power up + 00:00:03 [info] Event logging stopped
        power up + 00:00:03 [debug] Done!
        power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
        power up + 00:00:04 [warn] WiFi module started
        power up + 00:00:08 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.xxxx
        power up + 00:00:08 [warn] HTTP client 192.168.10.xxx login succeeded (session key 3944043149)
        2023-10-29 18:28:38 [warn] Date and time set at power up + 00:00:08
        x = desktop
        xx = phone
        xxx = laptop
        xxxx = printers IP.
        M122:
        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1 (2023-08-31 16:16:56) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
        Used output buffers: 1 of 40 (29 max)
        Static ram: 102836
        Dynamic ram: 124036 of which 0 recycled
        Never used RAM 11688, free system stack 182 words
        Tasks: NETWORK(1,nWait,16.3%,211) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,773) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,0.7%,108) MAIN(1,running,81.9%,704) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 01:24:28 ago, cause: software
        Last software reset at 2023-10-29 18:28, reason: HardFault invState, Gcodes spinning, available RAM 5200, slot 0
        Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok
        Stack: 000001b0 00000002 200014ec 00000000 ffffffff 0009df2d 00000000 600f0000 00000000 00000000 00000000 00000000 200301d4 00000800 20035710 2002bf00 20018668 2002bd9d 20018668 2001e880 0002fedf 00000000 00000000 00000000 20012058 00000014 00000000
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 5068453, completed 5068451, timed out 0, errs 0
        MCU temperature: min 34.4, current 35.1, max 37.8
        Supply voltage: min 23.1, current 24.1, max 26.0, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/564/128, gc cycles 236
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 68, read errors 0, write errors 1, ifcnt 235, reads 4587, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 68, read errors 0, write errors 1, ifcnt 231, reads 4587, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 115, reads 4586, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 116, reads 4586, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 117, reads 4587, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: not present
        Driver 6: not present
        Date/time: 2023-10-29 19:52:58
        Slowest loop: 12.68ms; fastest: 0.13ms
        === Storage ===
        Free file entries: 18
        SD card longest read time 6.4ms, write time 7.1ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        no step interrupt scheduled
        Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
        === DDARing 0 ===
        === DDARing 1 ===
        Heater 1 is on, I-accum = 0.0
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is doing "G4 S1" in state(s) 0 0, running macro
        Aux2 is idle in state(s) 0
        File2 is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x0000803
        Code queue 0 is empty
        Code queue 1 is empty
        === Filament sensors ===
        Extruder 0 sensor: no filament
        === CAN ===
        Messages queued 45625, received 103943, lost 0, boc 0
        Longest wait 2ms for reply type 6031, peak Tx sync delay 336, free buffers 26 (min 25), ts 25342/25341/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 24.73ms; fastest: 0.00ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        === WiFi ===
        Interface state: active
        Module is connected to access point
        Failed messages: pending 0, notrdy 0, noresp 0
        Firmware version 2.1beta4
        MAC address c4:5b:be:ce:91:93
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972
        WiFi IP address 192.168.10.xxxx
        Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
        Clock register 00002001
        gloomyandyundefined NeoDueundefined 2 Replies Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @Exerqtor
          @Exerqtor If the problem is some sort of short transient from the power supply that could easily not be captured by the voltage monitor.
          It might be better to test using the same setup you had when things crashed, so Orca Slicer plus Chrome? Especially if Orca slicer is doing something that is different to the normal connection pattern generated by DWC.
          • DaveAundefined
            DaveA
            Dumb question but where is this debug.log that you are referring to?
            Exerqtorundefined 1 Reply Last reply Reply Quote 0
            • Exerqtorundefined
              Exerqtor @DaveA
              @DaveA said in Reboots/crashes - RRF 3.5.0-rc1:
              It has to be configured through M929.
                dc42 administrators @Exerqtor
                @Exerqtor thanks for creating this new thread, it makes this issue easier to track.
                Please continue to post M122 reports whenever this happens, in case I can establish some common data in the stack trace.
                Please install the firmware at https://www.dropbox.com/scl/fo/tjznycpk7bv7sj71p0ssl/h?rlkey=096p4nvgmigyrb20jj8olg3wu&dl=0. The only issue it fixes that might cause this type of crash is related to filament monitors and (I think) tool changes, so I doubt that it will fix the issue you are experiencing.
                Re DWC disconnects/reconnects, do you have a PanelDue connected? See https://forum.duet3d.com/topic/33538/duet-2-ethernet-disconnect-when-printing-and-paneldue-connected.
                • NeoDueundefined
                  NeoDue @Exerqtor
                  @Exerqtor out of curiosity since you did not mention it (I have to admit I did not read through that huge other thread): The fact that - if I understand you correctly - you say the Mini worked first but started to show issues after a while makes me wonder a bit.
                  Therefore, just to have asked and based on my rusty electronics knowledge - did you check the following two things:
                  • a faulty power supply might produce spikes that will probably never pop up on the voltage display of the duet but might cause issues or even slowly kill your controller (evil to find out and as far as I can tell the Duet is well hardened against such things, but there is always a limit for that). I would not know how to find this that except with an oscilloscope however, or by blindly replacing the power supply with another one that is known to work.
                  • obscure emf / crosstalk issues (which I would not rule out on a new printer) might be found or at least narrowed down if you run the Duet with literally everything unplugged. Do these reboots happen even then? If yes, replace the power supply next. If not, start to plug in things back in one item at a time, wait for the issue to (not) happen, turn off the Duet, plug the next in (or unplug and note the possible culprit if it happens - but do not stop there), boot the Duet etc. If you have located all connectors that seem to cause the issue, remove all the others, plug the first of those in and repeat the process. If you are lucky, the issue happens at once, if not, you need go on until you found its counterpart(s)... and so on.
                    It is an unnervingly lengthy process since you will need to wait for an extended period of time between each attempt, but since you had to fight with that issue for so long now... maybe that process helps. Well, unless you already tried that...
                  • Exerqtorundefined
                    Exerqtor @dc42
                    @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
                    Will do, haven't been another reboot since the last one i posted. But the desktop has been in hibernation without any connections to DWC. But i will continue posting reports until a solution is found 🤣
                    Installing that now, thanks!
                    Yup i have a PanelDue connected as well, i'll update the system description to inlcude that as i completely forgot to mention it.
                    @NeoDue said in Reboots/crashes - RRF 3.5.0-rc1:
                    To emboss that statement i made about the Mini seeming to be working a little bit:
                    • When i hooked it up and did the initial tests i didn't have the desktop computer or any other clients connected through DWC either. I just did the PID tuning etc. from the PanelDue and ran a quick test cube to see that all actually worked. Then the printer stood idle witout no use or anything until I had time to work on it in early october, when i quickly
                      saw that the issues wasn't solved at all.
                    I'll try to see how it behaves over the weekend, and if it's still acting up (which i assume it will) I'll try running it "barebones" for a day or two and see if anything happens.
                    Not saying a faulty PSU or EMF ain't the issue, it's just not what my gut is telling me at this point.
                    • Exerqtorundefined
                      Exerqtor @Exerqtor
                      And a new crash, also while idle, but being active on the desktop with an instance of DWC open through OrcaSlicer.
                      This is the first crash in 4 days, and the only difference (other than FW updates that shouldn't effect this anyways), is that I've been active on the desktop with an DWC instance connected.
                      Don't know if this is just me seeing paterns in the clouds lol, but i'm sure starting to see a clear pattern in when it crash or not.
                      This is with RRF 3.5.0rc1+ on the Mini / 1LC, and 3.5.0rc7 on the panel due.
                      degbug:
                      power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03)
                      power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady
                      power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady
                      power up + 00:00:04 [debug] - Event notification -
                      power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady
                      power up + 00:00:08 [warn] HTTP client 192.168.10.xx login succeeded (session key 1133366275)
                      2023-11-03 23:29:57 [warn] Date and time set at power up + 00:00:08
                      M122:
                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-01 10:29:03) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Used output buffers: 9 of 40 (40 max)
                      Static ram: 102812
                      Dynamic ram: 123924 of which 0 recycled
                      Never used RAM 11824, free system stack 186 words
                      Tasks: NETWORK(2,nWait,18.3%,209) HEAT(3,nWait,0.0%,354) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.8%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                      Owned mutexes:
                      Last reset 00:13:05 ago, cause: software
                      Last software reset at 2023-11-03 23:29, reason: HardFault invState, Gcodes spinning, available RAM 10940, slot 2
                      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f88 Task NETW Freestk 482 ok
                      Stack: 000001b0 00000002 200014e8 00000000 ffffffff 0009e9cd 00000000 600f0000 00000000 00000000 00000000 00000000 20031c4c 00000800 2002c0e0 2002c0e0 00000001 2002bf7d 20018658 2001e868 0002ff97 00000000 00000000 00000000 20012038 00000014 b5dd8a35
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 785822, completed 785822, timed out 0, errs 0
                      MCU temperature: min 37.0, current 37.4, max 40.1
                      Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1856/1420, gc cycles 36
                      Events: 1 queued, 1 completed
                      Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 31, reads 41299, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: standstill, SG min 246, read errors 0, write errors 1, ifcnt 27, reads 41299, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 161, reads 41299, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 162, reads 41298, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 164, reads 41299, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2023-11-03 23:42:53
                      Cache data hit count 1378843841
                      Slowest loop: 13.16ms; fastest: 0.13ms
                      === Storage ===
                      SD card longest read time 6.9ms, write time 4.6ms, max retries 0
                      === DDARing 0 ===
                      === DDARing 1 ===
                      check 0 clear 0
                      === CAN ===
                      Messages queued 7076, received 16136, lost 0, errs 1, boc 0
                      Longest wait 2ms for reply type 6031, peak Tx sync delay 231, free buffers 26 (min 25), ts 3926/3925/0
                      === Network ===
                      Slowest loop: 8.42ms; fastest: 0.00ms
                      HTTP sessions: 3 of 8
                      === WiFi ===
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39880
                      Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0
                      A new development this time is that the hotend heater reports fault and reads 2000C after the crash.
                      After when restarting it manually (with M999) it reports back as usual (active / 25C).
                      • Exerqtorundefined
                        Exerqtor @Exerqtor
                        Another crash about 4 hours and 30minutes ago, one instance of DWC open on the desktop but with orcaslicer/other instances closed (printer idle).
                        This time it also reports a heater fault and 2000c on the hotend, so it seems like the toolboard don't get recognized after the crashes now.
                        debug:
                        2023-11-05 00:02:51 [warn] HTTP client 192.168.10.100 login succeeded (session key 328058056)
                        power up + 00:00:10 [warn] HTTP client 192.168.10.xx login succeeded (session key 987728275)
                        2023-11-05 06:19:22 [warn] Date and time set at power up + 00:00:10
                        M122 after crash:
                        Used output buffers: 1 of 40 (34 max)
                        Static ram: 102812
                        Never used RAM 11824, free system stack 182 words
                        Tasks: NETWORK(1,ready,58.6%,203) HEAT(3,nWait,0.1%,331) Move(4,nWait,0.0%,356) CanReceiv(6,nWait,0.2%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,2.3%,108) MAIN(1,running,35.2%,670) IDLE(0,ready,0.9%,29) AIN(4,delaying,2.7%,264), total 100.0%
                        Last reset 04:30:58 ago, cause: software
                        Last software reset at 2023-11-05 06:19, reason: HardFault invState, Gcodes spinning, available RAM 11236, slot 1
                        Stack: 000001ae 00000002 200014e8 00000000 20032e1a 0009e9cd 00000000 600f0000 00000000 00000000 00000000 00000000 200303ec 00000800 20035928 2002c0e0 20018658 2002bf7d 20018658 2001e868 0002ff97 00000000 00000000 00000000 20012038 00000014 904c0824
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 16258966, completed 16258966, timed out 0, errs 0
                        MCU temperature: min 36.2, current 37.2, max 39.2
                        Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/716/280, gc cycles 756
                        Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 69, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: standstill, SG min 236, read errors 0, write errors 1, ifcnt 64, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 193, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 194, reads 3741, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 196, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2023-11-05 10:50:10
                        Slowest loop: 13.22ms; fastest: 0.13ms
                        === Storage ===
                        SD card longest read time 7.2ms, write time 4.4ms, max retries 0
                        === DDARing 0 ===
                        === DDARing 1 ===
                        check 0 clear 0
                        === CAN ===
                        Messages queued 146340, received 333359, lost 0, errs 0, boc 0
                        Longest wait 2ms for reply type 6053, peak Tx sync delay 270, free buffers 26 (min 25), ts 81295/81294/0
                        === Network ===
                        Slowest loop: 8.43ms; fastest: 0.00ms
                        HTTP sessions: 2 of 8
                        === WiFi ===
                        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960
                        And here is a M122 report from after restarting the board(s) with M999:
                        Used output buffers: 4 of 40 (29 max)
                        Static ram: 102812
                        Dynamic ram: 122012 of which 12 recycled
                        Never used RAM 13724, free system stack 198 words
                        Tasks: NETWORK(1,ready,11.8%,228) HEAT(3,nWait,0.0%,356) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,352) TMC(4,nWait,0.7%,116) MAIN(1,running,85.2%,670) IDLE(0,ready,1.4%,29) AIN(4,delaying,0.8%,272), total 100.0%
                        Owned mutexes:
                        Last reset 00:00:21 ago, cause: software
                        Last software reset at 2023-11-05 10:51, reason: User, Gcodes spinning, available RAM 11824, slot 2
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 21884, completed 21884, timed out 0, errs 0
                        MCU temperature: min 37.0, current 37.2, max 40.1
                        Supply voltage: min 8.3, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1692/1296, gc cycles 0
                        Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 83, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: standstill, SG min 236, read errors 0, write errors 1, ifcnt 78, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 207, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 208, reads 1120, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 210, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2023-11-05 10:52:03
                        Cache data hit count 36913447
                        Slowest loop: 5.73ms; fastest: 0.14ms
                        === Storage ===
                        SD card longest read time 3.8ms, write time 6.0ms, max retries 0
                        === DDARing 0 ===
                        === DDARing 1 ===
                        check 0 clear 0
                        === CAN ===
                        Messages queued 208, received 436, lost 0, errs 0, boc 0
                        Longest wait 2ms for reply type 6031, peak Tx sync delay 3, free buffers 26 (min 25), ts 109/108/0
                        === Network ===
                        Slowest loop: 8.47ms; fastest: 0.00ms
                        === WiFi ===
                        It should be noted that it's no recent wifi connections/disconnections leading up to any of the recent crashes in the logs, however it's been one or more connected session on each of them.
                        deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          I still maintain that swapping out your PSU might be a good. Early on you were showing min 22.9, max 26.1 when idle - that ain't normal. Now you have a minimum of 8.3V - that definitely ain't normal.
                          Exerqtorundefined 1 Reply Last reply Reply Quote 2
                            @Exerqtor thanks. Those last 2 M122 reports have some common features.
                            • Exerqtorundefined
                              Exerqtor @deckingman
                              @deckingman said in Reboots/crashes - RRF 3.5.0-rc1:
                              Yeah i don't know if those readings can maybe (thinking out loud here now) off since i run the Duet3 of a 5v PSU? And the 24v PSU is switched off/on with relays each time the board reboots. 🤷‍♂️ Just to be clear that's more of a question than a statement from my end.
                              I just got home, and it litterlarly crashed a minute or two after i came home, this time it's also showing heaterfault & 2000c on the hotend
                              debug:
                              power up + 00:00:08 [warn] HTTP client 192.168.10.xx login succeeded (session key 2917043153)
                              2023-11-06 15:53:21 [warn] Date and time set at power up + 00:00:08
                              M122 after crash:
                              Used output buffers: 1 of 40 (40 max)
                              Static ram: 102812
                              Tasks: NETWORK(1,ready,17.5%,234) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.7%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                              Last reset 00:13:58 ago, cause: software
                              Last software reset at 2023-11-06 15:53, reason: HardFault invState, Platform spinning, available RAM 10940, slot 0
                              Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f88 Task NETW Freestk 482 ok
                              Stack: 000001af 00000002 200014e8 00000000 20032e1b 0009e9cd 00000000 600f0000 00000000 00000000 00000000 00000000 200303ec 00000800 20035928 2002c0e0 20018658 2002bf7d 20018658 2001e868 0002ff97 00000000 00000000 00000000 20012038 00000014 b5dd8a35
                              Error status: 0x04
                              Aux0 errors 0,0,0
                              MCU revision 3, ADC conversions started 838810, completed 838810, timed out 0, errs 0
                              MCU temperature: min 36.2, current 36.6, max 39.2
                              Supply voltage: min 23.3, current 24.1, max 25.9, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1096/660, gc cycles 39
                              Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 107, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 1: standstill, SG min 244, read errors 0, write errors 1, ifcnt 102, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 225, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 226, reads 44113, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 228, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Date/time: 2023-11-06 16:07:29
                              Cache data hit count 1443468903
                              Slowest loop: 12.56ms; fastest: 0.13ms
                              === Storage ===
                              SD card longest read time 6.9ms, write time 4.4ms, max retries 0
                              === DDARing 0 ===
                              === DDARing 1 ===
                              check 0 clear 0
                              === CAN ===
                              Messages queued 7558, received 17228, lost 0, errs 1, boc 0
                              Longest wait 3ms for reply type 6053, peak Tx sync delay 327, free buffers 26 (min 25), ts 4194/4193/0
                              === Network ===
                              Slowest loop: 6.64ms; fastest: 0.00ms
                              === WiFi ===
                              Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42952
                              Signal strength -47dBm, channel 6, mode 802.11n, reconnections 0
                              M122 after manual reboot with M999:
                              Used output buffers: 1 of 40 (32 max)
                              Static ram: 102812
                              Dynamic ram: 122024 of which 0 recycled
                              Tasks: NETWORK(1,ready,13.4%,238) HEAT(3,nWait,0.0%,360) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,352) TMC(4,nWait,0.7%,116) MAIN(1,running,84.0%,670) IDLE(0,ready,1.0%,29) AIN(4,delaying,0.8%,272), total 100.0%
                              Last reset 00:00:32 ago, cause: software
                              Last software reset at 2023-11-06 16:08, reason: User, Gcodes spinning, available RAM 11824, slot 1
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU revision 3, ADC conversions started 32518, completed 32518, timed out 0, errs 0
                              MCU temperature: min 36.3, current 36.8, max 39.2
                              Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/904/508, gc cycles 1
                              Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 121, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 1: standstill, SG min 244, read errors 0, write errors 1, ifcnt 116, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 239, reads 1680, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 240, reads 1680, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 242, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Date/time: 2023-11-06 16:08:19
                              Cache data hit count 54882292
                              Slowest loop: 8.47ms; fastest: 0.13ms
                              === Storage ===
                              SD card longest read time 3.6ms, write time 4.1ms, max retries 0
                              === DDARing 0 ===
                              === DDARing 1 ===
                              check 0 clear 0
                              === CAN ===
                              Messages queued 304, received 651, lost 0, errs 1, boc 0
                              Longest wait 3ms for reply type 6013, peak Tx sync delay 189, free buffers 26 (min 25), ts 163/162/0
                              === Network ===
                              Slowest loop: 8.45ms; fastest: 0.00ms
                              === WiFi ===
                              Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42944
                              • Exerqtorundefined
                                Exerqtor @Exerqtor
                                Haven't had much time to derp with the printer this week/weekend, plus my damn desktop computer is starting to slowly bite the dust (rejecting RAM, wohoo).
                                Anywho, had a couple minutes to check the loggs now while doing som other stuff, and the wifi controller ain't happy.
                                debug:
                                power up + 00:00:06 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:06 [warn] WiFi module is idle
                                power up + 00:00:08 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:08 [warn] WiFi module is idle
                                power up + 00:00:10 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:10 [warn] WiFi module is idle
                                power up + 00:00:12 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:12 [warn] WiFi module is idle
                                power up + 00:00:14 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:14 [warn] WiFi module is idle
                                power up + 00:00:17 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:17 [warn] WiFi module is idle
                                power up + 00:00:19 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:19 [warn] WiFi module is idle
                                power up + 00:00:21 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:21 [warn] WiFi module is idle
                                power up + 00:00:23 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:23 [warn] WiFi module is idle
                                power up + 00:00:25 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:25 [warn] WiFi module is idle
                                power up + 00:00:28 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:28 [warn] WiFi module is idle
                                power up + 00:00:30 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:30 [warn] WiFi module is idle
                                power up + 00:00:32 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:32 [warn] WiFi module is idle
                                power up + 00:00:34 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:34 [warn] WiFi module is idle
                                power up + 00:00:36 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:36 [warn] WiFi module is idle
                                power up + 00:00:39 [warn] Error: WiFi module reported: Failed to load credentials
                                power up + 00:00:39 [warn] WiFi module is idle
                                power up + 00:00:41 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:41 [warn] WiFi module is idle
                                power up + 00:00:43 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:43 [warn] WiFi module is idle
                                power up + 00:00:45 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:45 [warn] WiFi module is idle
                                power up + 00:00:47 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:47 [warn] WiFi module is idle
                                power up + 00:00:50 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:50 [warn] WiFi module is idle
                                power up + 00:00:52 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:52 [warn] WiFi module is idle
                                power up + 00:00:54 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:54 [warn] WiFi module is idle
                                power up + 00:00:56 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:56 [warn] WiFi module is idle
                                power up + 00:00:58 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:58 [warn] WiFi module is idle
                                power up + 00:01:01 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:01 [warn] WiFi module is idle
                                power up + 00:01:03 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:03 [warn] WiFi module is idle
                                power up + 00:01:05 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:05 [warn] WiFi module is idle
                                power up + 00:01:07 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:07 [warn] WiFi module is idle
                                power up + 00:01:09 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:09 [warn] WiFi module is idle
                                power up + 00:01:12 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:12 [warn] WiFi module is idle
                                power up + 00:01:14 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:14 [warn] WiFi module is idle
                                power up + 00:01:16 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:16 [warn] WiFi module is idle
                                power up + 00:01:18 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:18 [warn] WiFi module is idle
                                power up + 00:01:20 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:20 [warn] WiFi module is idle
                                power up + 00:01:23 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:23 [warn] WiFi module is idle
                                power up + 00:01:25 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:25 [warn] WiFi module is idle
                                power up + 00:01:27 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:27 [warn] WiFi module is idle
                                power up + 00:01:29 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:29 [warn] WiFi module is idle
                                power up + 00:01:32 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:32 [warn] WiFi module is idle
                                power up + 00:01:34 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:34 [warn] WiFi module is idle
                                power up + 00:01:36 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:36 [warn] WiFi module is idle
                                power up + 00:01:38 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:38 [warn] WiFi module is idle
                                power up + 00:01:40 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:40 [warn] WiFi module is idle
                                power up + 00:01:43 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:43 [warn] WiFi module is idle
                                power up + 00:01:45 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:45 [warn] WiFi module is idle
                                power up + 00:01:47 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:47 [warn] WiFi module is idle
                                power up + 00:01:49 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:49 [warn] WiFi module is idle
                                power up + 00:01:51 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:51 [warn] WiFi module is idle
                                power up + 00:01:54 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:54 [warn] WiFi module is idle
                                power up + 00:01:56 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:56 [warn] WiFi module is idle
                                power up + 00:01:58 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:58 [warn] WiFi module is idle
                                power up + 00:02:00 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:00 [warn] WiFi module is idle
                                power up + 00:02:02 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:02 [warn] WiFi module is idle
                                power up + 00:02:05 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:05 [warn] WiFi module is idle
                                power up + 00:02:07 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:07 [warn] WiFi module is idle
                                power up + 00:02:09 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:09 [warn] WiFi module is idle
                                power up + 00:02:11 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:11 [warn] WiFi module is idle
                                power up + 00:02:15 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
                                power up + 00:03:04 [warn] Error: WiFi module reported: Lost connection, auto reconnecting
                                power up + 00:03:04 [warn] Error: WiFi module reported: Auto reconnect succeeded
                                power up + 00:00:06 [warn] Error: WiFi module reported: Failed to load credentials
                                power up + 00:00:08 [warn] Error: WiFi module reported: Failed to load credentials
                                power up + 00:00:13 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:13 [warn] WiFi module is idle
                                power up + 00:00:15 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:15 [warn] WiFi module is idle
                                power up + 00:00:24 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:24 [warn] WiFi module is idle
                                power up + 00:00:26 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:26 [warn] WiFi module is idle
                                power up + 00:00:35 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:35 [warn] WiFi module is idle
                                power up + 00:00:37 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:37 [warn] WiFi module is idle
                                power up + 00:00:39 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:46 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:46 [warn] WiFi module is idle
                                power up + 00:00:48 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:48 [warn] WiFi module is idle
                                power up + 00:00:55 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:55 [warn] WiFi module is idle
                                power up + 00:00:57 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:57 [warn] WiFi module is idle
                                power up + 00:00:59 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:00:59 [warn] WiFi module is idle
                                power up + 00:01:06 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:06 [warn] WiFi module is idle
                                power up + 00:01:08 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:08 [warn] WiFi module is idle
                                power up + 00:01:10 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:10 [warn] WiFi module is idle
                                power up + 00:01:15 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:15 [warn] WiFi module is idle
                                power up + 00:01:17 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:17 [warn] WiFi module is idle
                                power up + 00:01:19 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:19 [warn] WiFi module is idle
                                power up + 00:01:21 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:21 [warn] WiFi module is idle
                                power up + 00:01:24 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:24 [warn] WiFi module is idle
                                power up + 00:01:26 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:26 [warn] WiFi module is idle
                                power up + 00:01:28 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:28 [warn] WiFi module is idle
                                power up + 00:01:30 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:30 [warn] WiFi module is idle
                                power up + 00:01:35 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:35 [warn] WiFi module is idle
                                power up + 00:01:37 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:37 [warn] WiFi module is idle
                                power up + 00:01:39 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:39 [warn] WiFi module is idle
                                power up + 00:01:41 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:41 [warn] WiFi module is idle
                                power up + 00:01:44 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:44 [warn] WiFi module is idle
                                power up + 00:01:46 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:46 [warn] WiFi module is idle
                                power up + 00:01:48 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:48 [warn] WiFi module is idle
                                power up + 00:01:50 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:50 [warn] WiFi module is idle
                                power up + 00:01:53 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:53 [warn] WiFi module is idle
                                power up + 00:01:55 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:55 [warn] WiFi module is idle
                                power up + 00:01:57 [warn] Error: WiFi module reported: Failed to load credentials
                                power up + 00:01:57 [warn] WiFi module is idle
                                power up + 00:01:59 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:01:59 [warn] WiFi module is idle
                                power up + 00:02:01 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:01 [warn] WiFi module is idle
                                power up + 00:02:04 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:06 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:06 [warn] WiFi module is idle
                                power up + 00:02:08 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:08 [warn] WiFi module is idle
                                power up + 00:02:10 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:10 [warn] WiFi module is idle
                                power up + 00:02:13 [warn] Error: WiFi module reported: no known networks found
                                power up + 00:02:13 [warn] WiFi module is idle
                                power up + 00:02:15 [warn] Error: WiFi module reported: Failed to load credentials
                                power up + 00:02:15 [warn] WiFi module is idle
                                power up + 00:02:18 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
                                power up + 00:02:48 [warn] Error: WiFi module reported: Lost connection, auto reconnecting
                                power up + 00:02:49 [warn] Error: WiFi module reported: Auto reconnect succeeded
                                power up + 69:32:47 [warn] HTTP client 192.168.10.xx login succeeded (session key 1481405628)
                                2023-11-10 15:27:24 [warn] Date and time set at power up + 69:32:47
                                Continued on the next reply
                                • Exerqtorundefined
                                  Exerqtor @Exerqtor
                                  M122;
                                  Used output buffers: 22 of 40 (40 max)
                                  Static ram: 102812
                                  Dynamic ram: 122036 of which 12 recycled
                                  Never used RAM 13700, free system stack 180 words
                                  Tasks: NETWORK(2,nWait,53.7%,213) HEAT(3,nWait,2.2%,327) Move(4,nWait,0.2%,344) CanReceiv(6,nWait,4.3%,772) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.7%,341) TMC(4,nWait,61.6%,108) MAIN(1,running,111.9%,670) IDLE(0,ready,22.0%,29) AIN(4,delaying,71.9%,264), total 328.3%
                                  Last reset 123:52:45 ago, cause: power up
                                  Error status: 0x04
                                  Aux0 errors 0,0,0
                                  MCU revision 3, ADC conversions started 445965944, completed 445965943, timed out 0, errs 0
                                  MCU temperature: min 24.4, current 36.2, max 36.6
                                  Supply voltage: min 0.2, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/980/584, gc cycles 20101
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9947, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9947, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Date/time: 2023-11-12 21:47:22
                                  Slowest loop: 11.70ms; fastest: 0.13ms
                                  === Storage ===
                                  SD card longest read time 7.0ms, write time 4.5ms, max retries 0
                                  === DDARing 0 ===
                                  === DDARing 1 ===
                                  check 0 clear 0
                                  === CAN ===
                                  Messages queued 4013705, received 9142508, lost 0, errs 3539, boc 0
                                  Longest wait 3ms for reply type 6053, peak Tx sync delay 11386, free buffers 26 (min 25), ts 2229830/2229826/0
                                  Tx timeouts 0,0,3,0,0,0 last cancelled message type 30 dest 127
                                  === Network ===
                                  Slowest loop: 19.15ms; fastest: 0.00ms
                                  Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                  === WiFi ===
                                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39508
                                  Signal strength -53dBm, channel 6, mode 802.11n, reconnections 1
                                  Should be noted that on this crash it didn't fail to connect to the toolboard, so it wasn't any heater faults etc.
                                    @Exerqtor please remind me: did this issue also occur when using firmware 3.4.x, or is it specific to 3.5.x?
                                    I've created https://github.com/Duet3D/RepRapFirmware/issues/935 t track and summarise this, but please continue to post M122 reports in this thread.
                                    dc42 created this issue in Duet3D/RepRapFirmware
                                    closed Regular crashes on Duet 3 Mini WiFi #935
                                    dc42undefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                                      dc42 administrators @dc42
                                      @Exerqtor please install the firmware at https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and post the M122 report when it next crashes. I have added some extra debug in the area where I think it is crashing.
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        IF it happened in 3.4.5 it must have been so Intermittent that i didn't catch it happening. If we put it that way.
                                        Okok i will do it later today 👌☺️
                                        • Exerqtorundefined
                                          Exerqtor @Exerqtor
                                          The printer has been sitting idle since i updated to the "special" firmware you compiled, and it's been running for about 24hr with one instance of DWC open but the PC not being used (used stood there ).
                                          Now i've been sitting on the PC working for 10min, with the printer idle and in that time the printer has crashed. This time again it's not connecting to the 1LC after the crash and it's throwing a heater fault & 2000C.
                                          debuglog:
                                          2023-11-15 20:35:24 [warn] HTTP client 192.168.10.xx disconnected
                                          2023-11-15 20:35:27 [warn] HTTP client 192.168.10.xx login succeeded (session key 55059692)
                                          2023-11-15 20:35:31 [warn] HTTP client 192.168.10.xx disconnected
                                          2023-11-15 20:35:36 [warn] HTTP client 192.168.10.xx login succeeded (session key 1424224561)
                                          power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-14 10:45:05)
                                          power up + 00:00:08 [warn] HTTP client 192.168.10.xx login succeeded (session key 740842430)
                                          2023-11-15 20:37:48 [warn] Date and time set at power up + 00:00:08
                                          M122:
                                          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-14 10:45:05) running on Duet 3 Mini5plus WiFi (standalone mode)
                                          Used output buffers: 1 of 40 (30 max)
                                          Static ram: 102812
                                          Dynamic ram: 123820 of which 0 recycled
                                          Never used RAM 11928, free system stack 188 words
                                          Tasks: NETWORK(1,ready,17.6%,209) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.6%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                          Owned mutexes:
                                          Last reset 00:15:57 ago, cause: software
                                          Last software reset at 2023-11-15 20:37, reason: AssertionFailed, Gcodes spinning, available RAM 6020, slot 0
                                          Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                                          Stack: 000008fe 000af1c8 0002dd83 2002beb4 2002be01 000001a8 2002c0e0 20030b90 2002c0f8 2001e868 a5a5a5a5 a5a5a5a5 00000000 00000000 00000000 00000000 20030b9c 00000800 200358c0 2002c0e0 20018658 2002bf7d 20018658 2001e868 00030023 00000000 00000000
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          MCU revision 3, ADC conversions started 958328, completed 958328, timed out 0, errs 0
                                          MCU temperature: min 35.1, current 35.5, max 38.2
                                          Supply voltage: min 22.7, current 24.1, max 26.3, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1932/1496, gc cycles 44
                                          Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 118, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 118, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 81, reads 50391, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 79, reads 50391, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 80, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Date/time: 2023-11-15 20:53:37
                                          Cache data hit count 1623656227
                                          Slowest loop: 12.73ms; fastest: 0.13ms
                                          === Storage ===
                                          SD card longest read time 6.5ms, write time 4.6ms, max retries 0
                                          === DDARing 0 ===
                                          === DDARing 1 ===
                                          in 0 notIn 0
                                          === CAN ===
                                          Messages queued 8631, received 19678, lost 0, errs 1, boc 0
                                          Longest wait 2ms for reply type 6053, peak Tx sync delay 299, free buffers 26 (min 25), ts 4790/4789/0
                                          === Network ===
                                          Slowest loop: 9.16ms; fastest: 0.00ms
                                          === WiFi ===
                                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43136
                                          Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
                                            @Exerqtor thanks, that's just what I needed to confirm the area of the code that's going wrong.
                                            To help pin it down further, please install the new version of firmware from https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and send a M122 report when it resets again. I don't need a second M122 after a manual reboot.
                                            Exerqtorundefined 1 Reply Last reply Reply Quote 1
